Question about HP L Class Power Converter (09503470) Power Supply
Hi, I bought on ebay a Magnetek 3877-77-103 (DC /DC inverter) on which there are many multiple connections that do not know the functions. I would like to be able to operate but i have no the schemes, no indications of how to connect. Thanks for any response.
  • 1 more comment
  • romandir Apr 09, 2011
    Perhaps I have not explained well.
    I look for information how to run a MAGNETEK 3877-99-103 and not a HP L class PWR CONV. 09503470.
    The answer you gave me does not match anything with what I asked!
    If you need to tell me how to do and I will send you a photograph of the object in question.
    Thanks
    Yes You are right sorry.
    The part numeber is 3877-99-103
    Thanks
  • romandir Apr 10, 2011
    that's all what I find on the card:
    CCTECH CD-2
    RU (triangle simbol) 94V-0
    2304.
    No more.
    Regards.
  • HP Master
  • 1,591 Answers
The part number appears incorrect, please check.
Posted on Apr 09, 2011
  • Norman Skinner
    Norman Skinner Apr 09, 2011
    Still appears to be an incorrect part number, look for OTHER numbers on the unit, that number isn't the part number apparently.
  • HP Master
  • 6,993 Answers
The Magnetek 6332 removal requires that 4 screws be taken out of the front panel and then 4 more removed out of the wood. Two more screws are removed to take the AC cover off the top left corner. The lower power supply portion can then be removed by taking out 4 more screws and disconnecting the 2 AC wires plus 3 DC wires.
There are really three sections to this converter. A picture should help explain what does what.
The top left corner is and AC electrical panel similar to what you would find in any house. Here is the list of what loads
they supply:
1. Main 30 Amps (Green)
2. 15 Amp Air Conditioner
3. 15 Amp Battery Charger
4. 15 Amp Side Door and Lounge Seat Receptacle
5. 15 Amp Microwave Oven
6. 15 Amp Fridge
The right top corner is a DC fuse panel. In this model the first 6 fuse locations are connected to the unregulated DC when
shore power is turned on. Some people call these unfiltered. That means there will be AC ripple on the DC so these should
not be used to power loads which are sensitive to AC. A good example would be the TV or audio system. You might hear
hum in the speakers if an audio system was connected to these fuses. Here is a list of what they are connected to:
1. Blank (No fuse installed)
2. 1 Amp CO Detector
3. 20 Amps Lights, Furnace, Hood Fan
4. 15 Amp Water Heater
5. 1 Amp LP Detector
6. 15 Amps Fridge
7. 10 Amps Roof Fan
8. 10 Amps Water Pump
9. 15 Amps TV
If you are interested in exactly how much each appliance draws, take a look at this link; http://windsurf.mediaforte.com/roadtrek/solar/Roadtrek_Solar_on_the_Cheap.html
The lower section is a 32 Amp DC power supply. A block diagram is shown to help understand how this thing works. The DC fuse panel is broken into two pieces and called Unregulated and Regulated.
I have broken the wiring diagram into two drawings so they fit better on one page. The first drawing shows the
transformer, relay and temperature controlled fan. The relay is needed to connect the ungegulated fuses to the battery
when no shore power is present. The fan comes on when the heatsink reaches a certain temperature.
The maximum voltage shut off circuit in this power supply does not take very many parts but the theory on how it works is
not straight forward. It would not be done this way today. That is probably why it is no longer made. In general they use
one SCR to control the gate of another SCR. When the battery voltage reaches a set point, chosen by the pot, the first
SCR shuts off the second SCR and no more power is sent to the battery.
I hope you find the above helpful.....
Good luck.
Posted on Apr 08, 2011
I want a speed controler for a PM dc motor . the spec for the motor are. 180 v 7.5 amp 4800 rpm Duty Treadmill Part no 7.22 316400 model46300-17 .Magnetek NPL 877-7. I am making a machine and I...
Hi, Can you use the treadmill speed controller ? Or you could by a AC/DC invertor drive , http://www.inverterdrive.com/group/DC-Thyristor-Drives/SSD-507-Eurotherm-Shackleton-Rapier-Drives-503-504/default.aspx
Thats a link for a possible option for you , you often see them in exchange and mart or Craigs List .
hope this helps, please rate accordingly .
Aug 31, 2010 | Heating & Cooling
Yesterday I bought an STP-120 SIMA power inverter
you inverter was not fully charged because it requires a 110/220 v ac as specified in the manual; to charge it so it is impossible for the aircraft 15vdc to charge it
Jan 27, 2010 | APC DC to AC power inverter ( external ) -...
How do to get in multiple player mode on nintendo 64?
test the controllers before....check the cables...problems with wires are common....there are many options inside the menu game...to enable functions... and enable multiplayer mode...Good Luck!
Sep 10, 2009 | Nintendo 64 Console
Invertor connections to protect from utilty power backfeed
Inverters normaly have inbuilt protection built into them check for reset button/switch.
Jun 19, 2009 | ABB S272-k16 2-pole Miniature Circuit...
Dell Inspiron 1505; Battery does not charge; DC jack is loose..
The loose connection for the AC adapter means the motherboard needs to be replaced or the AC adapter jack on the motherboard needs to be replaced. (With Labor, it is about the same cost to buy a new motherboard as it is to have the old one fixed)
Motherboards are available on EBay for around $100
Apr 25, 2009 | Dell Inspiron E1705 Notebook
Spa tub motor need replacing
I havent seen to many motors this old, but today all you really need to know is the horsepower and the frame (either round or square). Pull the old one off and take it to a pool store, and they can probably get it for you.
Also..im not sure but i think A.O. Smith bought out magnetek some years back....
Mar 30, 2009 | Pentair Ultima Series Pump Part Heat Sink...
Can't get power to my RoadPro 1500 DC to AC Power Inverter
I have had this same problem with several power inverters over time. The problem is usually one of three things.
Those starting with the simplest.
1. Too much current being drawn on the inverter.
Solution (Check appliances that are plugged in and make sure they are not drawing more than 1200 watts. If they are unplug the appliance that is using the most current and get an inverter that is more suited to your power needs.)
2. Some power inverters have fuses built on to them. Sometimes multiple fuses. Sometimes, one fuse may burn out leaving one intact. When this happens even small items draw too much current and over load the inverter.
Solution (Replace the fuses)
3. Improper installation. Inverters draw a lot of current. You must use the propper wire size for the inverter. I would recomend at least an eight guage wire directly fused and hooked directly to the battery. Of course like with all things the bigger the wire the better the flow of electricity.
If it is not one of those things stop into a truck stop electronics shop and have the person diagnose it.
Hope that helps.
Jan 20, 2009 | RoadPro AC/DC Power Inverter 2000/5000w
Evesham Nac-cam 7000
Hi
We sell the chargers for the unit. we bought all the stock when evesham went down they are 100% the right one
username on ebay whenitssolditsold
Jun 02, 2008 | Evesham Nav-Cam 7700 GPS Receiver
HP L Class Power Converter (09503470) Power Supply Logo
638 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
