Question about Kenmore 22422 Top Load Washer
Kemore Won't Agitate
Just moved cross country, offloaded the washing machine and started it up. The basin filled to the level, but that's it. You can reset the volume and it will fill to the desired level, but that's it. I wonder if something got jarred in transport?
  • klsmithson Aug 06, 2008
    The water won't drain from ours.... help!!!!
  • wgomez92102 Aug 18, 2008
    I have a Kenmore 70 series, Heavy Duty/Super Capacity washer. It fills up with water & then does nothing. The lid is shut & the electrical outlet is working properly. We bought it 2 years used about 7 months ago. Has worked fine until just yesterday :( Any solutions?
    Genius:
  • 1,028 Answers
Ck lid switch raise lid and slowly close listen for slight click if none heard switch is not making depending on model some switches are on right side and has a small opening where lid strike hits it or could be underneath console area
Posted on Aug 07, 2008
Why my washing machine fortress FFW816B only fills water but do not start to wash and agitate?
problem program board is not progressing after the water level switch turns off the water and tells the board to move the cycle on
Nov 12, 2017 | Washing Machines
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
May 17, 2012 | Whirlpool Washing Machines
The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Oct 30, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Won't stop filling basin and doesn't agitate.
check your pressure level hose. it probably pulled off at the tub or the pressure switch
May 18, 2009 | Hotpoint VBXR1090D Top Load Washer
Kemore 90 Serieswashing machine fills and spins but won't agitate
Remove the agitator and see if the agitator shaft moves during agitate. If it moves then the agitator spline is worn or the agitator dogs are worn and the top half of the agitator will not work. If no results then the gearcase would have to be replaced
Dec 30, 2008 | Kenmore 24032\24036 Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine fills, but won't agitate
sound like the lid switch is open, if that doesn;t fix it try the water level switch
Mar 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 22422 Top Load Washer Logo
42 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
