Question about Whirlpool 24 in. ADG7540 Built-in Dishwasher
Dishwasher drains OK ,heats water OK I can select programmes OK but the washer arms don't spin.....help please
  • Whirlpool Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Apr 08, 2011
I have a built in whirlpool dishwasher. My problem is that dishes aren't being washed properly, there was water in the bottom of the washer, I removed and cleaned the filters ran the machine and the water...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 25, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Takes on water ok, heats and drains but spray arms dont move
You will probably find that this is because there is not enough water pressure going through the jets.
1. Take off the top rotery arm by unscrewing the nut and then it can be released from the basket by giving a twist and pushing backwards. once off check that all the jets are clear and that the small plastic washer is OK re assemble and ensure that is spins freely.
2. if this does not help then the problem may be with the recirculating pump underneath. Replace the capacitor that is attached to it. This drastically improved my dishwasher and now works better than when it was new.
3. if this does not work then you are on your own as I have no orther suggestions.
Oct 24, 2010 | Hoover 24 in. HD97E Free-standing...
Dishwasher is 16 months old. Recently, it won't get tea stains from spoons or cups and there is a white film on plastics. I have run unit once with vinegar. I tried using less detergent and no change...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Sep 26, 2010 | Maytag MDBH985AWB / MDBH985AWS 24 in....
Not draining water and not cleaning all, pipes ok is machine just old bosch exxcel dishwasher
heatman101
e
Dec 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Not draining and washer arm not spinning
Have you cleaned the drain filter? The symptoms you describe indicate that the filter are totally clogged.
Cleaning filters should be done every other week to maintain good function in dishwashers, it is not uncommon people forget that.
You access the filter by removing the perforated stainless steel plate at the floor of the washer tub, usually there is a round plastic knob in the middle that you turn counter-clockwise then lift it up. Underneath this plate you will find the main filter, take it out and clean with a soft brush under running water.
May 24, 2009 | Hotpoint 24 in. HDA2130Z Built-in...
Top Arm does not spin so glasses are not cleaned and detergent is not rinsed out of holder very well.
Make sure the water level is just at or below the heating element. Low water level will cause the pump to "run out of water" before all wash arms and connecting tubing are filled. A pulsing sound during the wash cycle will verify. Low water pressure or a bad water inlet valve are one cause. Water siphoning ou the drain line is another. Look under your sink and verify the drain line goes from the garbage disposal or sink tailpiece all the way up to the bottom side of the coutertop enroute to the dishwasher.
Apr 27, 2009 | Dishwashers
Lower spray arm won't spin
Sounds like you may have put it together wrong. I would just take the arm back off and make sure that it all fits together right. A little tip for you too. Dishwashers will clog up all the time with water deposits and food gunk. There are all those expensive cleaners out on the market but the best and cheapest way to clean them is with white vinegar. Simply pour it into the dishwasher when it is empty and run it on the pots and pans setting on hot. Always make sure to pre heat your water too by running the sink till it starts steaming. This will make it easier for your dishwasher to heat the water. If you don't, then when you turn on the dishwasher it starts to fill with cold water and has to heat it on its own. Run the vinegar though through it at least once a month or so and it will extend the life of the dishwasher. Hope this helps. Just try taking that arm back off though and putting it back together making sure everything is fitting properly. If you have any other questions feel free to ask me. Good luck.
Jan 22, 2009 | Maytag 24 in. MDBS661A Built-in Dishwasher
Dishwasher is filling up but not washing dishes.it will run the programme and also drain the water
Sounds like the washer arm is not rotating around during the wash cycle.. Can you reach in and manually rotate the arm to make sure it is free to spin? Also, it may be washing but the drain filter has so much sediment in it from previous cycles that it is just redistributing that stuff on you dishes.. check the drain filter too... lastly, is the detergent dispenser opening after a wash cycle? If it is empty ( meaning it has been used) the other things mentioned above are probably the issue.. Hope that helps...
Aug 16, 2008 | Dishwashers
Problem selecting programme
hi
sounds like you have a heater problem,check connections on your main module behind control panel if all appear ok check you heater for open curcuit.
Apr 27, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Nov 19, 2006 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashers Logo
170 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
