I have HP Cue status all the time on start up. How can I repare it. I have a Win. XP and a HP C 4180. Please help me stop it. Thank you. Lorne Longley
  • dlongley Aug 06, 2008
    I did all that you said but still the problem is there.
    I will next uninstall the HP program and reinstall later to night.
    What do you say ?
  • 876 Answers
Go to Start>Control Panel>Printers and faxes
double click on your printer
You will get a little window that says at the top use printer offline
Choose print at the top menu and then in the pull down menu choose cancel all documents.
That should work. If it does not, then try resetting your printer by unplugging it at the back and leaving it off for a while, then reattach cords and see what you have then.
I hope this helps.
Posted on Aug 06, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 06, 2008
    When you go to the printers folder, does it show more than one printer?
Print jobs stuck in cue
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Jun 25, 2010 | HP LaserJet 8500 Color Printer
HP D1460 only prints when computer is restated on XP
click on start click on run in open box type
net stop spooler. then hit enter.
then type net start spooler. and hit enter repeat above steps 3 4 times. net stop spooler then net start spooler. at the end make sure spooler shud be started. then restart computer.
Dec 16, 2009 | HP Office Equipment & Supplies
Hp cue status root has stopped working
click on the start button go to start search bar and type services.msc and hit enter now a window will open look for hp cue in that and check status it should be started and automatic not mannual or automatic delayed if its started then there is a problem with the cue version of the hp software
now try downloading the driver through the link and reinstall the software〈=en&cc=us
Jul 10, 2009 | HP Deskjet D1455 InkJet Printer
Hp CUE Status Root has stopped working ERROR
You should try using Windows Restore. Restore the computer back to when it worked correctly. Then try downloading the latest software for your scanner, etc. from the appropriate websites. i.e.
That's probably the easiest way to do it.
Feb 20, 2009 | HP Pavilion dv9700t Notebook PC
i had this prob. the "hp cue root " error isnt a hp thing, its a microsoft thing. i beleive it was caused by installing a older model printer AFTER installing a newer model. (i had a hp 2500 series,then installed drivers for a hp 1400 series)
just go to control panel, then "programs and features" , then uninstall everything that is assoiated with the printer your no longer using. just deleating the older printer from the "printers" folder won't do it. (this is assuming that you dont need both printers)
I havent gotten the error message since i did this. besides, its a good rule of thumb to not have drivers that you dont need on your machine anyways.
hope it helps
Feb 07, 2009 | HP Pavilion dv6000z Notebook
HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Dec 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Prints everything but word & pdf documents!!!!
right click on printer , click on properties, click on compatibility tab tick box , highlight the win system you are using , apply and ok
google -- downloads for hp4180 --find the download and drivers for your model suitable for the win operating system , download and run
Nov 19, 2017 | HP Photosmart 4180 All-in-One Printer
I need hp cue status patch plz
please i have vista and a message hp cue status
Dec 01, 2008 | Office Equipment & Supplies
HP Pavillion a1220n stopped printing
Most companies don't offer driver support for XP anymore, it's 2017, time to upgrade to atleast Windows 7 now.
Mar 21, 2017 | HP Pavilion a800n (PP163AA) PC Desktop
HP 4180 printer
Try the resetting the printer to factory defaults.
1.Turn the Printer OFF, unplug the power cabled from the back of the printer and from the wall outlet.
2.Then, Press and hold the ON button for 30 -60 seconds
3.Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold CANCEL and COLOR COPY button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Please let me know, the status. GoodLuck cheers!!
Thank you ...
Feb 11, 2008 | HP Photosmart 4180 All-in-One Printer
Computers & Internet Logo
David Payne
David Payne
