Question about Sony Playstation 3 (PS3) Console
My ps3 powers on for 2 seconds then turns off
    President:
  • 1,139 Answers
Hi there, unfortunately this is what is commonly known as the Yellow Light Of Death (YLOD). When the PS3 was originally made Sony used lead free solder in their consoles. Lead free solder is not as flexible as normal leaded solder and over time due to expansion and contraction because of heat given off by the console's components hairline cracks formed in the solder joints between the CPU and GPU and lots of PS3's failed. You have got a couple of options, you can either have the console professionally repaired which is going to cost around £50. If the console is out of warranty Sony will only replace it for a cost of around £130. As a last resort if you are good with electrical items you might want to have a go at repairing it yourself. If you google YLOD you will find plenty of guides that will instruct you on how you can repair it yourself.
Please bear in mind that once a console has the YLOD there is NO guarantee as to how long a repair will last, it could be a couple of hours to a couple of years
Hope this helps and thank you for using FixYa
Posted on Apr 08, 2011
Hooking up my ps3 using HDMI cord to my olevia 232-S13 and it says invalid format
Setting up your HDMI cable on your PS3 games console
1: Turn on your TV and set its input to HDMI.
2: Make sure your PS3 is connected via a HDMI cable.
3: Power on your PS3 and press and hold the power button for approx. 5 seconds, you will hear the PS3 start to beep, release the power button after the second beep.
4: Your PS3 should automatically configure itself for HDMI video and Audio output.
Jun 28, 2015 | Olevia Televison & Video
I need to know how to reset the ps3 to work with an av cable after using hdmi
Hi there, please do the following -
1. Turn the PS3 off into standby (red light on)
2. Press and hold the power button for 2 beeps (the first beep will be when you first touch it, then the second will be about 5 seconds later)
3. Let go of the power button after you hear the second beep.
That's it!
Hope this helps
Jan 14, 2011 | Sony Playstation 3 (PS3) Console
My ps3 won't get to the main menu when I turn it on
Ok, follow these steps to fix your PS3, unfortunately you will lose your save game data!!
Step 1. Turn your PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep once more and turn off. Release the power button.
Step 3. Press and hold the power button. It will beep when you first press it, beep 5 seconds later and then there will be 2 quick beeps together. Release the power button when you hear these 2 beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then go onto the next step.
Step 5. A menu will load. Select option 5 "Restore PS3 system". The console will ask you if you are sure, just accept and then the PS3 will restart. All the original software will be loaded and you will need to enter the date and time and other details.
When you have done all this your PS3 should be fully working again.
Aug 27, 2010 | Sony Playstation 3 (PS3) Console
I turn on my ps3 and there is no menu when it comes on. just a blue screen where the menu should be.
This is because the PS3 software has become corrupted. Follow these steps to fix it but be warned, you will lose your saved data!
1. Turn the PS3 off into standby (Red light on)
2. Press and hold the power button, it will beep as soon as you press it, then again 5 seconds later then once more and turn off. Release the power button when the PS3 turns off.
3. Press and hold the power button again. It will beep as soon as you press it, then again 5 seconds later, then it will beep twice quickly. Let go of the power button when you hear the 2 beeps.
4. The console will now boot into the recovery menu. Do as the screen tells you and connect a controller up via a USB cable and press the PS button.
5. On the next screen choose option 5, "Restore PS3 system". This will then reinstall the PS3 software and cure your problem.
Hope this helps
Aug 10, 2010 | Sony Playstation 3 (PS3) Console
I turned on my ps3 and nothing is happening it is not giving me the option to sign in or anything. just the blue backround nothing else and now it wont let me turn it off.
Sounds like you PS3 software has become corrupt. Follow these steps to sort it but I must warn you, you will lose all your save games!!
Step 1. Turn the PS3 onto standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again 5 seconds later then beep once more and turn off. Release the power button when it turns off.
Step 3. Press and hold the power button again. It will beep as soon as you press it, then beep again 5 seconds later, then there will be 2 quick beeps together. As soon as you hear the two beeps let go of the power button.
Step 4. Your PS3 will now boot into recovery mode. Connect you controller via USB when asked and press the PS button.
Step 5. Select option 5 from the recovery menu, "Restore PS3 system". This will rewrite your PS3 software and hopefully should sort your problem.
Aug 08, 2010 | Sony Playstation 3 (PS3) Console
It doesnt work
hello Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
regards
shaun
Jul 29, 2010 | Sony Playstation 3 (PS3) Console
How to fix ps3 when light flashes green,yellow, then red
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.hello
regards
shaun
My son was playing his PS3 for an hour or so. I went and turned it off for him when he decided to leave the room. I pushed the ON/OFF button (on the left side of the TV) and realized I had the remote...
1 - Turn on TV and set input to port being used.
Jun 15, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
I turn on my ps3 it turns off straight away and the red light flashes and its not overheated....????
If that doesn't work then that means either the power supply is bad or the mainboard is bad.
May 31, 2010 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
