Question about Canon MP560 All-In-One InkJet Printer
New cartridges installed, but black comes out as grey
Black toner replaced; now all black printing comes out faded grey
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 02, 2010 | Dell 1320c Laser Printer
Samsung CLP-300 Printer not printing black well
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It's best to do this each time you install a new cartridge. get more information and help from here .
Jan 10, 2010 | Samsung CLP 300 Laser Printer
Epson rx700, the black prints grey
replace another black cartridge the cartridge is factory defect
Nov 03, 2009 | Epson Stylus Photo RX700 All-In-One InkJet...
How to install Delta T17030 Innovations Collection Single Handle Tub/Shower Trim Chrome by my self
http://www.deltafaucet.com/media/Product_Tech_Docs/Maint_Installation/50001to80000/51975RevE_13943.pdf
New Install:
1. Shut off the water.
2. Remove Plastic rough-in spacer. It's black and it's only there for roughing in, and so the tilers don't come too close.
3. Unscrew silver retaining nut - should only be hand tight. Remove and discard grey cap that was being held is place by nut. Remove and discard plastic stopper inside faucet.
4. Take grey plastic disk off of cartridge and DO NOT THROW AWAY. Adjust gearing/splines to hottest temp by rotating plastic insert. Reinstall plastic disk.
5. Install cartridge with HOT lettering to LEFT. Secure with Silver Nut.
6. Slide large O-Ring over silver nut.
7. Install trim plate using long phillips(star) screws provided (2)
8. Slide Plastic spacer (looks like a snowflake) into chrome trim (cylinder) and slide cylinder over Silver Nut.
9. Install handle by tightening allen screw until it engages firmly with cartridge.
Changing Existing Trim:
As Above Except Old Trim Must Be Removed First. Cartridges Are Specific To Certain Trims. Even More So If Installation Is Over 3 Years Old. 3 Years Ago, Delta Went To The "Universal Rough-In" Which Made Things A Little Easier Because The Appropriate Cartidge Now Comes With The Appropriate Trim.
Sep 08, 2009 | Delta Plumbing
Epson pro 4800 r prints grey not blank and says to set cartridge
I am having the same problem If anyone has an answer or whether judy you have found an answer.
If I do a greyscale strip to print my black is coming out as a dark grey. the bead off of the greyscale strip would appear that the pbk photo black is not actually printing.
This has been a problem for a few months but as I haven't been doing much printing didn't notice it just thought something was odd. Now I look at previous prints and the blacks are black I print it out now and it is a dark dark grey. Nothing has changed in my profiles or my workflow. I have tried hours of profile paper printing option changes and workflow adjustments but nothing changes, If I print 100 percent black from a file it comes out 95% grey I have tried it from three computers to clarify. It appears is a 4800 problem.
Perhaps it is not recognising that it is a PB catridge.
I have no idea.
I have tried adjusting the settings from the printer but there is no option to clarify catridge from the printer.
This is odd, if anyone has any idea.
Mar 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Not printing black
Everytime you install a new cartridge, you should print a test page which will allow the printer to auto adjust to the target print.
May 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Prints grey not black
I solved this problem but probably not what the printer manufacturer would recommend! The reason you are just getting grey is that the black ink cartridge is either empty or dried out from non use and only the color cartridge is working. I had the same problem after being away for 5 months. I put the printer cartridge in a bowl of warm water to disolve the dried out ink on the print pad. I dried off the cartridge with a soft cloth and then it worked perfectly.
Feb 25, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Canon MP560 All-In-One InkJet Printer Logo
old marine
old marine
