Question about Whirlpool 3.2 cu. ft. Plus Washer
Doster1@hotmail.comfill cycle didn't shut off and overflowed over the top of the machine and down into the basement
    Brigadier General:
  • 6,277 Answers
This is possibly symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else like the control board ;-0(
Good luck,
John C
Posted on Apr 08, 2011
When furnace cycles on the humidifier overflow spout has a tremendous flow of water that pours all over basement floor. Is there a valve problem ? I can connect a drain tube from this overflow spout to the...
If the water stops when the heater is not running then the humidifier is working fine. I know it seems like alot of water but that's how it's designed.
Jan 02, 2010 | Aprilaire 550 Humidifier
I have a kenmore model 110 and it is overfilling the water doesn't stop and it overflows, flooding my basement.
Pull the top of your washer off, look on the tub and you will see a round plastic reservoir. You will see a plastic tube come out and to to the control panel. Make sure that hose is attached at the tub and the pressure sensor.
Sep 13, 2009 | Washing Machines
Water overflowing - GE wvsr1060a1ww top loading washer
since the water stops running in and goes to the agitation mode when you blow on the tube, it is more than likely the pressure switch - one thing to check though, put it in the fill cycle [with water running in] and unplug the power cord. the water should stop running in. if it doesn't, the fill valve is sticking open and should be replaced
Aug 16, 2009 | GE Washing Machines
Water won't shut off during wash/rinse cycles & overflows
the clear tube going from the tub to the pressure switch probably came undone or has a hole in it
Apr 24, 2009 | Washing Machines
Tub overflow
Remove the hose from the water level switch and blow air through it.
The water level switch air hose has a clog in it.
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
MAGIC CHEF 5 YRS OLD WONT AGITATE
Ours started doing the very same thing. I took the top off and found that a mouse had chewed a hole in the vacuum tube. I replaced it with a 3/16" ID small engine gas line hose I bought at local implement dealer. Works like a charm.
tjn
Jul 23, 2008 | Magic Chef CAV2000AWW Top Load Washer
Washer does not stop filling and it overflows!
check the pressure switch tube connectiong to the tub for a hole or crack first
Apr 23, 2008 | Maytag Performa LAT2500A
Washing machine filling
turn the power off if the water stops it most likley a pressure switch problem or the pressure tube on the side of the outer tank may have pulled off.if you turn the power off and the water doesnt stop then the valve is faulty (cold)if it was on the rinse.hope this helps.
Mar 17, 2008 | Admiral AW22 Top Load Washer
Whirlpool 3.2 cu. ft. Plus Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
