Question about Rimage 2000i Burner
My Rimage 2000i is not diplaying no info. The peinter turns on but the Drives are not coming on.
  • Rimage Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 08, 2011
Rimage 2000i driver
no drivers needed.
contact Rimage if you have a problem
http://www.rimage.com/gb/contact-us.html
Jan 30, 2015 | Rimage 2000i CDR 2 (52X), CD Duplicator...
Rimage 2000i is getting
Check its memory and i think it can solve the problem.
Performance Chip
Aug 28, 2012 | Rimage 2000i CDR 2 (52X), CD Duplicator...
The Rimage 2000i recorder leaves streak marks on the underside of the disc where the information is recorded; thus when attempting to playback the DVD, the player cannot read it.
Hello pwilford,
The most common cause for this issue is dirt and dust build up on the pivot tray. The pivot tray is the plastic piece the disc slides across when it is done printing. Clean this really well with some Formula 409 and it should "clean up" your issue.
Jan 14, 2011 | Rimage 2000i Burner
My Rimage 2000i will not begin production of cd burn/print. Says there are no production servers active on cluster
Hello B13Designs,
If you receive a "No Production Server Active" message when using QuickDisc, make sure that the Production Server status is set to Active, Processing orders in Rimage System Manager. Once the Production Server is set to this status, jobs can be processed.
1. Open Rimage System Manager.
2. Select Production Server. Production Server status information displays in the right panel, next to the Production Servericon.
3. If Production Server is paused or stopped, press the play button. Production Server starts.
If this does not fix your problem, feel free to give our support line a call @ 1-800-553-8312 (Option 2).
Thanks!
Nov 18, 2010 | Rimage 2000i (530101320) DVD±R Burner
Target line has no recorders: 103
Hello carl vicary ,
We at Rimage value you as a customer and are equally concerned when you are experiencing issues with your Rimage Unit. To better serve you, please call our Support Technicians at 1-800-553-8312 (Option 2) Monday through Friday 7:30 AM - 5:30 PM CST and we will be happy to further assist you.
Nov 16, 2010 | Rimage 2000i (530101320) DVD±R Burner
I've lost my software...
Try the Rimage website. If your software is not there for download, call them.
May 21, 2009 | Rimage 360i CD/DVD Publisher Built in 4800...
Rejected discs
I had the same problem, with rejections getting more and more frequent. In the end replacing the DVD burners fixed the problem. Apparently, the red lasers that burn the cd surface fade with use. They are still fine reading the disk at low power, but burning at high power becomes progressively more hit-and-miss.
Jan 08, 2007 | Rimage 2000i CDR 2 (52X), CD Duplicator...
Rimage 2000i Burner Logo
239 people viewed this question
Top Rimage Computers & Internet Experts
David Payne
David Payne
Are you a Rimage Computer and Internet Expert? Answer questions, earn points and help others
