Question about Lexmark T630 Laser Printer
My printer T630 wont feed the paper, if its full to the paper line it really doesnt work. We have tryed to lower the amount of paper in the trays and that doesnt work either. I go to print and it tells me paper jam so i look and theres no paper, it is when the paper is going to be fed to be printed it wont grab it happens in both tray 1 & 2. Please help
  • 37 Answers
The printer don't pick-up the paper, the cause is dirty roller. You can clean pick-up roller with a wet cloth with alcool.
Posted on Apr 29, 2011
The printer recognizes tray 2 but it will not print to tray 2.
The printer will not print from any tray if tray one is pulled out. the paper path from any other tray still goes through tray 1\'s feed path (little slit in the front of the tray). if tray one is not in the printer it will not pull from any other lower tray.
Jun 03, 2014 | Lexmark T630 Laser Printer
Printer recognizes tray 2 but will not print from tray 2.
its not reading there is any paper in the slot so will not load from this draw. the is a switch that when paper is installed it lifts it to tell printer paper loaded. like any switch they can fail.
Jul 03, 2017 | Lexmark T630 Laser Printer
241 paper jam message
Lexmark T630 241 paper jam message - Indicates a paper jam from the pull down manual feed tray.
If you check to make sure and small fragments of paper are not hindering the operation of the switch. The switch is located on the left side of the tray and will be spring loaded. The switch should move freely without binding. Make sure no toner or dust is on the optical sensor assembly. See Diagram for location.
If the switch seems OK and the printer still reports an error, the printer will require professional care.
Jan 15, 2011 | Lexmark T630 Laser Printer
Hello i have a lexmark t630 and when it prints out of tray 2 it says change tray two and beeps. It will work normal if you hit the select button. What could it be?
the printer is telling you that the tray is reporting the wrong size paper. print the network menu from tray 2 if it prints out smaller than the page it will be reporting smaller than letter. if the bottom line of the outline is missing its reporting legal size paper. if you are running lettersize paper in the tray check on the left side of the tray half way down the drawer you will see a plastic snap in plate with 3 fingers the bottom 2 should be sticking out for letter size paper. you only have to be one of the small adjust teeth off to make the third finger stick out and report the wrong size paper this is a very common issue. look at the metal fingers that stick out of the frame of the options tray to make sure they are uniform and straight. if the fingers are set right and not damaged then the logic board in the tray assembly will have to be replaced
May 14, 2010 | Lexmark T630 Laser Printer
PAPER FEED DOESNT WORK KONICA MINOLTA COLOR PRINTER
This happened to me one time after I pulled out a jammed paper the wrong way. I pulled it from the paper tray. Heard the sounds, it tried to grab the paper, but couldn't. It happened a long time ago, so I'm fuzzy on which part I tinkered with...but I recall that because I pulled the paper (backwards) from the tray, it flipped a lever/feeder/roller/thing and that 's why it wasn't grabbing the paper. If you look in the paper tray as the rollers go down to grab the paper, you'll see what's not working......sorry, lame solution.
Mar 26, 2009 | Konica Minolta magicolor 2430 DL Laser...
Printer will not print
I had the same problem and to fix it there was a blue tray I had to pull out (the tray for the photopaper). Once it was pulled out so it was about flush with grey part beside it, the printer worked again. (The photopaper tray is just above where you put the regular paper.)
Jan 04, 2009 | HP Photosmart C6280 Printer
Manual feed only
Pull out tray 1 & ensure the gray left-rear paper type clip is completely in the notched hole.
Aug 11, 2008 | Dell M5200n Laser Printer
Lexmark T630
Repeated, Unexplained Paper Jams With Little or No Damage to the Paper ID:ENUS5286 null.gif null.gif null.gif
IMPORTANT: The printer should rest on a surface that is flat, level, and uniform. This is for safety reasons as well as for paper feed reliability. In the bottom left corner on the front of the printer, as well as on the duplexer and each paper feed option apart from the 2000-sheet feeder, there is a shaft that rotates as the main drive motor in the printer operates. The purpose of this shaft (called the Power Take Off shaft) is to turn the pass-through rollers in the option below. The Power Take Off (PTO) shaft rotates during the printer's POR as well as any time the main drive motor turns, including while paper is feeding from any source and when the toner is agitated in the cartridge.
If the printer is on an uneven or non-level surface, the PTO shaft may not make full contact with the bevel gear on the lower options.
If the printer is on a surface that is not uniform (such as a carpet or foam padding), the PTO shaft on the lowest option may catch or bind, causing the paper feed operation to slow or stop completely.
In either case, repeated and unexplained paper jams (with little or no damage to the paper) may occur. The paper jam is due to the increased amount of time it takes the paper to feed through the path because the PTO shaft is bound or caught on the surface below, or is slipping on the bevel gear.
NOTE: This is not a printer defect or failure although it may result in a broken or stripped PTO shaft.
May 30, 2008 | Lexmark T630 Laser Printer
Selecting a default paper source for a specific program
That what you want is not TRAY 2 it is Manual feed!! That is need to select to be default or you can empty Tray1 and feed Tray2 and select feed automatic! This both solution will work you choose witch appropriate to you!!!
good luck
Jan 30, 2008 | Lexmark T630 Laser Printer
Hp paper feeder wont thu printer
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Lexmark T630 Laser Printer Logo
148 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
