Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 42 cc chain saw that is hard to pull the rope like the compression release is not working. How do I repair it?? Built in 2007
  • Poulan Master
  • 2,239 Answers
I do not think they had a compression realese on a saw that small, it is more likly to be an issue with the starter, remove the screws and take away the starter does it pull easily off the saw? if it is ok try turning the engine with the flywheel, is the flywheel rubbing the ignition unit, the gap here should be 0.5mm.
Posted on Apr 08, 2011
Testimonial: "no, this did not fix the problem"
  • 4 more comments
  • Andrew White Apr 10, 2011
    i feel then this is how the machine is, running a 50-1 fuel oil mix might help a little, when it is running does it run well?
  • dawillems Apr 11, 2011
    The engine turns easy with the spark plug removed, I see this as a compression problem.
  • Andrew White Apr 11, 2011
    I fear the only thing left is to de coke the piston crown, assuming it has the correct spark plug in, there is no more you can do to decrease the compression
    How do I decoke the piston crown??
    The easiest way without removing the cylinder, is to remove the muffler, bring the piston down to bottom dead centre, now carefully scrape any carbon from the top of the piston with a suitable tool via the the exhaust port, shake any loose carbon out through the exhaust port, use compressed air if available to blow it out.
  • dawillems Apr 13, 2011
    I scraped the top of the piston and then brought the piston to top dead center and sprayed some internal engine cleaner through the spark plug hole, replaced the spark plug and let it soak for overnight, then I cut a test log for 5 minutes. That helped. Thank you for the help.
Took carb apart not sure if i put diaphram right side up it runs but not for long seem to be air coming fuel line air bubbles replaced ffuel line and stone
Posted on Apr 15, 2011
How much compression should the saw have?
What Causes Too Much Compression on Poulan Chain ...
homeguides.sfgate.com > ... > Other Types of Mortgages
Many makes of gasoline-powered yard tools, including Poulan chain saws, use two-cycle, or two-stroke, combustion engines. ... Pull the rope out and oil it to see if that helps the problem. ... How Much Compression Should a Stihl 066 Have? ... Pull Starter on a Poulan Chain Saw · Oil Pump Removal on a Poulan Chain Saw ...
The Timber Trades Journal and Saw-mill Advertiser
Nov 26, 2015 | GCSP Husqvarna 340 345 346 350 353...
Chain saw is not oiling the chain
adjust oiler screw on bottom of saw--clean out area behind chain cover
Apr 26, 2014 | Poulan/Weed Eater Poulan Pro 35 cc 16" Gas...
Starter rope hard to pull. It's not smooth and takes a lot of effort.
Make sure the brake is off and retest. If brake is off and still difficult to pull, remove the side cover, chain, bar and retest. If still not right (remove sparkplug), remove the muffler and make sure that the spark arrest screen is clean and verify that the cylinder and piston look clean and smooth by looking into port. You can clean the cylinder by spraying wd40 and pulling the rope untill it all comes back out. Verify that the rope pulls smoothly before you reinstall the spark plug. If all looks good, reinstall muffler and retest. If the compression is normal, it should be rather hard to pull thru the compression stroke. Reinstall bar and chain for final test.
Oct 12, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a wild thing. the rope pull starter is very hard to pull. when i take the spark plug out it is easy to pull. the saw was not used for about 4 years until yesterday. it ran for about 45 minutes fine....
one piston ring has expanded now having no or a very fine gap increasing the compression ratio causing this to happen. When the spark plug is removed it is very easy to pull on the cord in any means. A inspection is due of this engine or a new chain saw is needed
Jun 05, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Poulan 14" chain saw has become difficult to
If you have more questions or need additional help pleasereply below and I will get back to you. HTH & Good Luck. Lou Thank You for using FixYa. gif,gif89a%12%00%12%00%b3%00%00%ff%ff%ff%f7%f7%ef%cc%cc%cc%bd%be%bd%99%99%99zyzrur%00%00%00%fe%01%02%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%21%f9%04%04%14%00%ff%00%2c%00%00%00%00%12%00%12%00%00%04x0%c8i%2b%1d8%eb%3d%e4%00%60%28%8a%85%17%0ag*%8c%40%19%7c%00j%08%c4%b1%92%26z%c76%fe%02%07%c2%89v%f0%7dz%c3b%c8u%14%82v5%23o%a7%13%19l%bcy-%25%7d%a6l%df%d0%f5%c7%02%85%5b%d82%90%cbt%87%d8i7%88y%a8%db%efx%8b%de%12%01%00%3b
Jan 09, 2011 | Poulan 14" Chainsaw
I have Poulan Pro 42 CC 18" Chain Saw. When I
Check to see if you have the chain oriented correctly - it is east to put them on backward without realizing it. Th3e teeth should point forward, with the anti - kickback lug in front of the tooth. Let me know if this helps!!
Nov 05, 2010 | Poulan Pro Chain Saw 46cc 20"
18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts (usually first pull).
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Feb 18, 2010 | Poulan Garden
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Husqvarna Chain Saw Rope Pulls Very Hard, what is the cause?????????
Has it always done this or has it developed?
Some saws have a decompression button to make it easier to pull over.
Oct 03, 2008 | Garden
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
952 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
