Clunking noise when compressor shuts off
I have a brand new Carrier a/c 24ACA. It seems to work well, quiet when it turns on and while its running. I'm concerned because often (not every time but most of the time) the unit makes a pretty loud clunking noise as it shuts down. Its pretty annoying as the unit isn't too far from a window in the kitchen. The a/c technician said it was typical of a "scroll compressor"
  • 876 Answers
For another opinion, you can ask a tech online at:
http://www.robertsservice.com/webapp/GetPage?pid=173
Posted on Aug 06, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 06, 2008
    Wonderful I hope you'll rate my solution!
    Master:
  • 623 Answers
The technician was right....thank you!!!
SOURCE:
Noisy scroll pump in Bryant air conditioner when shutting down. Is this clunking noise normal?
this noise is 100% normal and follows the turning on or off of most scroll compressors in all brands
Aug 16, 2010 | Heating & Cooling
Tip
Refrigerator Clunking in back
<p>There have been many questions asked on <b>FixYa.com</b> about a <b>refrigerator</b> that has a <b>clunking</b> sound from the back of the unit. I will explain what is happening and why it is happening.<br /> <p><br /> <p>The <b>refrigeration system</b> that cools your <b>refrigerator/freezer</b> is run by a motor in a can that is enclosed with a small compressor. This<b> motor/compressor combination</b> is what turns the refrigeration gases back into a <b>high pressure gas</b> and is then cooled to a liquid. This liquid then expands and gets very cold which cools the inside of the box. That is a very simplified view of how a refrigerator works.<br /> <p><br /> <p>Now the motor that runs the <b>compressor</b> has a strong twisting <b>torque</b> (motion) when starting or stopping. To keep the unit quiet when starting and stopping the <b>compressor is mounted on rubber.</b> This allows just a bit of a twisting movement without causing a lot of noise. Sometimes the compressor is just setting down over pins with spring clips to hold it on, and other times they are actually bolted down with rubber bushings between the compressor and the base to cushion the compressor from the base.<br /> <p><br /> <p>Now after many times of starting and stopping a few different things can happen which will cause the starting and stopping motions to make noise.<br /> <p><br /> <p>As with any type of rubber product they can get old, hard and brittle and can crack with age. If this happens the<b> rubber cushioning</b> is gone and the <b>compressor frame</b> is now rubbing directly on the pan or bracket that is holding the compressor. If there are pins or bolts they will soon wear through and break. This will cause even more noise then before. This also will allow the compressor to move enough that the <b>refrigerant lines</b> are in danger of breaking.<br /> <p><br /> <p>Another possibility is that the bracket that holds the compressor or the compressor frame it's self may break and allow the compressor to flop around without any restraint except the<b> refrigeration piping</b> to hold it down. This will cause all kinds of clunking and needs to be fixed as soon as possible.<br /> <p><br /> <p>So the bottom line is that if you are hearing crazy clunking or thunking noises coming from behind your refrigerator, you better pull it out and investigate the causes before you have much bigger problems. The parts to fix many of the problems are available through many appliance repair sites. Look for your model number and then look for the parts you need in the compressor section of the diagrams.<br /> <p><br /> <p><span>How to Buy </span><u><a href="http://www.fixya.com/support/r3907570-buy_appliance_parts_online"><span>Appliance Parts Online</span></a></u>
on Jan 17, 2011 | Refrigerators
MY OUTSIDE CARRIER UNIT CLUNKS WHEN THE COMPRESSER SHUTS OFF
My CKC was doing the same thing and I thought it was the compressor slamming to a stop. Turns out it was the fan motor. I had a local company replace the motor and the sound is gone. That being said, it has now been replaced by blade vibration.. It just never ends!
Jun 28, 2010 | Carrier 38CKC042 Air Conditioner
What is the clunking noise made after the refrigerator stops running? Its a Kenmore and is 10 yrs old. We have thoroughly cleaned behind and beneath the refrigerator and now the noise seems louder.
The clunking noise you hear , is probably when the compressor shuts off , due to temp reached or when it goes into defrost . An internal motor mount spring , inside the compressor , is broken ( rusted and broke ) . The refrig can go on working for years , without any problem , except noisey , when it cuts off . To stop the noise , replaceing the compressor is the only option . I have heard of placeing objects under 1 leg of the compressor , to " re-adjust " the ballance , but thru my experience , another spring broke , causing more knocking .
Mar 24, 2010 | Kenmore 64802 Top Freezer Refrigerator
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
I had a lightning storm tonight, power flickered several times. Now neither of my compressors kick on. There is a troubleshooting board inside, but not sure what the codes mean. It is a carrier 24ACA
The contactors on each unit were stuck closed. I shut off power to the units for about 2 hours. I went back out and checked and the contactors had released. I re-powered and they started up. Great solution, but didn't really do anything.
Oct 06, 2009 | Carrier 38CKC042 Air Conditioner
My Vinotemp VT60 makes a clunking sound
You may want to contact Vinotemp's customer service @ 800-777-8466... you may need a new compressor
May 06, 2009 | VinoTemp VT-60 Wine Cooler
Excessive noise when refridgerator shuts off
Remove the rear cover at the compressor and check for loose mounting bolts on the compressor and fan motor.
Feb 21, 2009 | KitchenAid Refrigerators
Cake Display Freezer Compressor keeps freezer cold
Maybe the guy meant the compressor is going bad.
Jul 24, 2017 | Traulsen Reach in Freezer - G12010
Heating & Cooling Logo
781 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
