Question about Car Audio & Video
I had the head gaskets replaced in my car, since my radio will come on and once in a while, I get sound, other times there is no sound at all. What could the problem be?
    Novelist:
  • 117 Answers
Well, it's pretty unlikely that having your engine head gasket replaced has anything to do with your stereo intermittently working so I would be looking to remove the head unit from the dashboard and make sure that all of the speaker cable connections are correctly and securely attached to the back of the unit. It might also be worth checking the terminals on the back of the speakers as one of the connectors may have worked loose.
Posted on Apr 08, 2011
What would make a 1995 ford ranger not idle after replacing head gasket
Best have it checked by a garage. You replaced head gasket was the timing put back absolutely correctly?
Have you checked the engine compression?
Did you check the head for warping / air tightness?
Were all the ancilaies replaced correctly?
There could be anything causing the problem
Jul 03, 2015 | Ford Cars & Trucks
After new head gasket installed, why won't it start?
Once you have taken an engine apart to replace the head gasket, there are a multitude of connections and items that could be causing starting problems. Did you ask the mechanic who replaced the head gasket?
Jun 15, 2015 | Cars & Trucks
My 97 oldsmobile cutlass supreme is leaking coolant and over heating, why? I also noticed tht the oil is milky. Please help
The most likely source of your problem is NOT a head gasket or cracked head, but the black plastic plenum or "upper intake manifold". These GM engines tend to melt, crack, or warp the plenum because of the hot EGR tube sticking up through the plastic.
If water is getting into your oil (milky looking), your lower intake manifold gasket is probably cracked. Once the plenum is off the engine, there are only about a dozen bolts holding the lower intake manifold on. When you replace the gasket, it is recommended to use an ALL METAL gasket with rubber seals to prevent this from happening again. The metal gaskets cost about $80 where as the plastic ones that are prone to breaking cost about $45. Better to fix it right once than to do it wrong several times.
Also, if you are still using Dexcool coolant (orangeish), be sure to change it every two years or so as it does bad things to seals when it gets old.
Nov 13, 2009 | 1997 Oldsmobile Cutlass Supreme
After changing a head gasket, car won't start. it
Sounds like the timing is off. Re-check your timing marks. If it has a timing belt it may be a few teeth of and getting no compression. Why did you need to replace the head gasket? If you overheated the motor it may have cracked the head causing a weird noise, but I would start with the timing first. That is the cheapest test.
Oct 03, 2009 | 1998 Chevrolet Cavalier
Need expertise answer
How many miles are on the car and did you replace the timing chain and tensioner?
Jun 02, 2009 | 1999 Ford Explorer
Need to know solution
replace the chain tensioners. There is a problem with the original design
Injection pump trouble
This all sounds like it is a blown head gasket, I would not worry about the top cover and the speed control, until you get the head gasket fixed. The head gasket not being replaced will mean a new motor
Apr 29, 2009 | Volkswagen Rabbit Cars & Trucks
Smoke problem
Sounds as though you have water in the oil. The white smoke is the steam. Check your oil by taking the dip stick out and if it looks like mayonnaise then your head gasket will need replacing. Once the head is off the engine block, there is no way safely to say how much work will be needed on the cylinder head. If the head gasket has blown then you will need to fit a new timing belt also.
Nov 24, 2008 | 1991 Peugeot 405
1992 taurus 3.8 gl 68,000 miles
It is possible that you may only need a tune up. I hope thats it anyway. Which would consist of changing your spark plugs and wires, if you have the distributor model then replace ddistributor cap and rotor button. Now if this doesnt work you may have a more severe problem. Which sounds to me that you have a blown head gasket or a cracked head. See when you first start your car the heads or gasket is cold, which would leave your car running great but as the car gets hot the heads and gaskets expand, therefore letting valuable compression escape.. Hope this helps these are very valuable tips..
Jul 28, 2008 | 1992 Ford Taurus
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
