Question about Epson Stylus Photo R2400 InkJet Printer
Have a jet 2400 printer, cannot get the paper to go thru to print. Does it go from front to back or from the back
    Master:
  • 344 Answers
The paper loads from the back. As seen on the image there. Make sure you don't have anything like a pencil dropped in the paper slot because that can cause it not to load paper too. Dust can be an issue with this printer too so you might want to get a special cleaning sheet for it if it continues acting up.
You can find the kit here or at a local store... http://www.officedepot.com/a/products/470041/Office-Depot-Brand-Inkjet-Printer-Cleaning/
Posted on Apr 08, 2011
How do you reset a replace toner error on brother printer
Open the front cover of the printer
Press and release the "clear" key
Press "start", then press the up arrow until you see the number 12 on the display
Press "ok", you will see "accepted" on the display
Close the front cover, your toner cartridge should now work.
Apr 07, 2014 | Brother MFC-7860DW - Laser Multifunction...
I have a HP Office Jet Pro 8500 A909a My wife sent
1) Turn the printer OFF.
2) Unplug the printer's AC adapter fro the rear of the printer.
3) Unplug the AC adapter cord from the wall outlet.
4) Wait a FULL 10 minutes minimum...While waiting, go to step 5.
5) Remove the rear access door. Reach inside and rotate the rubber feed rollers on the shaft with your thumbs until they stop/click.
6) Use a can of compressed air and blow out the entire access interior.
7) Use a magnifying glass and a flashlight to to inspect for bits of torn paper or other foreign object that may still be locking the feed sensor in the feed position.
8) Try to locate the sensor and see if it is stuck. It should be spring-loaded and easy to move with a narrow screwdriver or pick.
9) Put the access door back into place (make sure it is completely closed/seated)
10) Plug the AC/power cables back in, turn the power button ON and test for a normal print process.
Dec 03, 2011 | Computers & Internet
Lexmark 2400 series: the ink cartridge doesnot move across. The power light blinks. computer says there is a paper jam but there is not paper jam.
Hi
Open the back and front door and see the properly a small piece of paper make a error of paper jam, after that move your cartridge panel by hand, and check the cartridge fix properly, if cartridge not fix properly fix the cartridge and try again to print.
Thanks
Sep 02, 2011 | Lexmark Office Equipment & Supplies
My printer will not print. it goes thru the motion but nothing prints
The ink-jets that spray the ink onto the paper may be clogged; run a few "print-head-cleaning" cycles. Also, check that you've not run out of ink.
Feb 26, 2011 | Dell V313w AllInOne InkJet Printer
Is the color stylewriter 2500 just a copier?
Just a printer but could be used as a fax printer if combined with the fax software of Windows XP or winfax for Mac.
The Color StyleWriter 2500 is a color inkjet printer manufactured and sold by Apple in 1996. It was based on a Canon-developed Bubble Jet printer, but was repackaged with a new housing, firmware, and Apple's proprietary 8-pin mini-DIN serial port. The printer is similar in appearance and functionality to the StyleWriter 2400, but featured faster printing speeds: 5 PPM black, 0.66 color, vs the 2400's 3 PPM black, 0.3 color. As with the 2400, the 2500 was compatible with the Apple Pippin console gaming system. Apple offered LocalTalk and EtherTalk networking upgrades in the form of external print server devices. Also offered was a "PhotoGrade" kit, which included a special monobloc (heads and ink in one unit) cartridge with lighter photo-oriented inks and coated paper.
Sep 30, 2010 | Office Equipment & Supplies
HP Laser Jet 1100 - Pulling Multiple Pages thru when printing
Just by Cleaning and changing the Pickup roller
Click here and Follow the steps.
Please rate my response!!!
Jan 29, 2010 | HP LaserJet 1100 Printer
Canon Bubble Jet printer won't feed paper and print properly.
Hello sir; You need to clean up paper pick up roller and feed roller with alcohol, if still have problem then replace it.
Nov 07, 2009 | Canon BJC-85 InkJet Printer
Borderless printing
I don't think there is because it has to have some space to grip the paper through the drum and the fuser. Usually ink jets can do it but its tough to do on laser units.
Jun 19, 2008 | Konica Minolta magicolor 2400 Laser...
Printer problem in hp laser jet printer 1020
Problem is you have paper jam!!! Seek for the paper inside the printer, pull out cartridge!!! when you do that, turn off printer and disconnect power cable for 1min. Pull back the cable, turn printer ON!!!
good luck!!!
Jan 29, 2008 | HP LaserJet 1020 Printer
Epson Stylus Photo R2400 InkJet Printer Logo
37 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
