Question about Hisense Televison & Video
DVD PLAYER 838C - PRESSED SETUP, AND TRIED TO CHANGE PICTURE SETTINGS AS THERE VWAS A FAULT OF NO COLOUR. NOW THERE IS SOUND BUT CANNOT ACCESS A PICTURE AND CAN'T SEE WHAT WE ARE DOING. IS THERE A DEFAULT BUTTON WE CAN ENTER TO RESET ALL SETTINGS ON THE REMOTE? - VERY URGENT PLEASE
SOURCE: DVD not playing in colour
I have this same DVD player and I have had problems with it, I then returned it and got another, this one too is having problems. They just are not very good quality.
Posted on Apr 22, 2007
SOURCE: unable to change the DVD 1 Command Mode back to DVD 3 (DEFAULT) SETTING
Had the same problem when I changed the factory settings by mistake. There is no "cancel" button in the remote or the set. What worked for me was to follow the directions on P. 22 of the manual and change the remote settings to DVD 1. This is done by holding the "Enter" button and pressing number 1 on the keypad simultaneously for more than 5 seconds. Then, you go back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down more than 5 seconds. Good luck!
Posted on Sep 04, 2007
SOURCE: Video settings reset everytime I turn off TV
Hit the menu button on the remote. Click on Setup. Then click on Set The Quick Start Options. Make sure it is on. That should solve your problem.
Posted on Mar 14, 2008
SOURCE: Polaroid HD flat screen TV with DirecTV
Press input and then select dvd. After a few moments the dvd will start up if one is inserted.
Posted on Apr 18, 2008
Ajkill
  • 2035 Answers
SOURCE: remote control code
The remote control for your DVR has the capability to control 2 additional DVRs in addition to the one that you currently have. In order for the remote control to work with your DVR, you will need to make certain both of them are talking on the same frequency. If you press the remote control and the front of your unit says DR2, that means that you need to have your remote on DR2 as well so that it can operate the DVR. To set your remote to DR2, you will need to make sure the unit is off then you will need to press and hold down the SETUP button and while you are holding this button down, press the number 2 button. Your remote is now set to DR2.
Good luck...
Posted on Sep 07, 2008
No colour either with the antenna or dvd player
Check the picture settings. Check the colour system settings. If colour system selection is improper, this kind of fault can occur.
Aug 31, 2013 | Televison & Video
With some dvds picture is split screen showing the picture on both halves of tv screen, how do I make this a single picture on whole screen?
HI,
Check on thing Go to the SETUP Menu and check is there is any System settings (colour system) on both DVD and TV . Try all the settings available in the colour system setting. As you didn't mentioned anything about Brand and model number of the player or tv. Its not possible to give you the exact solution.
Ajin
Jul 25, 2012 | Audio Players & Recorders
While watching a dvd on the Q2035a I was using a seperate dvd player and I use a universal remote for both the dvd player and Q2035a. I began to adjust settings for the dvd player using the univ. remote....
Hello, It sounds like when you pressed the remote you inadvertently changed the scan on the ctv. This can cause the ctv ( colour tv ) to change from say ntsc to pal or similar. Even a reset button wouldnt help as it sounds like it is within the setup menu. You could try, as I have done this myself with a similar problem, disconnecting your dvd and putting it aside. Then, pressing the remote when in tv mode and watch for any change in screen flicker etc. If you have the original remote for ctv use that. If as you say, the tv goes to standby mode, you may have damaged the power supply, as the power supply will shut down to standby at any sign of a short.
Mar 23, 2011 | Televison & Video
RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Mar 26, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
We have reconnected our DVD to our new flatscreen and can see the picture, hear the sound but the picture is only black and white
This sounds like either the colour settings on the DVD are wrong for your new TV, or the TV has got the wrong setting for the socket that the DVD is connected to.
Go to the menu of the DVD first and look for picture settings etc. Or colour, keep your eyes peeled for the words PAL or NTSC.
Feb 06, 2010 | Toshiba SD-K770KU DVD Player
I hit a wrong button in settings, and now the dvd player is gray, and looping so fast I can't go back and change what I pressed. Is there a DVD reset settings button anywhere?
i was doing a setup when i cleaked the swr? butten thats the dvd player stoped working it still plays cd but dvd i hear sound but no picture
Dec 24, 2009 | Mintek DVA-8700 System
Someone made my video dvd combo black and white
It sounds like the video out put has been set to S video,go into the hv-dx300a menu and look for the video or picture out put settings and set to VIDEO or RGB, rgb is the best if it works for you.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | Sony DAV-SA30 System
No picture after resetting by pressing stop button for 20 sec
Problem fixed: I realized that the problem was that with resetting the player it defaulted to the standard video ouput ie no longer sending signal through the component video. I used a standard video cable and connected player to tv with that and it had a picture. Then I changed the setting to progressive output and got picture signal through the component cable again.
Aug 15, 2008 | Cyberhome CH-DVD 300 DVD Player
Xbox 360 picture problem
check vga cables or composite cables
May 24, 2008 | Microsoft Xbox 360 Console
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Televison & Video Logo
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
