Question about Baby Gear
We are looking for replacements straps for a TE@M70 Universal childs car seat,where can I get them?
  • 5 Answers
SOURCE: Infant Rear facing car seat
1. Depress the harness adjustment button
under the seat flap. Pull the shoulder
straps out to loosen the harness.
2. Behind seat, remove the ends of the two
shoulder straps from the metal junction
plate.
3. From front, pull straps through the
harness slots and then reinsert them
through the appropriate slots.
4. Behind seat, push both shoulder
straps UNDER owner’s manual pocket
and out the bottom.
5. Reassemble the strap ends onto the
metal junction plate.
Page 28-31
http://www.gracobaby.com/assets/pdfs/instructions/ISPC089BA_ISPC106AA.pdf
Good Luck and be safe!!!
Posted on Nov 20, 2007
SOURCE: I took the straps off my Brevi Childs car seat to
Hi I am looking to buy a Brevi Universal car seat cover and the straps as well what web site should i be looking on???
Posted on Jul 29, 2009
SOURCE: evenflo discovery 5 infant car seat straps
Okay okay--do not do anything with the big pieces behind the babies back but the gold clips at the **** area..pop those out and shove that piece and the clip and the chest clip through the back of the strap hole--then reput the strap through the slot you wish then the gold pieces back through the bottom and of course pop the gold pieces back--again do not use the upper clips behind the back to do this :0)
Posted on Dec 21, 2009
  • 9 Answers
SOURCE: looking for instructions for assembling a costco
Go to this website and type in your car seat info. If they do not have the manual, I would call the manufaturer's number located on your car seat.
http://www.coscojuvenile.com/Instructions
GOOD LUCK!
PS I just took my car seat apart to wash the cloth material and found the easiest way to reassemble it was to remove the base during install of the straps and then replace the base.
Posted on Jul 05, 2010
SOURCE: Graco nautilus 3 in 1 car seat need help with strap installation
Yes! PLEASE someone help with this problem! I took the seat apart over a year ago because my daughter hit 65 pounds and I had to remove the harness. Well, now I need to use the 5 pt again for a friend's daughter and I cannot for the life of me figure out how to get it back together! Are there supposed to be TWO very looooong straps for the harness? I can only find one, and when I put it together the way I *think* it is supposed to go, the strap is tooooo long. I know you have to flip the back of the seat down to get at the spot where the harness straps are supposed to attach on the sides of the seat but I don't know how they're supposed to go exactly. I can't find ANYTHING about how to put this part of this seat back together!
Posted on Sep 06, 2011
Crouch strap
Hi
Please contact Graco for assistance with correct use of the harness
Get news from Graco delivered right to you inbox
May 10, 2014 | Graco Nautilus 3-in 1 Car Seat
Tip
How to Install a Child Seat
FOR LARGER KIDS: If the child is over 35lbs, use the belt and shoulder harness as you would an adult and simply extend the belt over the seat. You do not need to install any of the built in straps.
SMALLER CHILDREN (UNDER 35 lbs):
1) If your child is under 35lbs get the locking clip that came with the seat if you have a seat with a shoulder harness attached. Otherwise, it isn't necessary. Pull the shoulder harness down to the base of the waste strap and then use the locking clip to bind it into place.
2) For a smaller child you will need to install the built in straps like so.
3. Set the seat in place running the waist strap through the back of the seat and clipping it on the other side.
on May 06, 2010 | Baby Gear
I took the straps off and can not put them back, can you help?
The Long strap goes under the seat and comes up thru 2 holes (each end goes up thru each side). The holes are on each side of where the child sits. They come up and weave into the latches that snap into the **** clasp. Upward toward where the child's head would be they go thru the chest clasp. Look at the writing on the clasp to make sure it is on right (letters read the name Cosco and arent upside down) and the belts should be behing the clasp (in at the bottom of the clasp and out at the top). Up thru the holes on the back of the chair at the height appropriate for the childs body. Out the back and down to the claw that is on a strap under the front that you can pull to tighten or press to release slack as the child gets bigger. There should be 1 or 2 (usually 2) slots for the ends of the straps to be slid on to. Sit the child in the car seat and adjust the belt system so that a finger can be slid between the belts and the child's shoulders. This should do the trick. Good luck and be safe.
Mar 18, 2011 | Cosco High Back Booster 22-200 /22-207
Maxi-cosi tobi strap tensioner not working. able to tighten straps when child is in seat but when buckle is pressed to release straps and get child out, unable to loosen straps tensioner will not let go.
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Jul 28, 2010 | Maxi-Cosi Baby Gear
I took the straps off my Brevi Childs car seat to wash and can't get them back on!
Jun 11, 2009 | Safety 1st Designer 22-325
I cannot fold down seat
Try looking for a strap in your trunk it should be located at the upper inside of your trunk, there could be one or two straps, when you pull on these straps they act as a release lever for your rear seats, pull the straps toward you and push the seats forward from the trunk side.
Mar 11, 2009 | 2002 Oldsmobile Alero
I need to put the straps back in seat
When I was doing research on your problem, I came across this recall. Please read and see if it relates to your product. RECALL ID# 66785 - CHILD SEAT Recall Date: July 28, 1993 Model Affected: AUTOMATE Recall Summary: THE TONGUE OF THE BUCKLE ASSEMBLY CAN CORRODE. THIS DOES NOT COMPLY WITH FMVSS 213, "CHILD RESTRAINT SYSTEMS." ALSO, THE LABEL WITH USE AND SAFETY INSTRUCTIONS IS MISSING FROM THE PLAYSKOOL MODEL. Consequences: BUCKLE ASSEMBLY CORROSION COULD AFFECT THE SAFETYPERFORMANCE OF THE CHILD RESTRAINT. THE MISSING LABEL MAY CAUSE IMPROPER USEOF THE CHILD SAFETY SEAT. Remedy: KOLCRAFT WILL PROVIDE OWNERS WITH A FREE REPLACEMENT HARNESS ASSEMBLY AND INSTALLATION INSTRUCTIONS. OWNERS OF THE AFFECTED CHILD SEATS SHOULD CALL KOLCRAFT TOLL-FREE AT 1-800-453-7673, TO OBTAIN A NEW REPLACEMENT HARNESS ASSEMBLY. Notes: KOLCRAFT ENTERPRISES, INC. Potential Car Seats Affected: 307017
Dec 29, 2008 | Kolcraft Universal 46250L-N
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
The straps are too tight on my child
Ok. First don't panic, I did the same thing with mine! lol. In the front of the seat where your childs legs hang, there is a velco flap. Lift it up and you'll see a metal button(but it doesn't look like a button). Push it in and at the same time pull one of the shoulder straps. This will loosen the strap. Then adjust accordingly. If you remove the back plastic piece you will see all the straps underneath if you want to eventually replace them. You can also adjust the height from the back if needed. Good Luck!
Oct 08, 2008 | Eddie Bauer 3-In-1 with Latch
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Baby Gear Logo
125 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
