Question about Refrigerators
It stopped cooling yesterday without any warning signs
  • 6,993 Answers
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food
As for the fridge, the same solution but for more details. If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Take care.
Posted on Apr 08, 2011
Where is the engine over heat shut off switch?
Hello - when the engine overheats (and your ignition/key switch) is still functional you basically have two options:
1. Turn the vehicle off at the key (you could also disconnect the negative terminal on the battery - cars aren't the way they used to be - you can't disconnect the cable to see if the alternator is producing the electricity to keep the vehicle going - if you disconnect the battery the car is down for the count with the electrical systems now.
2. If you're driving in a residential area or city (redlight to redlight or stop sign to stop sign) - all that stop and go traffic prevents you from running the vehicle down the road without stopping to get cool air pushing through the radiator. If you're ever in a situation and you have no choice but to drive and the car is overheating/but not blowing the bypass on the cap - you can also get out on the interstate - going those speeds without stopping forces cool air over/through the radiator - helping to cool down the coolant faster. Unless there is a near total meltdown - that will actually help the engine cool faster than just the radiator fan will.
B
Jan 26, 2016 | Cars & Trucks
Hi my peugeot 308 is using more oil than usual and the oil pressure warning sign keeps coming on but no obvious signs of an oil leak
After cooling, check the radiator water for signs of engine oil. Oil can be forced into the water cooling system through faulty seals or gaskets.
Dec 29, 2015 | Peugeot Cars & Trucks
Can it be used without the fan?
If you want to get anymore useful life out of it, stop operating it without the fan.
Aug 18, 2015 | Whirlpool Microwave Ovens
Coolant problems
Check to see if the radiator cooling fan operates when the problem occurs. If the fan doe s not operate, check for a blown fuse in the fan cooling circuit. That the engine does not overheat when idling for long periods seems to indicate the radiator cooling fan operates normally.
If the radiator fan operates normally when the engine is hot, the likely culprit is the engine thermostat, which then should be replaced. Thermostats can fail "closed," their normal position when the engine is cold. When that happens, they will not open to allow adequate coolantr flow as the engine heats up. An idling engine des not require much coolant flow to remain cool as it is not working very hard. When powering the car down the road, excessive heat is trapped in the cooling system and cannot be radiated by the radiator away due to the failed thermostat stuck in its closed position.
May 15, 2014 | Vehicle Parts & Accessories
Smoking from under hood
sounds like a head and or head gasket problem when u overheat u can damage warp head or blow head gasket look at oil if milky look possible getting/having antifreeze leak into oil or if white smoke coming from rear exhaust sign of antifreeze getting into cylinder
May 08, 2013 | 1996 Ford Mustang
Flashing light re temperature in fridge jenn air model
Your freezer may be a fan cooled system. Make sure that nothing is crammed up against the fan grill as this stops the air flow and probably causes the red light warning
Mar 28, 2010 | Refrigerators
Same problem , car has only 86,000 miles
replace that thermostat again...flush radiator any way...then see how it runs...
Aug 28, 2009 | 1996 Cadillac DeVille
Have a Whirlpool refrigerator that has stopped
replace the electronics on the compressor --if you would like more tech diagnosis let me know
Aug 10, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
