Question about Equator EZ 3600 CEE Front Load Washer / Dryer
Excessive shaking at start of spin cycle - Equator EZ 3600 CEE Front Load Washer / Dryer
    Scholar:
  • 96 Answers
I have the same prob with mine when the electricity is dim. Also when the clothes in it are put in unevenly and when only a bit or very large amount of clothes is put in. shuffle the clothes about, or put in some more clothes/ remove some clothes. that might fix it.
Posted on Apr 08, 2011
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet mod#ghw9160pwo washer shakes the whole house during spin cycle. shocks look good, springs look good and adjustable feet are tight and on floor. the washer is level and i get no alarm...
Unit probably has bad main shaft and bearings. Worn bearings will cause excessive shaking on spin cycle. The shaft, bearings and seal will have to be replaced. Also if you grab the tub by the top and shake it up and down, it will have a little play in it. That will confirm bad tub shaft bearings. It's a pretty big job for a DIY.
Dec 10, 2017 | Whirlpool Washing Machines
Excesive Shaking during spin cycle
Your washer has self adjusting rear legs . Tilt the machine foreward and look at the back legs . If one is stuck in , use a screwdrive and pry it out till both legs are in the out position . Set washer back down slowly and the rear legs will automatically adjust .
May 02, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Excessive shaking during spin final cycle
check to see if the floor is solid and not soft, thin or flexible. are the leveling legs tight? make sure the locking nut is tight and that the leg does not wobble.
Dec 23, 2009 | Maytag Washing Machines
Excessive shaking
your suspension dampers is damaged on washing machine causing bad balance on spin cycle..
Mar 03, 2009 | LG WM2277HSW XL Front Load Stackable...
Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Feb 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Excessive vibrations
I have ordered KE shake away pads. I'll have to see how they work.
Jul 01, 2008 | GE Washing Machines
Sqweak wile spinning with excessive shaking for maytag top loader model # sav5910aww
if the squeek is at the end of the spin cycle then there is rust accumalation on the brake pad, it can be fixed but it has to be dissasembled to do it
Apr 13, 2008 | Washing Machines
Equator EZ 3600 CEE Front Load Washer / Dryer Logo
70 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
