Question about Maytag MAH2400A Front Load Washer
Where is the drain pump of the maytag mah-24? I have drain issues and cannot get to the drain to unclog it.
    Brigadier General:
  • 6,277 Answers
Here are my complete guidance notes for checking both the drain motor filter and the drain motor on washing machines in general;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 08, 2011
How do you clean out the drain pump maytag centennial washer
Maytag & Whirlpool & Kenmore Washer Pump Repair ...
? 3:44
https://www.youtube.com/watch?v=97rBObh_3mQ
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Repair your own Maytag Top Load Washer which has the following ... Took me awhile to unclog as an entire ...
Washer Won't Drain - Pump Clogged with Sock - Repair ...
? 1:53
https://www.youtube.com/watch?v=tHT7PmmFc9w
Dec 2, 2011 - Uploaded by Tomahawk DIY
Washing machine pump clogged with a sock. ... I searched hi and low trying to figure out why my washing ...
HE Maytag Centennial Washer Fix - YouTube
? 31:43
https://www.youtube.com/watch?v=CoTlOr3Gxuk
Nov 15, 2013 - Uploaded by mike3000ace1
So how do you open the washer to pull out the Manual? .... +mike3000ace1 Hi, I have a 2011 Maytag ...
Maytag Centennial Washer Drain, Transmission ...
Jan 05, 2016 | Maytag Washing Machines
I have a Maytag MAH-24 Washing Machine showing a 5E error code
You will have to contact Maytag and speak to their service dept and give them your model number. Ask them what a 5E eror is and when you call for service, tell the repair facility what Maytag told you. That will next to eliminate labor cost for Diagnostic.
Apr 17, 2012 | Maytag Washing Machines
My maytag washer mah-24 have a "nd" msg. which mean "not draining" and now i cannot open the door to take the clothes out. pls. help.
Unlocking the door:
Turn on the washer, but don't start any wash cycles. After a few minutes, the door should unlock itself.
Troubleshooting the "nd" message:
"nd" means "no drain". Empty the (now unlocked) washer and fill the wash tub with just enough water to see a bit of water at the bottom of the tub. Run a drain cycle and check a) if it drains and b) if there are any unusual noises while it is draining. If either event occurs during the drain cycle, the drain pump may have to be repaired/replaced.
Nov 25, 2010 | Maytag MAH2400A Front Load Washer
ND Error code
Error code "nd" means it is not draining. Click on this link to get the user manual:
http://laundry.manualsonline.com/manuals/mfg/maytag/mah24.html
Then click on "GET THIS MANUAL" to download the manual.
Not draining can be caused by the controller, pump, solenoid valve, or clogged drain.
If this information was useful, please select YES to the first to rating questios. Good Luck and thank you!
Oct 22, 2009 | Maytag MAH2400A Front Load Washer
Maytag Neptune MAH 3 will not drain
usually with this model
you have something clogging the pump
if u unplg it take it out
take off the back
the pump is right there
disconnect the hoses
you might just find a quarter
Oct 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag washer MAH 5500bww seems to run OK, but it does not pump out all the water(pumps out some) at the end of the cycles, churns remaining water during spin
Open the rear panel and remove the drain pump and clean it.
If there is nothing in the pump, check the drain motor for 18 ohms with a volt/ohm meter.
Not 18 ohms, replace the motor.
May 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH 24 does not drain and makes weird humming noise
i also have this problem. to get the door to unlock, just unplug the washer and it should open in a min or two. you will hear a click. you may have a mini flood but at least you can get your cloths out and bail out the water. my problem started when i began using a new detergent from Tide called total care. Still tying to get the pump to work.
Jan 25, 2009 | Maytag MAH2400A Front Load Washer
Unlisted error code on MAH-24 Maytag front-loading washer
Did you connect the wires back to the pump. The neutral runs through the pump winding and to the door interlock. Check the connections on the drain pump and the harness in general. Sounds like a broken connection somewhere.
Nov 05, 2007 | Maytag MAH2400A Front Load Washer
HOW DO I GET TO THE PUMP TO UNCLOG IT
siphon to drain the water then flip the washer sideway and locate the motor cuopling or broken belt and change this to a new one
Jan 07, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH2400A Front Load Washer Logo
191 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
