Question about Toshiba Satellite A665-S6086 Laptop
Toshiba Satellite Laptop A665-S6086 came with 4GB of 2x2GB DDR3. Upgraded today to 8GB of 2x4GB DDR3 and went to turn it on, but the lights are on it beeps and then shuts off. Took out battery and AC for a bit and then tried again with same results. Won't stay on and won't display boot sequence. Put back original RAM and same issue. What could have happened and how is this resolved? I am sure the RAM was seated properly as no gold is displayed and there was a click and then are solidly being held.
  • Toshiba Master
  • 16,981 Answers
There is a chance that you ESD and ruined the motherboard. Take all the RAM out and try to boot it and see. Then put one in and boot and then the other. This checks the memory. See if you can get to CMOS setup screen in the bios.
Posted on May 20, 2017
SOURCE: Toshiba satellite a105 s4004 cannot boot
if the recovery disk would not run to load the program than your hard drive is probably bad have you been into the machine and seen the hard drive have a look at the front where the wires plug in and there is a slot for jumpers to select the hard drive function make sure its set for master only. most hhard drives will not have a jumper for master setting if there is a jumper make sure its set right .
Posted on Dec 08, 2007
flipbooks
  • 177 Answers
SOURCE: Toshiba Satellite Laptop Power Failure (A105-S1013 System Unit)
Okay, lets troubleshoot this:
1)Does your laptop run on battery alone ?
yes )test your jacks continuity to the motherboard using a continuity tester or Digital Multimeter.
a)test between the center contact and the motherboard.
b)test between the outside metal cover of the jack ,and the motherboard.
c)If either of these fails continuity,replace the jack.
2)does your laptop now power up on AC ?
yes)Stop
No)Try the BIOS upgrade.
Posted on Feb 10, 2008
  • 45 Answers
SOURCE: Toshiba Satellite A105 no power
try looking at the DC input. My brother's 1st laptop had that same problem. All we need to do is solder it. Remember-1st dc connection, not the one on the MB.
Posted on Aug 19, 2008
  • 11800 Answers
SOURCE: Toshiba x205 Sli1 suddenly died. Got 3 beeps.
3 beeps usually means that either the chipset or the processor is dead. Nothing you can do, take it to a repair shop.
Posted on Nov 06, 2009
RescueTechLA
  • 2653 Answers
SOURCE: Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Posted on Apr 04, 2010
Testimonial: "First step in a series to diagnose. On the journey. Useful thanks."
Toshiba satelite laptop won't poweer up, built in battery.
Built in battery? Why? Did someone glue it in place?
Those batteries are found on the bottom of the Laptop and are easy to replace. You can get them fairly cheap (like $40)
Here's and extended life 95w battery from Amazon
Amazon com Toshiba Satellite A665 S6086 Laptop Battery 95Wh 8800mAh...
Aug 08, 2016 | Toshiba Satellite A665-S6086 Laptop
Why Toshiba Satellite A665 Laptop won't start?
Have you tried pressing space bar (maybe its in hibernation mode) ?
or try holding power button for a few seconds (10) then turn it back on.
as a last resort you could try take the battery out, disconnect it from the power adapter, hold down the power button for 30 seconds and then place the battery back in and the power adapter and try powering it on?
Aug 26, 2014 | Toshiba Satellite A665-S6088 16 Notebook...
Plugged in, not charging
1. Check charger, probably you should get checkes at some repair shop because need an electronic tester
2. Check memory
Jan 29, 2014 | Black Diamond Memory 8GB 2X4GB RAM Memory...
Toshiba satellite a665 does not recognize lg phone, it states there are missing drivers.
try having your laptop connected to the internet before connecting the phone. Most of the time the laptop will download any and all drivers to recognize the phone.
Oct 06, 2011 | Toshiba Satellite A665-S6086 Laptop
I need driver software for lab top toshiba satellite a665/s6086
all toshiba satellite A665-s6086 drivers: --->click here<----
and watch the video
May 19, 2011 | Toshiba Satellite A665-S6086 Laptop
How and where to download all drivers for toshiba a665-s6093 after reinstall the os with windows 7 64 bit some of fitur like hot key and etc not working properly....pls need help asap !! thanks
Hi
Go the website of the manufacture, choose your laptop model (
Satellite A665-S6093), and the operating system ( 7-64bit),
and download the software utility for the keyboard
Please tell us your results
Good Luck
May 16, 2011 | Toshiba Satellite A665-S6093 Laptop
Hp touchsmart 600 memory upgrade. We have ordered (2) 4 gb memory upgrades for this machine. As far as we can tell the machine only has two slots for memory upgrades and the most recent items sent were (2)...
Maximum RAM supported by this system is 2x4GB PC3-10600 200 pin, DDR3 SO-DIMMs modules.
2x2GB is standard factory RAM. Call back the seller and get a replacement(2x4GB).
Jul 19, 2010 | Computers & Internet
Toshiba Satellite A665-S6086 Laptop Logo
116 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
