Humming noise when volume is reduced...also, when turning on tv.....how do you get rid of the noise?
    Problem Solver:
  • 10 Answers
Thats the noise you can ignore, it comes from every graphics card...more fast is your card, more is the noise you get (mostly because of fan)
Posted on Apr 23, 2011
How to get rid of water pipe noise at home
This usually occurs with high water pressures.
It may help by installing a water reducing valve at the water meter.
When a dish washer or washing machine turns on and off the water you will get a water hammer noise. The pipe fixings have come loose over time and the pipe bangs against the fixings.
You can reduce this noise by installing a water hammer device on the all the taps and then connecting the hoses from the dishwasher and washing machines to the water hammer devices.
I suggest you check out the best options with a plumber.
Apr 04, 2013 | Dane-Elec DaneElec 4GB USB Drive Copper...
I dont have sound on my laptop
A general case might be to take the stereo headphone output of the laptop and feed it a set of left and right line level (not microphone level) inputs to the soundboard. Radio Shack sells a cable that has a typical mini stereo headphone plug on one end and a pair of RCA Phono plugs on the other end. If the soundboard does not have phono jack inputs you will need some type of adapter plug on the ends of the cable phono plugs to match the soundboard's connector.
You then experiment with the laptop's volume control setting (start low) and the soundboard's input level control to get undistorted sound with minimum noise and hum. If you can not get rid of the hum, you probably need to add a ground loop isolation box (also available from Radio Shack, I believe) to reduce or eliminate the hum. __________________
Sep 20, 2010 | IBM (01K2154) Sound Card
Humming noise when volume over 40
This hum could be from a ground loop or a bad main board in your TV.
1. Try removing all the inputs from the back of the TV.
2. Unplug the TV for about 3 minutes and plug it back in.
3. Turn on the TV and go to HDMI1 input.
4. Turn the volume up to see if you hear the hum.
5. If you hear the hum without any inputs into the TV, then the problem is with your main board, or with the quality of power you have going to your TV (your wall outlet may have an open or bad ground). You can try plugging the TV into a different outlet across the other side of the house (to try a different circuit) to see if your power is the problem.
6. If you don’t hear a hum without any inputs into the TV, then the audio hum is caused from one or more of your inputs.
7. You will have to plug in one input at a time into the TV, and turn up the volume to see if that one input is creating the hum. If the TV hums, then you have a problem with that device and or the cable that connects it to the TV.
8. There is a chance the hum will occur when two or more devices are connected to the TV at the same time. So be careful of this issue. This issue is not the fault of the TV and is a grounding issue between the devices.
I hope this information has helped you.
Good Luck.
May 28, 2010 | LG 32LG30 32 in. LCD HDTV
Acer Aspire One laptop is making a humming noise when I start it
Locate the Microphone from the control panel and reduce or mute the microphone volume.
Control Panel, Harware and sound, Manage audio devices,recording
adjust the Voulme there.
Mar 11, 2010 | Acer Aspire One PC Notebook
Hum from tv
try unplugging any equipment that you have attached to the tv one at a time, such as dvd players, surround sound, cable box, etc. also if you have a cable box attached, try adjusting the volume on it. if you have everything unplugged from tv and it still hums, then it may be a tv issue
Oct 21, 2009 | Televison & Video
Volume making humming noise when on
there is a bad ground.
the hum you are hearing is ac getting into the audio.check all the rca plugs on the set are plugged in all the way.do not run them close to a power bar either.
sometimes a second unit with it's own volume is hooked up to the tv and then the tv volume is up too high because the other box is turned down.if there is a unit hooked up,turn it's volume up ,and the volume on the tv down,otherwise the tv will amplify the residual noise.cheers,ed
Jul 04, 2009 | Proscan 32LB30H LCD TV
Volume noise after warm up
YES! I had this problem and there are others here under humming.
Standing in front of the TV, make your volume zero.
Punch in --very quickly-- 9876
If it worked, it will open a new menu. Go down to the Backlight and enter. Move it up to 83 from 81.
Hit menu twice.
Now try it and see if your hum is gone! [I think I was starting to go deaf trying to hear the volume over the buzz!]
I will warn you to try it a few times. At one point it shut off on me in the middle and if this happens to you, expect the volume to be BLARING when you turn it on again. :-)
Feb 21, 2009 | Proscan 32LA30Q Television
I'm experencings a buzzing noise coming from the speaker when I turn on the tv....How can I get rid of this noise?
Give this a shot, it should fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
Let me know if this works.
Feb 19, 2009 | Proscan 32LB30QD 32 in. LCD TV
Tv makes humming noise when on. how can I eliminate or reduce the nose?
Some of the larger TV's are DISH ready, meaning that they have the tuner inside for SAT TV. The SAT tuners often have an internal fan that makes a humming noise. If it sounds like something other than that, you might have a bad component in your sound circuit that allows 60 HZ hum through the speakers.
If it is a rear projection LCG TV it has a fan in it to cool the bulb. You will hear the fan if you listen closely. It usually cannot be heard over the volume.
The fluorescent bulb and electronics inside make humming sound naturally. Kinda like when you turn on a lamp, and some lamps make a low humming sound.
Apr 03, 2008 | Televison & Video
Humming noise in Harmon Kardon AVR 110
on what cd dvd ? cheak cable 1st rca swap out
Jan 29, 2008 | Audio Players & Recorders
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
