Question about Whirlpool Duet GHW9150P Front Load Washer
Spin light is flashing 1min left in cycle door
Spin light is flashing 1min left in cycle door remains locked after many minutes tried trouble shooting suggestions unplugged machine still can't open door
  • Whirlpool Master
  • 8,220 Answers
How do I get the door to open when still locked after normal cycle stopped with 1 minute left?
Try putting it through another cycle and see if it is still going to stay locked. That would seem like a timer problem. The door should only be locked normally, as I see it, when there is power applied to the locking solenoid so it should not remain locked with no power. You might call a maytag dealer and ask a sales or service person about this also.
Sep 08, 2014 | Maytag Washing Machines
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
During the spinning cycle machine makes grunting noise and it doesn't spin. After few minutes of only noise all the lights on the dial are flashing and it doesn't do anything else. The doors are...
Sounds like you have some thing caught in the drum and/or drum bearing has give up the ghost---another thought is the drum brake is being applied while trying to spin--something could be out of sequence with timer and/or wires crossed/shorted causing functions at wrong time---can you spin it when it's off ?? the reason being you can't open the door while running is a safety factor--water doesn't run on floor--somebody getting arm caught in drum etc etc----do you have the operating manual--if so does it have trouble shooting section---to check this out while operating is a very very dangerous situation---this better left to a professional do to the machine being able to mutilate or dismember parts of you.
May 31, 2017 | Kenmore HE2 Plus Front Load Washer
Control lock light will not go off.
Do you have any error codes?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
850 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
