Question about Ryobi 30cc 17" String Trimmer Zrry30530 Wcurve Shaft
Where can I get replacement parts for my Ryobi strimmer? The small rings that fit into the strimmer head and from which the strimmer lines exit need replacing, one is broken the other lost
4 Suggested Answers
  • 148 Answers
SOURCE: RLT30HT 30CC PETROL STRIMMER difficult to start
The plug that I have in my 720r is a Champion RDJ7Y. Can I suggest that you pull the old plug out and look to see which one you have? Also when you buy the new replacement it should already be gapped for what you need.
Posted on Jul 28, 2009
  • 969 Answers
SOURCE: ryobi 700r gas trimmer, replace old fuel lines
1-800-345-8745 US
1-800-265-6778 Canada
Posted on Aug 23, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Ryobi 700r 31cc 15" Trimmer,
Hi and wel;come to FixYa, I am Kelly.
The part you need is item 9 on most parts lists:
Your problem is caused by either drive shaft failure or.. clutch failure. Most of the time the drive shaft fails before the clutch.
The manual is here:
http://www.mymowerparts.com/pdf/Ryobi_String_Trimmers_Blowers_Tillers/700r.pdf
Shaft is PN 682064 or 753-04280
Sears parts direct has the shaft as item 10 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Ryobi-Parts/Grass-trimmer-weed-wacker-Parts/Model-700R/0909/1503820/10060718/00002?blt=06&prst=0&shdMod=700R
Detailed view:
http://www.searspartsdirect.com/partsdirect/part-number/Ryobi-Parts/Grass-trimmer-weed-wacker-Parts/753-04280/0071/247/Model-700R/0909/1503820?keySuffixId=NA&productTypeId=x&searchModelNumber=700R&subCompDesc=Boom%20and%20trimmer&brandDesc=RYOBI&modelDesc=TRIMMER&pathTaken=partSearch&blt=11
Lower price here:
http://www.mowpart.com/p661995/Flex,-Shaft-(Rpls-682064)/product_info.html
Average price ($32.50)
Thanks for choosing FixYa,
Kelly
Posted on May 29, 2011
Ryobi Li-ion strimmer
check that you are using the correct line in the head
if it is too thick , the load will be causing the thermo switch for the motor to stop operation until it cools down
Jun 16, 2017 | Ryobi Drills
Where can i get a piston ring for ryobi strimmer,its a 25cc,model number PLT 2543.
Some of these small engines have very limited parts availability so that part may not be available. Try www.jackssmallengine.com
Oct 27, 2016 | Ryobi Garden
Ryobi line strimmer hedge cutter attachment won't cut even though the blades are moving can you give any idea what he problem might be?
grass,string or vines can get wound around the motors shaft, you will need to take off the spinning head to remove debris from motors shaft
Jul 25, 2014 | Ryobi Garden
I have a partner colibri strimmer. How do I lock the driveshaft to change the line spool head ?
You should have a small hole in the side of the head that a small rod goes in to lock it. Just line the holes up and stick the rod or a nail in there and it should be locked.
Jul 11, 2014 | Ryobi ZRRY30550 Factory-Reconditioned 30cc...
Purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
try Lowes or any Agway, and if that dowsn't work, try checking on line with your type of trimmer.
Apr 22, 2012 | Garden
Fuel line for ryobi
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up aginst tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulbgoes to top port of carburetor. that is the way thay go on.it is important to make sure you have the same fuel line I.D.3/32 and O.D.3/16 are very important! also if old line dissolved it will get in carb. and clog ports & small screen inside.clean inside of carb. with carb. cleaner & air pressure. to get your parts and numbers ,go to mtdparts.arinet.com, parts,791-683398,fuel line assembly,this is for most fuel line trimmers~~~hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ``
Feb 12, 2012 | Garden
Replace fule line on ryobi wipper snipper I
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up aginst tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulbgoes to top port of carburetor. that is the way thay go on.it is important to make sure you have the same fuel line I.D.3/32 and O.D.3/16 are very important! also if old line dissolved it will get in carb. and clog ports & small screen inside.clean inside of carb. with carb. cleaner & air pressure. to get your parts and numbers ,go to mtdparts.arinet.com, parts,791-683398,fuel line assembly,this is for most fuel line trimmers,any comments welcome,thank you. ``
Feb 03, 2012 | Ryobi Garden
I have the ryobi rlt30ces strimmer and cant find a piston ring anywhere any help???????????????????????
Here is a 30CC Ryobi 2-stroke trimmer. Your ring is item number B-53 in the diagram. The part number is 03179. They have these in stock also. Hope this helps you!
http://www.ereplacementparts.com/ryobi-ss30-ry30002a-string-trimmer-parts-c-7931_15633_15652.html
Jul 14, 2011 | Ryobi 15" Electric Factory Reconditioned...
How to fit brushcutter to ryobi petrol strimmer. I have the tools but have lost the nuts etc, can I replace them? But will still not know how to fit the Tri-Ark
the nuts on weed eaters are usually left handed threads, they do sell them at a hardware store and I am sure the other parts you need you may have to go to a small engines sales/service. Hope this helped Tim
May 28, 2011 | Ryobi Garden
I have a ryobi 31cc straight shaft with all the attachments. I am replacing the fuel line and need a schematic of what goes where. There are two holes under the tank reservoir and one has nothing attached...
The second hole is for the carburator return line(& primer line). Your correct their is nothing to attach it to. The line itself self seals the hole. If you inspect the old line you will see that where the line fits the hole the upper part & lower part were slightly larger in diameter. This enabled the line to seal itself in the hole when installed. If you have to replace the line, purchase a rubber washer and plastic cement and cement the line to the outside, leave about 1/4 of inch of line inside the tank. Try to buy tubing that is slightly larger then the whole which I belive is 1/8"OD. The other line is fuel supply it will have small white ring to attach the tubing to on the fuel tank.
May 07, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 30cc 17" String Trimmer Zrry30530 Wcurve Shaft Logo
20 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
