I have video tape recorder grundig xeria 65 and I cannot make it play its showing tracking every time I push play
SOURCE: tapes keep getting stuck
we have 4 of the decks. they will often fail to unload panasonic and maxell tapes, i think its due to the design of the reel bases. sony tapes always work fine, they are flat where the others have a groove.
Posted on Nov 27, 2006
SOURCE: VHS tracking
The tracking control is on the remote or you can try the channel up & down on the remote.
nuch
Posted on Dec 21, 2007
ctf1800
  • 4402 Answers
SOURCE: Video Tape picture shakes horizontally
needs tape path alignment or cleaning done
Posted on Jan 15, 2008
SOURCE: Tracking adjustment
have you tried the following >
1)Get a head cleaner for the Vhs and run it
2) the next tim e you put in a casette it should adjust the tracking automatically you will see it on the screen as it is adjusting.
Posted on Oct 15, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Handycam DCR-TRV460 Digital-8
Camera has dirty / clogged video head.
Use good quality video head cleaning cassette.
Posted on Oct 25, 2008
Hi, I have a sony tvr 140E. When I try to play back a tape that was recorded from another digital 8 camcorder I get blue screen. when I play back a tape recorded on my camcorder plays fine. Any...
This smacks of the same problem that the old VCR's used to have. One of you are out of sync. The tape records on a portion of the tape in a sort of straight line track. Think of it as your track is down 1/16" from the top. The other camera tracks it's video down 1/8" instead. That's why in playback it can't read it. The only cure is a realignment. Nimsgame
Feb 19, 2011 | Sony Handycam DCR-TRV460 Digital Camcorder
When playing a vhs tape the pics jump half way through watching. trying to record these old family tapes to dvd. is there a type of vcr i can buy to manually fix tracking or is there another way to solve...
There are two reasons that might cause loss of tracking halfway into a video tape. The first means you can't really do a lot about it. To check it is this is simple. When you get to the point the video jumps, stop the VCR and eject the tape. The look at the tape itself by lifting the flap at the front (push the small catch on the right side). Examine the section of the tape. If you see any damage to the tape (it should look smooth and shine) then it will never track properly.
Another cause of the jumping is caused by the take up reel, getting sluggish. Sometimes these are run off a belt, that becomes slack, replacing it could solve the problem, or it could be something else in the mechanism that's causing it.
There is another solution, particularly if the tape wasn't recorded on the machine that is playing it back. I haved used loads of different VCR's and I found that the tracking has never been set up right on any! This means that only the VCR it was recorded on generally gives the most correct playback.
Having said that it is possible to get a VCR with really good tracking. I have found that Panansonic VCR's have the best tracking. I currently have a NV-HS900 which can track just about everything, but you will only get one seconed-hand now.
Apr 07, 2010 | Televison & Video
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Play back/recording of tapes
check the conections if some where loose.
Aug 25, 2008 | Audio Players & Recorders
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
Blocks of noise
Don't know about the slow motion, but the noise is usually from dirty heads. Just like a cassette player it needs them cleaned periodically. Dip a Q-tip in rubbing alcohol and rub over the entire path the tape takes. You'll see a little block that actually reads the tape. Thats what you need to clean.
Make sure you eject the tape and remove the battery while the tape drive is open to clean it. Rubbing alcohol dries fast but give it an extra ten minutes and check it again.
Video recorder while the heads were dirty will not change however new video should be clean.
You may also have a bent tape carrier that is putting your video off track. It needs to be pushed or pulled to realign it.
It it's not the cause though, this can make playing back the earlier tapes more difficult since they will read and record in a slightly different part of the tape.
Jul 10, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Oct 15, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Vcr tape problem
It sounds like the tracking information is being lost for brief periods of time. Tracking is recorded at the lower edge of the tape, and if the tape is wrinkled or otherwise damaged in this area, playback will go out to lunch. A visual check of the tape would be in order. Have the heads been cleaned in these machines? This would be another area to check.... Also, there could be small differences in the tape path alignments, perhaps the control/audio head alignment is slightly different between the 2 machines.
Apr 28, 2007 | Panasonic AG-1980 S-VHS VCR
My camcorder not playing back
First, try head cleaning by trained technician. Tech will clean manually with cleaning chemical each head to make sure video heads are performing 100%. Otherwise, they will probably quotes you for tracking adjustment. Head cleaning is typically around $25-50. Tracking adjustment might cost you around $100-200 in US depending on service time.
Mar 17, 2007 | Panasonic Palmcorder PV-GS14 Mini DV...
29 people viewed this question
k24674
jasbo
jasbo
