Question about Pioneer Car Audio & Video
Car stereo working properly but no visible display,,what to do
If its a GM vehicle, the answer is to replace it. They wear out over time and just stop working. If not, check your vehicles instrument panel lighting dimmer switch.
Posted on Mar 06, 2014
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pioneer Master
  • 2,226 Answers
What model is it? It should be a deh..... if a cd player or keh..... if a tape deck.
Posted on Apr 08, 2011
2008 camry stereo display doesnt work
Just replace it. It's not worth the trouble to fix it!
Jul 26, 2012 | 2008 Toyota Camry
How do i get my car stereo to work even though we have installed it properly?
a) stereo is not installed correctlyorb) stereo is defectiveorc) stereo is not being operated correctlyord) problem in wiring harness
Dec 22, 2011 | Car Audio & Video
My JVC car stereo display " Protect " on display
FIRST PRESS THE RESET BUTTON BEHIND THE FACE IF DONT WORK CHECK ALL SPEAKER WIRES SOMETHING MIGHT BE TOUCHING
Jul 24, 2011 | JVC AM FM CD DET FACE CAR STEREO
AC display won't dim after stereo installation
If you disconnect the stereo, does the temp. display go back to working properly? Did you connect the stereo Illumination wire correctly? Are all the other stereo wires connected correctly? Double check what the wires in the aftermarket harness are supposed to be and don't just go by color.
Jun 17, 2009 | 1996 Oldsmobile Cutlass Supreme Coupe
Cd Player
Yes i can solve your problem first you must have the proper radio code 4 numbers and shut off engine and leave radio on with key on accessory with it displaying off leave it the radio on for 3 hours then enter the proper code and it should work fine THIS IS THE FACTORY PROCEDURE
May 21, 2009 | 1997 Volvo 850
"PROTECT" is displayed on the car stereo when turned on
This is really easy to fix. Look on the face plate for a REALLY small hole. Put the tip of a pen in the hole and it should work. This usually means the stereo isn't wired properly so if the PROTECT keeps coming on after you've re-set it, take it to a dealer. To make sure you're everything is in properly. Hope this helps...
Jan 26, 2009 | Kenwood KDC-MP228 CD Player
Need to change the 12v supply by the Radio
The Ford Focus has a stereo problem where the display blinks on and off, with or without the ignition on. This is not a power problem.
This problem occurs when attempting to store a radio station when a blank RDS signal is being transmitted.
To restore your stereo:
  • Insert a CD, stereo will turn on in CD mode.
  • Press MENU button
  • Select DEFAULT RESET by turning the right rotary knob and press to select
  • Select YES by tuning the right rotary knob and press select
  • Press BACK button
  • Press the RDS button once, display will read RDS OFF
  • Stereo will now work properly
To prevent this problem from occurring again, be sure some text is in the top line of the display when setting a stereo station. Do not set a station when the station name is blank in display.
Nov 16, 2008 | 2006 Ford Focus
Low Volume from right speaker of entertainment center - turntable only
Hi There thanks for your very good desctiption of the problem it really helps to have a lot of detail...
There are Mono and stereo types of stylis cartridges and it sounds like you have a mono equipped into a stereo amplifier..
If there are 4 small coloured wires visible under the stylis then
its a stereo stylis and should work, have a close look and maybe one of the small wires has dropped of the small pins on the back opf the stylis cartridge.
If there only two wires visible then its a mono cartridge and this is why you only have sound from one channel..
So answer is wires dropped of the stylis.
or
Wrong type of stylis cartridge.
or
if there are four wires and thay all look connected then perhaps the stylis is faulty and you need to replace it...
Cheers from YU BEUT
Feb 02, 2008 | Audio Players & Recorders
Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Nov 14, 2007 | Panasonic RX-ED707 Boombox
Car Audio & Video Logo
81 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
