Question about Cameras
Ajbennett@gvec.netI have a 5250 kodak printer and when I copy something the paper comes out gray with black lines down the side. It does print. Why is the paper colored and have lines on it?
    Master:
  • 344 Answers
You are possible loading the paper in up-side-down. Try loading the paper flipped over. A lot of kodak photo paper have bar-codes printed on one side for the printer to scan and verify you are using the proper paper for the printing job you assigned to it.
Posted on Apr 08, 2011
Will not print
get a new printer,you got 4 years out of it
May 19, 2015 | Kodak Office Equipment & Supplies
Kodak ESP 5250/assembly/back of printer/roller assembly
Ok, here is what you do to replace the gray paper feed at the back of the ESP 5250:
Hold the part with the flat side up and the rollers should be facing you. Note that there are 2 pegs on the right side, one smaller than the other. Now look at the back of your printer, you may need a flashlight, and find 2 square holes, one smaller than the other on the right side of the printer. Guide the pegs on the part into the
holes on the printer (right side) .Then push the left side of the part into the left side. Note that the part does not snap in. What you do is push the part to the left as far as it will go to hold it in place.
You should now be able to print.
You're welcome, have a nice day, Ken the fixit guy.
Apr 18, 2013 | Kodak Esp 5250 All-in-one Inkjet Printer
HOW CAN I PRINT A TEST PAGE FOR MY KODAK ESP 5250
To print a test page:
  1. Make sure you have the latest version of firmware
2. Load8.5 x 11-in. plain inkjet paper in the paper tray. 3. Dothe following steps depending on the printer: ON ESP 3250, 5250, Office 6150 or 7250:
  1. On the control panel press Home.
  2. Select Maintenance, then press OK.
  3. Select Print Test Page, then press OK.
  4. Press Start.
  5. Wait for the test page to print.
For the 5000 Series Printers, a diagnostic sheet is usedinstead of a test page. To print a diagnostic sheet:
  1. Make sure you have the latest version of firmware. See How do I upgrade my all-in-one printer with the latest version of firmware?
  2. Load 8.5 x 11-in. plain inkjet paper in the paper tray.
  3. Do the following steps depending on the printer:
ON 5100: 1. Press and hold Quantity + Copy. ON 5300 or 5500: 1. Press the Menu button. 2. Scroll down to PrintDiagnostic Sheet. 3. Press OK. 4. Press Start. Wait for the test page to print.
Nov 20, 2010 | Kodak Office Equipment & Supplies
I put paper in align the guide, click on print. It doesn't print. It says it is unable to detect paper width.
Restart your printer,put 8.5X11 papers in th paper tray.Align the gray coloured paper tray to the edge of the paper.Place any paper on the scanner glass of the printer and press copy on the printer.You will get a copy from the printer. Keep posting me ...
Dec 14, 2009 | Kodak ESP 5 Printer
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Esp3 printer, has new cartriges, printing very fient
Have you tried the maintenance tool - if you open the kodak printer status monitor in your taskbar (next to the clock); at the top right hand side you will see an icon showing crossed hammer and spanner, click on this and run the tools from top down (dont need to do the test page).
If that doesnt work you could try this:-
my new esp3 printer (replaced due to not printing black) came with a suppliment document for action if no black or faint print appears!!:
verify paper is loaded into paper tray then press and hold the Cancel and Copy/Resume buttons simultaneously until the On/Off light flashes -apparently this fixes the no black/faint issue.
hope this helps
Jun 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Vertical black line when copy with Koda ESP 3
Some dust particle or something might have been stuck on the scanner. Try cleaning the scanning glass
May 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My KODAK 5300 AiO printer wont print from PC
try pressing the copy and cancel buttons at once a blank sheet of paper will come out and that should solve your problem. I hope this helps
Jan 19, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Lines on print
check your paper guide and then run through it's maintenance test. then run another test paper.
Jan 05, 2009 | Kodak Easyshare Printer G600 Thermo...
Black line down the paper on copy mode. Ok in print mode.
There is most likely something on your scan glass that is blocking the scanner. Clean of both pieces of glass that are there when you flip open the ADF, or top cover. Try to copy again. If it is still there then there is either something on the scanner piece that moves back and forth to scan or one of your scan LEDs is burnt out and the scanner will have to be replaced.
Dec 17, 2008 | Brother MFC 7420 All-In-One Laser Printer
Open Questions:
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
