Question about Sony VPLTX70 Projector
Sony VPL-TX70 won't turn on. The on/off button is red and flashes once if pressed.
3 Suggested Answers
Marrie
  • 563 Answers
SOURCE: SOny VPL-EX1 turns on for a few minutes and then the Lamp /Cover LED and Power ON/Standby LED flashes.
Hi David
I think you should replace the lamp.
Posted on Mar 26, 2008
Marrie
  • 563 Answers
SOURCE: Sony VPL-CS1 projector
Hi there
You should first check if there is any visible damage on your lamp. If not then it could be a faulty Ballast ( lamp powersupply )
Sony VPL-ES7 projector boots up after few seconds switches off, with a red light flashing severally on the power button. Please what could be the problem because i have serviced the projector!!!!
Check the fan connections, one might not be connected right if you have just serviced it. Switching off with a flashing red light usually indicates a fan error.
Also is there a sequence to the flashes? e.g, 4 flashes and pause?
some manufacturers have a fault code table for the amount of flashes.
Nov 09, 2016 | Sony VPL-ES7 LCD Projector
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
How to reset sony projector vpl-es2 without remote control cause the panel key is lock?
Turn the projector on and leave in standby mode. To do this press the power on button for 10 seconds until the projector comes on.
To unlock the main panel keys, press the MENU button for 10 seconds.
Aug 05, 2011 | Sony VPL-CS7 Multimedia Projector
I have sony vpl ex7 and the power button keeps on blinking?
If it blinks with 2 flashes, it's overheated. Check the filter unit.
If it blinks with 4 flashes, a fan is not working properly. see if any fan is not turning on, and check why.
If it blinks with 6 flashes, it's a system internal failure.
Jun 28, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
I have a sony SVGA VPL-ES4, when i turn it on it comes on only for a little while then goes off and the power button has this continuos blinking red button. HELP please..
hi,
Do one thing try to reset the lamp hour timer. for the same do the following.
Press the following keys on the remote in the following order for less than 5 seconds each.( on standby mode)
RESET then LEFT ARROW then RIGHT ARROW then ENTER
Remember on thing lamp reset is recommended only after replacing the lamp. if works try to replace the lamp as soon as possible.
ok
Apr 28, 2011 | Sony VPL-ES4 Projector
SONY VPL FX-40 projector. After plug in-ON/Standby LED is red for few seconds and starts flashes in red(repetition rate of 12 flashes). After pressing I/O key-ON/Standby LED flashes in green(few...
A Flashing Red ON/STANDBY LED means one of the following
2 Flashes - The internal temprature is high. Check the air holes are unobstructed.
4 Flashes - The fan is broken
6 Flashes - The internal electrical system has failed.
There is no entry in the manual for 12 red flashes.
Feb 19, 2011 | Sony VPL-FX40 Projector
Sony Projector VPL-VW 10HT 2 problems 1)The
there is a lock on the projector that needs to be removed. check the manual for the code.
Aug 19, 2009 | Sony VPL VW10HT Multimedia Projector
Sony
Turn on projector and Press following button on remote in following order for less then 5 seconds..
RESET, <==, ==>, ENTER.
Above procedure is written in user manual page-49
If you need user manual of VPL-HS50, click Sony Support.
Feb 11, 2009 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Sony VPLTX70 Projector Logo
69 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
