Question about Philips 32PFL3403D/27 32 in. LCD TV
The number of the selected programme does is permanently displayed at the left top corner of the screen. I tried to plug out the TV but the problem persists.
  • Philips Master
  • 8,457 Answers
Tries used ur tv remote and go into the tv MENU and tries go down to do a resetting to the tv back to the factory setting to every funsctions,to every funsctions setting of the tv menu of setup setting menus like PICTURE,SETUP,OPTION.By resetting all these menus setting back to the factory settings,tv should have a great chances to get ritting of the permanently dispalyed on the left top corner.
Posted on Apr 08, 2011
When i switch my TV on the light is permanent green but blank screen?
Sounds like a panel fault. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Illustrations to defective screen-shots are given. You can see it, and can make sure about the fault to your TV.
Oct 17, 2013 | Televison & Video
I'd sit the tv's remote and tv's screen remain blue with padlock sign at the lower left corner of the screen and the tv's remote will work only power on/off.no picture
Your TV is locked by anyway. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Unlock procedure to many brand TVs are given in detail.
Oct 12, 2013 | Televison & Video
Horizontal Blocks of blurring on LCD screen
Do a hard reset to this set and try. If it can't help you, visit the site referred here, and see whether it illustrates the fault to your TV. To make a hard reset to the set, unplug it from AC mains wall socket and re-plug it back after 3 minutes or so. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 26, 2012 | Televison & Video
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
My plasma LG TV has a black display box in the top left corner of screen. No words or text in it, just a black box covering that coirner of picture...how do I get rid of it?
There should be a button on your TV remote that will be called "Display" or "P in P".
The display button usually displays which input you have selected, such as: SAT for Satellite; AV1, AV2, AV3 or AV4 - depending on how many inputs your TV has, to plug in devices like a VCR or DVD recorder/player.
Otherwise, if you have a more sophisticated TV, it could be that you have accidentally pressed the "P in P" button, that selects the Picture in Picture mode. If you have done this, your TV will display the main picture of the input you have selected, plus another input, (such as SAT or AV1 or AV2 etc. as I've mentioned above). If the AV1 or AV2, etc. input is not active (not switched on) then that input will only display a blank (black) picture in the top left corner of the screen.
Hope this helps...
Nov 17, 2009 | LG 42PX5D 42 in. Plasma HDTV
Cant get AV1 symbol off top left hand corner of screen
hello on the remote control theres an button with an i symbol try pressing tv then the i button it should clear it
shaun
Oct 15, 2009 | Televison & Video
Channel number display won't turn off
This is a common problem with some cable boxes. Most likely it is not the television. Try to unplug the cable box for about five minutes to allow it to reset. When the cable box reboots it should reset itself. Plug the cable box back in and see if the number is still stuck on the television.
Nov 13, 2008 | Samsung LN-T4671F 46 in. LCD Television
Sony Grand Wega LCD TV, the channel indicator in the top left corner stays on permanently. How can I get it to turn off?
Press Display button on remote, channel indicator (on screen display) will disappear.
Nov 02, 2008 | Televison & Video
Problem with my Goodmans 2065TS
Hi.
Sounds like your tv has gone in to service mode.
Try doing this (BUT DO NOT PRESS ANY OTHER BUTTONS)
  • Select pr. number 91
  • Adjust sharpness to minimum and exit all menus.
  • Quickly press the key sequence : RED - GREEN - menu
  • The software version is displayed beside the word Service, e.g. “ SERVICE V1.00A”.
  • To exit SERVICE menu press menu key or Std By key.
  • http://dysonmanuals.inc.io/
    Oct 26, 2007 | Goodmans 2065TS 20" TV
    Display
    press and hold down the i button on the remote and the screen program number will disappear
    Apr 10, 2007 | Panasonic TX-26LXD1 26 in. LCD Television
    Philips 32PFL3403D/27 32 in. LCD TV Logo
    149 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
