Question about ParkerVision SIGNALMAX WR1500 (884181000031) Router
Real simple question...about turning off the "Wireless LAN" option on my WR1500
This question should be a piece of cake for someone who's a little bit more tech savvy than I am.
I have a ParkerVision WR1500 router that sits about 3 feet away from me. I don't need the wireless part of it...since I only use it to network 3 nearby computers via Ethernet cables.
I know this ****** is one high-powered router...blasting signals up to a mile away. Since I work right by the router all day...I'm not too fond of the idea of it blasting radio waves into my brain.
I've gone into the control panel and unchecked "Enable Wireless LAN" it shouldn't be transmitting anything.
Here's my question...
When I unchecked that box and "turned off" the Wireless LAN option...have I TOTALLY DISABLED any radio waves coming from this router? it still blasting out radio waves...just with no information or identification going forth?
Call me paranoid...I just don't want to be sitting here all day...having my brain cells "cooked" by radiation from a ultra-powerful router.
Like I said...this question is probably a piece of cake for someone with a little bit more tech savvy than me.
Thanks in advance for any help!
  • JonEklof Aug 06, 2008
    Hmmm...I checked the WLAN light...and sure enough, it was still flashing. Strange. Even though the WLAN is supposed to be turned off...
    I just might have to replace this router with a wired one.
    Problem Solver:
  • 13 Answers
The ParkerVision wireless products achieve their higher range by more efficient processing of the received signal. There is an FCC maximum power limit that all wireless products must honor. The ParkerVision router does not radiate any more power than any other 802.11b wireless router.
Posted on Mar 15, 2009
  • 3 Answers
The unit is made up of two boards. the main board is the router, on the underside is the wireless board. you can remove the wireless board and the router will still function
Posted on Oct 10, 2008
  • 173 Answers
It should, well to make sure that it isn't there's an LED indicator on your router that say's wireless or WLAN, since you've unchecked the feature on the router that say's Enable WLAN it should only work as a wired router and would not transmit or broacast any signal.
hope this answers your question regarding the router's wireless trasnmission.
Posted on Aug 06, 2008
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
I have a unstable linksys WAG200G what can I do
Converting A Router To A Switch The five steps are:
  1. [Optional] Put a piece of electric tape over the WAN port so it doesn't get used.
  2. Disable the DHCP server.
  3. Change the downstream router's LAN IP.
  4. [Optional] Turn off the wireless radio on the downstream router.
  5. Connect an Ethernet cable from a LAN port on the upstream router to a LAN port on the downstream router.
Step 1: Putting a piece of electric tape over the WAN port isn't necessary. But it is a good way to prevent future problems caused by someone plugging a device into that port.
Step 2: Log into the downstream router, look for the DHCP configuration section, and disable the DHCP server. For example, on a Dlink DI-614+, DHCP server configuration is a menu in the Home configuration section.
Step 3: Change the downstream router's LAN IP to an unused IP in the same subnet as the upstream router. Log into the upstream router and find the DHCP server controls. Figure 3 shows a typical set of DHCP server controls. You can see that - 250 is the range of addresses that will be issued by this router's DHCP server.
You can use any IP address outside (above or below) this range, except for 0 and 255, which are reserved. You also can't use the IP address used by the upstream router. This is usually 1, which in this case is But if you log into your upstream router's admin screens using an IP address with anything other than 1 as the last octet, i.e. XXX.XXX.XXX.1, then just don't use that address.
Thus, a safe LAN IP address for the downstream router that isn't used by the upstream router is an address from to So I assigned my downstream router a LAN IP of (Figure 4).
Step 4: [Wireless routers only] Disable the downstream router's wireless function. It doesn't hurt to unscrew the antennas from the downstream router as well if they are detachable. This gets them out of the way since you aren't using them anymore. Figure 5 shows the wireless disabled for a D-Link DGL-4300.
Step 5: Connect the downstream router. Run an Ethernet cable from a LAN port on the upstream router to a LAN port on the downstream router. The LAN ports are the ports that often grouped together and not labeled as WAN or Internet.
If you need more help post back!
Thumbs and testimonial are welcome!
Feb 23, 2011 | Linksys WAG200G Router
How do I secure my parkervision wr1500 router
You need to log into the wireless router either by a computer that successfully connects wirelessly or by physically connecting with an ethernet cable. Once connected, log into the router by open a web browser (Internet Explorer, Mozilla Firefox, Google Chrome, Apple Safari), and typing the router's address (usually or into the Address (or URL) line. The default usernameand password is usually "admin" & "admin" or "admin" & "password". Once successfully logged in, look for a tab or link that says "Wireless" or "Security". You'll be able to change whether security is enabled or disabled, and the password associated with it. Your security options are WEP or WPA (or WPA-PSK). WPA-PSK is the most secure, but WEP is also an acceptable choice. Select the security option of your choice and either enter text into the passphrase generator or choose your own password and type it into one of the security key text fields. If you use a password that is not a plain english combination of letters and numbers, be sure to write it down so that you can enter it as needed on other wireless devices that need to access your router (ie-pda phones, game consoles, laptops, desktops, etc). Be sure to save changes so that the security settings and password is saved.
Let me know how you make out.
May 14, 2010 | ParkerVision SignalMAX WR1500 / SignalMAX...
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here
for step by step instructions
Mar 24, 2010 | ParkerVision SignalMAX WR1500 / SignalMAX...
I cant get my labtop to detect a wireless connection
Make sure your wireless it turned on at your computer.
Dec 24, 2009 | Dell Latitude D600 Notebook
ParkerVision Signalmax WR1500
from the original docs:
Reset Button
The WR1500 Wireless Router reset button is built into the rear panel. Use this button to restore the factory default password to 1234; IP address to, subnet mask to and DHCP sever enabled with a pool of 8 IP addresses starting at
note my unit resets to ip
Sep 29, 2008 | ParkerVision SIGNALMAX WR1500...
Wireless speed
First you need to check what is the standard of your wireless adapter that is installed on your computer(to check this well you need to grab the manual or check the specification of the computer or adapter) if it's wireless b 802.11b the maximum speed that you'll be getting is 11Mbps regardless if your router supports N standard 802.11n which can get you through a maximum of 230 to 280Mbps tops.
Second, check the wireless settings of your router make sure that the wireless mode is set to auto or mixed.
Jul 04, 2008 | ParkerVision SIGNALMAX WR1500...
MacBook Pro/ ParkerVision SIGNALMAX WR1500/ Compatability?
It looks like the product is no longer supported by ParkerVision and no Mac driver was ever produced. The device you mention uses proprietary technology to get the performance you are seeing.
I would bet that it would be easier to replace your router with a new one that uses industry standards that all platforms support.
Mar 26, 2008 | Apple MacBook Pro Notebook
ParkerVision SIGNALMAX WR1500 (884181000031) Router Logo
267 people viewed this question
Top ParkerVision Computers & Internet Experts
Aris C.
Aris C.
Folusho Adeyanju
Folusho Adeyanju
Larry Maranto
Are you a ParkerVision Computer and Internet Expert? Answer questions, earn points and help others
