Question about Sennheiser HD 238 Headphones
I had working Sennheiser Hd 238 precision headphones for about for months and always kept them in their case however soon after they soon went very crackly and I had to hold the wire or apply pressure on it to get the sound otherwise I heard nothing or just crackling one year on they still do it any advice . PS the warranty has already expired and there is no receipt.
  • 40 Answers
Where exactly do you have to hold? If in the middle of wire somewhere, I have no idea what can be wrong. However, the problem is most likely in damaged wire or connection of it. Most likely its near the plug in part. If you know how to solder, just cut the wire few centimeters from damaged place. Best way to fix problems near plug is to cut it off and solder new one.
Posted on Apr 08, 2011
I need ear pads of sennheiser hd 470 in banglore...i need it urgent pls help.......pls let me know as soon as possible
Spare parts for these headphones are available at the following website
http://www.custom-cable.co.uk/sennheiser-hd400-hd470-replacement-earpads-black.html
Regards
Jul 28, 2011 | Sennheiser HD470 Headset
The Left speaker has stopped working and moving around the cable does not fix it, what can I do?
HELLO I ALSO HAVE HD238 AND I FIGURED WHY THE ONE SPEAKER PLAYS THATS BECAUSE THE COMPANY WANTS TO MAKE IT EASY TO BREAK-DAMAGE-DESTROYED
IF YOU OPEN THE ONE SPEAKER YOU WILL SEE THAT THE CONNECTION BETWEEN THE TO POLES IS WITH A HAIR OF A CABLE AND BY THAT WITH THE SIMPLEST DROP OF THE HEADPHONES CAN CUT.
NOW I AM TRYING TO PUT NEW WIRE "HAIR" BUT IT IS VERY DIFFICULT BECAUSE I WILL PROBABLY MELT THE PLASTIC OR DESTROY THE SPEAKER AN OPTION I PROPOSE IS TO STICK THE WIRE HAIR WITH GLUE
Jul 06, 2011 | Sennheiser HD 238 Headphones
I am searching a sennheiser hd 238 spare cable but can't find it.... Any suggestions?
It appears that the 238 has a cable connected to one headphone only.
If this is the case, try your existing cable.
If both ends look identical and plug into your music player easily, you could try any audio cable with
3.5mm mini plugs on each end.
I have used such to drive low powered speakers, and discount the hype about audio cables.
If you look on eBay, entering "sennheiser hd cable", a number of sellers have cables, none specifically claimed to fit.
The cheapest among the first few entries advising the cable has a 3.5mm plug at one end and a 2.5 mm plug at the other. If my first suggestion is unworkable, this will probably work.
Alternatively you could try to find one locally, to test for fit before purchase.
Check the other sellers for a look at pictures and possibly details if I got it wrong at the start and your cable has 2 connectors at one end.
If all else fails, take your headphones to you local electronics supplier, get plugs that fit and get a good friend with a soldering iron to make you up a cable.
Feb 03, 2011 | Sennheiser Audio Players & Recorders
The right speaker of my sennheiser hd 435 is not working while the left one is working just fine. I checked the wires inside and found nothing amiss.
Hi, after checking the wire and no damaged,it means that the speaker itself is damaged.You can replace it if can get a spare around repair stores around you.
Thanks for using fixya...
Oct 27, 2010 | Sennheiser HD 435 Consumer Headphones
I have Sennheiser HD 570 headphones. The plastic headband is broken where it attaches to the headphone. Can I order a new plastic headband and is difficult to replace?
That part isn't available from Sennheiser. But they are pretty maintainable, if you're good with mechanical things, and if you can come up with another set of the same headphones for parts.
If you've already replaced your headphones and want to rid yourself of the broken 570's, I'm looking for a set to scrounge for parts.
Aug 17, 2010 | Sennheiser HD 570 Consumer Headphones
My left channel in sennheiser hd 465 is not working and will not play any sounds. please help!
As long as it is NOT a wireless or noise cancel type, try looking at my tip on headphones dodgy cable/plug problems.
Aug 09, 2010 | Sennheiser HD 465 Headphones
Sennheiser HD 238 Headphones Logo
243 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
