Question about Electronics - Others
I have a beovision 6 with HDMI connections and a Beosound 2300 with Beolab 2500 speakers attatched via a beolink converter type 1611. Why will the converter not distribute sound from units attached via HDMI?
SOURCE: receiver won't put out sound to LCD Sharp aquos
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Posted on Dec 13, 2007
  • 151 Answers
SOURCE: Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Posted on Jun 29, 2008
  • 15 Answers
SOURCE: Polaroid FLM-3232 Blue Screen 'No Signal'
yeah stay away from polaroid! In the meantime check this out.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Jul 22, 2008
SOURCE: Hum from B&o active speakers
Hi,  You may try to not connect the ground pin of the main cable of Arcam Solo. Using a 2 poles adaptor is the simple way. Try to find hum is still there. And using better RCA cables, like twisted pair, quad wires cable is better. Because, it is long-run (over 2 metre long), EMI and RFI are easy to enter the signal path.
Posted on Mar 27, 2009
JulesPCaut
  • 702 Answers
SOURCE: connect to PC via hdmi-hdmi cabel (3m)& hdmi to DVI converter
First try installing the latest ATI video driver, to make sure the HDMI output is fully supported.
Did you set your TV to select the HDMI input? nothing shows?
Posted on Dec 03, 2010
How I can connect my mac to beolab 2000? is it possible?
Not going to be be possible but you sure do have some nice speakers!. On top of helping people with their computer problems I also write music. Would love to hear myself through these. Anyway The 2000 MUST be connected to the main system only. Its designed to only work with the main system via a MasterLink Cable. Its really simply an extension of your master system and cannot be used for anything else. Hope these helps.
Nov 30, 2014 | Computers & Internet
I have a denon avr-1611 and can get sound playback through my connected speakers (not tv speakers) but no video output from hdmi. I have the receiver connected to a samsung tv. Is there any fix for th
You should check your Denon manual to be sure that the receiver has been set up correctly. My 1913 has many set up options including associating a particular HDMI out connection with a particular source like CBL/SAT or DVD. The fact that you hear sound indicates the HDMI cable connecting the cable box or DVD player to the receiver is working ( at least the sound portion of the HDMI in cable.)
Next, is the HDMI connection you are using to the TV the one selected in the source listing on the TV ? The sound and video circuitry on a receiver are separated and you can hear sound but see no video if the TV isn't selecting the correct source. For example if the TV is set to HDMI1 but you are plugged into HDMI 2. If this doesn't solve your problem try this:
At this point you don't know if the problem is the receiver HDMI connections or TV HDMI connections or a bad HDMI cable. The first thing to try is a new HDMI Cable. If that doesn't solve the problem then do the following.
If the TV has more than one HDMI connection try another HDMI port. Be sure to switch the source on the TV to the new HDMI port ie. HDMI1,HDMI2 or whatever.
If this fixes the problem you are done. If not then Try the same thing with the HDMI out ports on the receiver. Try each one not forgetting to set the receiver to use the HDMI port you are testing.
each time.
Since this can get confusing I would write down what you are testing each time so you don't get lost or confused.
If none of this works then you can try hooking up another TV to the HDMI cable, if you have one. If you do this and you still have a problem it points to the receiver as being the culprit.
The most likely problem is you have misconfigured the system so that is where I started. Each test is dependent on the fact that your system is correctly configured to begin with.
Sep 04, 2014 | Denon AVR-1611 A/V Receiver - 3D - 75 W...
I just bought a Denon AVR 1611. All inputs are HDMI (Cable TV, Blu-Ray) and the monitor output to the TV is HDMI. ainly I listen to the audio out of my TV and occassional on my surround sound. I would...
avatar7.jpgcurt, I bought this Denon AVR 1611 and I have HD cable. If you have cable you can set it up two ways. First way (the way I have it) is to get a switch box with 2 HDMI
out (mine has 4 inputs and 2 outputs) and maybe 2-4 inputs. Put the cable from the wall in one of the switch box inputs. Now hears the cool thing. Put 1 of the outputs from the switch box to the Sat/Cable input on the 1611 then put the another output to your tvs HDMI input. This allows you to switch from the tv only output or the 1611 surround output without touching the switch box. The other way is to buy a converter from HDMI to VGA. The only thing here is that you would have to setup your sound through Aux in the front of the 1611..........Johnmoondancer@hotmail.com
Mar 06, 2011 | Audio Players & Recorders
Hello is there a way to connect a sony 52EX700 to a beosound 3200 system? regards Laurent
You can use the aux out or get yourself a beolink cable.
However the 3200 is not surround sound capable it was designed for audiophile CD enthusiasts, My advice is to get a home theatre system and leave the 3200 for those special music moments.
Aug 14, 2010 | Bang and Olufsen Audio Players & Recorders
Remote code for power on/off for Beosound 1
use the manual off switch on the product or use a beolink 1000 or beo4.
Jan 09, 2010 | Bang and Olufsen Audio Players & Recorders
BeoLab 8000 no sound
try moving the l/r switch, if sp still dead then its an internal sp fault.if it comes to life the fault lies in the cable or unit.
Sep 18, 2009 | Bang and Olufsen BeoSound 2 Companion MP3...
Only Black and White picture is displayed when devices are connected via RCA cables. The picture colors are fine via the Comcast cable connection. What could be the problem and How can it be fixed?
there should be other inputs like S-Video or HDMI. To convert the signal-go to E-BAY and type in "RCA to HDMI"(for example). Got my converter cable there for $5.00 while RADIO SHACK wanted $30.00!
Aug 09, 2009 | Toymax Viore 42 in. Plasma TV
hi , i just saw ur mail although I do not have the solution to this but I am keen to know how you are using these speakers as I too have identical beolab 6000 and beolab 9000. I was thinking of connecting them to a preamp. What do u suggest ? Pls guide
Oct 01, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
Electronics - Others Logo
123 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
