Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Poulan 16" saw, start fine, runs fine until it
  • Poulan Master
  • 2,239 Answers
A couple of ideas, it could be a fuel tank breather issue, when it starts to die just try loosening the fuel cap, if the saw picks up again you will need to change the breather, the only other thing i can think of is a bad ignition that is breaking down when hot, the only aswer to this is to replace the ignition unit
Posted on Apr 08, 2011
How do i adjust the carbarator on my poulan chain saw stalls out if running at full throttle when cutting
Ok, so there are 2 adjustment needles on the carburetor. A H and an L... If your saw is idling fine you won't have to worry about adjusting the L needle.
Your focus will be on the H... the high.
Firstly, if there is any plastic covers on the adjustment needles, remove them. Usually red and white in color... or just white. They serve no purpose(EPA regulations for California). Now adjustart in quarter turn increments.. turn the screw to the right until snug, now back it out 1 full turn. This is your starting point. While holding the trigger all the way in, turn the needle counter clockwise in quarter turn increments, use your ear to tell when you have peak performance.
If you can't hold it down cause it bogs out, just hold it in as much as you can while you turn the needle until you can fully depress the trigger all the way
Nov 01, 2015 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
My new poulan will start and run great for about 5-10 minutes then will just quit running. let it set and cool down and it will do the same thing why?
important to use correct oil and mix. no guessing. too much oil mix fouls up the engine. make sure blade is adjusted properly and not gummed up with oily debri
Feb 14, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do I adjust the carburator on a poulan wild thing 2375 chain saw that bogs down when cutting and is hard to start?
there are two screws on the carb start by turning them all the way in then 3 full turns out and then make half turn adjustments until you get it right..
Aug 06, 2014 | Poulan Garden
Poulan " Wild Thing
It is running lean, they always need to run a little on the rich side free running, once the engine is loaded it will then need the excess fuel, it runs ok without the bar and chain because there is no load, start by replacing the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of fuel leakage, replace if reqired, if the carb has standard adjuster screws, increase the H screw by 1/4 turn out ( anto clockwise ) this will richen the mixture.
Aug 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My Poulan Pro 295 chain saw starts fine, runs for a few minutes, then stops and will not start until completely cool. What could be my problem?
It sounds very much loke the ignition is playing up when hot, just as a little test when it starts to die slacken off the fuel filler cap does it pick up/re start? if yes it is a fuel tank breather issue, replace the breather.
Apr 25, 2011 | Poulan Pro Chain Saw 46cc 20"
Usually when a small engine starts fine.. runs fine.. gets hot it's ignition related.
First you want to make sure the cooling fins are clean.. remove any covers and clean the area around the head. If those fins are clogged.. not good.
Second I would check the spark.. and the spark plug condtion.
Also for power tools that don't get used that often.. fuel sytems get gummed up.. fuel gets old.. and folks tend to use the fuel in the can they mixed two seasons ago. Make sure the fuel mix is correct.
I assume it is running fine with the choke off.. however check the choke for proper operation.
Clean or replace the air filter as well.. once all the ignition and fuel components are in good order.. only then should you begin to adjust the carb. Probably not needed.. but don't do it until you are satisfied that you have good air fuel mix and proper spark.
Best of luck
Apr 08, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I was cutting 16" logs
The motor is locked up.What it did is seized the rod too the crank.Hate to say it but it,s time for a new saw.
Nov 29, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Bogs down?
Try turning the "H" needle CCW a little. Cleaning the muffler and spark arrestor is a good idea too (if it cannot exhale it cannot inhale).
I do not think you need this but something to save for later.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 08, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Saw will start an run short period and stop.Only start when adding gas directly into carberator. This is a Poulan 16 chain saw.
If it is a old saw it sounds like your engine seals are failing. when a engine seal fails it allows air in past the crank upsetting your fuel mixture You could try to richin the fuel mixture by turning the screw marked H anticlockwise a quarter at a time untill it runs Ps to set (h) screw to factory, screw it in til it stops then unscrew it 1 & 1/2 turns
Sep 25, 2009 | Poulan Garden
My 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Jan 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
396 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
