Question about Toshiba Televison & Video
Scrolled words across the bottom of the screen appear separated with 2 different colors and look as if they are going over a hill. The picture at times looks ok but the colors separate out at times.
  • 3 more comments
  • tiffiniemosl Apr 08, 2011
    The info on remote says Toshiba CT-90086
    I figured you were going to say that. I'm at work right now. I will go home at lunch and look. Its 10:30 am our time. I will go to lunch in a couple of hours and will let you know then. Is that ok?
    Thanks!!
    Model # 50H82
    How do you check the convergence output chip and the big resistors solder connection? Where are these located in relation to the TV? How do you resolder the dry/solder joints? Is there a manual (via remote) to check if these items are in sequence? If so, then how?
  • tiffiniemosl Apr 11, 2011
    Did you receive my questions on Friday?
  • 10,594 Answers
Let me know model number and brand of tv to diagnose possible cause of problem.
Thanks.
Posted on Apr 08, 2011
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Apr 08, 2011
    Thanks, model number would be written on rear of tv.
    No problem at all, please take your time.
    Thanks.
    50H82 is rear projection tv that has three basic color picture tubes to generate image on front screen.
    Problem seems in convergence output section, convergence output chips and big resistors solder connections should be checked as some of them would be dry/ cold. Resoldering of these dry/ cold solder joints will hopefully solve the problem in picture.
    Thanks.
    Are you handy with electronics stuff repair and have experience of soldering on circuit board?
    If not then contact local tv repair shop as they will do this job. I can provide you info about problem in tv as what could be wrong but teaching electronics is not possible over internet support.
    Thanks.
It has double images. The words are doubled even, appearing blurry. We are currently playing a DVD "daddy daycare" The words on the car are unreadable because they overlap. At the bottom of...
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes these problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 28, 2011 | Sony KP-46WT500 46" Rear Projection...
Wavy colors across the screen and the color has separated. ghosts on picture -four eyes ect. I can't adjust the convergence.
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Samsung HCL4715W 47" Rear Projection...
Red line across top/blue line across bottom of screen
Adjust your convergence. Under menu I think its the last choice at the bottom of settings or picture menu
May 05, 2009 | Sony KDF-50E2000 50" HDTV
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Colors are separated on the top from the left to right
Probably the color convergence is off. I had a similar problem. Have you tried the magic focus button yet? That is located at left in the small front control panel. Power on TV, wait 20 min (according to user guide), then press the magic focus. If that doesn't fix the problem, you could try the service mode alignment procedure. But that's a little trickier. I don't have a link handy for that procedure right now, but will look for it if magic focus doesn't re-align your color convergence.
Jan 02, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Rca p56927 colors out of line
This is a convergence oroblem. First question is do you have the convergence option in under setup in the customer main menu?... if you dont you may have the very common fl231 fuse problem; i have wrote a article on this under the tips and tricks section. this is a very simple inexpesive repair. If you do have the "convergence option" then you may have to replace one of three cuircit boards
Oct 25, 2008 | RCA R56WH76 Projection Television
60" Phillips HDTV Rear Projection
You need new convergence ICs two of them numbers STK392-110 they are available at the following link and they provide free installation instructions with pictures as well as free online tech support while you do the repair which takes about an hour. Heres the link.
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
