Question about Dryers
Dryer puts brown streaks about 2 inches long on clothes while drying.
  • 4,323 Answers
Hi
Try cleaning the lint filter on your dryer and also clean the blower housing and vents. If this does not resolve the issue then please post back with make and model # of the dryer.
Daniel
Posted on Apr 08, 2011
My clothes are leaving the dryer with streaks (maybe 4 or 5 inches long) that appear to be burn marks. Closer inspection of the inside of the drum shows that the back "wall" of the drum is off-center...
I have the same problem and read somewhere to replace the felt belts. We have done this twice and still getting the brown marks. I have found using Goo Gone and/or Dawn dish soap and scrubbing with a brush will take most of the mark out, re-wash and HANG to dry. I'm still looking for a permanent solution to this problem, as much as these dryer cost and you can't dry white clothes???
Jun 28, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have been getting brown streaks after drying clothes in my whirlpool dryer. they are about an inch long. My dryer is about 12 years old. Is it worth getting new drum seals or ghetting a new dryer?? (...
Try cleaning the entire air vent system of lint first including the exit vent panel (to the outside air). Remove the lint screen and wash it in detergent and hot water. The brown streaks are probably scorch marks rather than oil or grease entering the drum. Good air movement is essential to holding the drying temperature down. Hope this saves that old Whirlpool for another decade!
Sep 23, 2009 | Dryers
Brown streaks left on clothes
Not having seen this before, but my best guess would be that the piece of clothes is caught in one position and rubbing on the gasket material around the rear of the drum. Is the mark permanent?
Apr 16, 2009 | Whirlpool ET8CHEXSQ Dryer
Brown streaks on clothes from dryer
is it possible that something was left in a pocket that ended up in the dryer check inside the dryer for any ink gum or stains inside the drum because there is no way the dryer left these stains other than from something you accidentally put inside
Feb 16, 2018 | Maytag Dryers
Brown streak on clothes
It could be from scorching due to getting too hot. This may be the start of a problem for you.
It is best to judge how long clothes need drying for before drying them. If they are left too long, sometimes the heat builds up.
Try a smaller load in there, and if you can reduce the temperature any then do.
Often it's just overloading is the issue.
Hope this is a solution for you, If so, Please rate as Fixya! Thanks.
Jun 18, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Dryer leaving brown streaks on clothes
the brown streaks and holes will be when they get stuck the dryer is still turning and it will be friction marks if it is getting stuck between the inner and outer drums than check to see if there is any wobble in the inner drum by opening the door and placing your hand at the top of the outer rim of the panel and place your fingers to the top of the inner drum pull your fingers towards your hand if there is any movement than the bearings are gone which will need replacing once done then this will eliminate the problem if there is no movement check to see if there is a seal missing from between the inner and outer drum u can find this out by checking with your fingers than calling the manufacturer to see if there is supposed to be one there
Aug 19, 2007 | Hotpoint NBXR463EBWW Electric Dryer
mich, The brown streaks are probably caused by worn drum guides and lower basket seal. I've seen this quite often on Frigidaire dryers. Part numbers 5303937139 upper felt guide and 5303283286 lower basket seal. This can be a task for an inexperienced person but can be done. It requires removing the top panel and front panel/door assy. The old guides have to be scraped off. The upper felt guides and lower seal glue on. Catriver...post back.
Nov 19, 2006 | Frigidaire GLEQ642A Electric Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
