Question about Casio FX-9860G Graphic Calculator
I am unable to solve determinant of matrix. - Casio FX-9860G Graphic Calculator
  • Casio Master
  • 7,993 Answers
Here is enough to get you started and a little more.
Read the post ant consult your calculator manual.
How to calculate the determinant of a (square, non-singular) matrix is described in part B
A. Define a matrix (Create it)
  1. Turn calculator ON.
  2. Press Menu,select the MAT icon and press [EXE]
  3. You see a list of possible matrix labels (A, B, C,D,E,F)
  4. All that have not been created have a "none" to their right
  5. Highlight a matrix name and press the right arrow. Where there was "none" , you have a template 0x0.
  6. That is where you specify the dimensions (mxn). example. 2x2
  7. Enter the first dimension and press [EXE]
  8. Enter the 2nd dimension and press [EXE]
  9. A matrix template opens where you enter the coefficients left to right and up down.
  10. After each coefficient press [EXE]. Cursor moves to the next coefficient, etc.
Press [SHIFT][QUIT] to return to the list of matrices to create new ones
B Operations on matrices
Once you have one matrix, you can do operations on it: Calculate the determinant (if matrix is square), calculate its inverse, transpose, augment it, fill it, etc..
  1. These operations are accessed as follows.
  2. Quit the matrix editor by pressing [Menu] and selecting the [Run] application.
  3. Press [OPTN][F2:MAT]
  4. You have the menus Mat,M(atrix)->L(ist), Det(erminant), Trn (transpose), Aug(ment) ->, Iden(tity),Dim(ension) Fill
Example : calculate the determinant of a matrix A (already defined).
  1. You press the [OPTN][F2:MAT] key sequence (just above)
  2. Press [F3:Det]; the command det is displayed on screen.
  3. Press [F1:Mat] the identifier Mat is displayed.
  4. Press [ALPHA] A; screen display det Mat A.
  5. Press [EXE] to get the value of the determinant.
C. Square of Matrix A
[OPTN][F2:MAT] (MAT) [Alpha] A ^2 [EXE]
D. Product of two compatible matrices MatAXMatB
[OPTN][F2:MAT] (MAT) [Alpha] A [*] (MAT) [ALPHA] B [EXE]
Part E Invert a (square, non singular) matrix that was already defined.
Press [OPTN] [F2:Mat] to open a screen similar to the one in capture above
Press [F1:Mat] to have identifier Mat displayed.
Enter the name of the matrix by pressing [ALPHA] A, for example.
Press [SHIFT] [ ) ] activate the (x^-1) key.
This is what you might see (with parentheses and without).
Press [EXE] button to calculate the inverse.
Posted on Apr 09, 2011
L want to know an example of a4 by 4 matrix determinant
One example: the determinant of a 4x4 identity matrix is 1.
Use the matrix editor to create a 4x4 matrix with 1s along the main diagonal (upper-left to lower-right) and 0s elsewhere. Then use the det() function to calculate the determinant of this matrix.
Sep 07, 2013 | Texas Instruments TI-83 Plus Calculator
How to solve matrix
What do you mean by "solve matrix"? Do you want its determinant? Its inverse? The eigenvalues and eigenvector? Solve a system of linear equations?
Jun 11, 2013 | Casio FC-200V Scientific Calculator
How to find the determinant by Sharp ELW516 Scientific Calculator
Press the MODE key. and press 4 for MATRIX.
To enter a matrix press the MATH button and choose 2 for EDIT. Determine the size of your matrix by typing in the row x column value (maximum 4). Then press =. Type in the values in your matrix. After each value press = to move to the next part of the table. Once your matrix is complete press ON and then the MATH button. This time choose 4 for STORE. Select the matrix name you would like to store your matrix in - for example choose 0 for matA. Now press MATH and press the down arrow key once. Select 6 for CALC and choose 0 for det (determinant). Then input the matrix you want the determinant of by pressing MATH and 1 for MATRIX. Select the matrix you would like to work with eg, matA and press then press =.
Aug 22, 2012 | Sharp ELW516 Scientific Calculator
I'm having a hard time trying to solve matrices on my Casio calculator. I can enter the deminsions of the matrix, but I don't know how to solve them.
Read the post ant consult your calculator manual. The screen captures below may not look exactly as your calculator but the steps are identical.
Apr 20, 2011 | Casio FX-9750GPlus Calculator
How to find rank of matrix using casio991 es??
The FX-991ES offers simple matrix operations like basic arithmetic, plus the slightly more complex operations determinant and inversion. Furthermore, it is limited to matrices with a maximum size of three rows and three columns.
The rank of a matrix is defined as the number of linearly independent row or column vectors. You can perform a simple partial test for square matrices by calculating the determinant of the matrix:
  1. Enter the matrix into matrix variable MatA.
  2. Press [SHIFT] [4] [7] [SHIFT] [4] [3] [)] [=]
The display now should show det(MatA) and the determinant of the matrix in the result. If the determinant is not 0, the rank of the matrix equals the dimension of the matrix, otherwise the rank is less than the dimension.
Unfortunately, this is all support the calculator offers. For small matrices (i.e. 4x4 or smaller), you should familiarize yourself with the Gau? Elimination Method algorithm for solving linear equation systems. It is a two-step procedure where a matrix first is converted to its row echelon form, and second to row canonical form to solve the LES.
You need to follow the algorithm only through the first part, the number of non-zero rows after this step equals the rank of the matrix. With a little exercise you will be able to do it faster on paper than trying to do it with your calculator only.
For larger matrices I suggest to use a PC with more powerful math software (Maple, Mathematica, ...) or, if you know some basic computer programming, just write the necessary program yourself, which is also a very good exercise both in programming and understanding the algorithm.
Jan 16, 2011 | Casio FX-115ES Scientific Calculator
How do I solve a matrix? I have the manual but do not understand it
I will not try to guess what you mean by "solve a matrix", but I believe that what follows will help you.
  1. First you must set Matrix calculation: Press [MODE][6:Matrix].
  2. Then by entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix (mxn].
  3. Once finished entering the matrix you clear the screen.
  4. The operations on A SINGLE matrix are available by pressing [Shift][Matrix].
  5. The choices are
  • [1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
  • [2:Data] enter values in a matrix
  • [3:MatA] access Matrix A
  • [4:MatB] access Matrix B
  • [5:MatC] access matrix C
  • [6:MatAns] access the Answer Matrix (the last matrix calculated)
  • [7:det] Calculate the determinant of a matrix already defined
  • [8:Trn] The transpose of a matrix already defined
Once you have created a square matrix, for example matA.
You press
[Shift][Matrix] [7:det] [SHIFT][MATRIX][3:MatA], close the parenthesis and press [ENTER].
If you have defined two similar matrices (same number of row and same number of columns) you can ADD them or subtract them. The operation keys are Plus and Minus as for any number.
To multiply you use the multiplication sign. The matrices must be compatible (mxn) multiplied by (nxk).
If you know the theory behind systems of linear equations you can use matrices to solve the systems.
Nov 26, 2010 | Casio FX-115ES Scientific Calculator
How do i solve a matrix?
What do you mean by "solve a matrix"? Find the inverse? Find the determinant? Find the solution to a system of linear equations? Within limits the fx-115ES can do any of these and more.
The procedures are described in the "Matrix Calculations" section of the manual. If you still have problems, please reply to this post specifying what you want to do.
Nov 18, 2010 | Casio FX-115ES Scientific Calculator
I want to solve a 3x3 determinant, but what should be the parameter in the det() function??
The parameter is the name of the matrix, available from the matrix menu SHIFT 4.
Nov 09, 2010 | Casio FX-115ES Scientific Calculator
I want to solve my determinent of matrix A
Assuming you have a square matrix in MatA, press SHIFT [MATRIX] 7 SHIFT [MATRIX] 3 EXE
[MATRIX] is the shifted function of the 4 key. MATRIX 7 invokes the determinant function and MATRIX 3 names MatA
Oct 23, 2010 | Casio FX-115ES Scientific Calculator
How to make program of finfing the determinant of m*n matrix in C coding
I solve your problem but there is a little mistake that I can't find but maybe you can so here what I wrote:
#include <graphics.h>
#include <stdlib.h>
#include <stdio.h>
#include <conio.h>
#include <dos.h>
#include <math.h>
#define n 3
typedef struct
double A[n][n];
int size;
}Matrix;
double det(Matrix mat);
Matrix cut(Matrix mat, int x);
int main(void)
clrscr();
double d;
Matrix mat;
mat.size=n;
mat.A[0][0]=1;
mat.A[0][1]=2;
mat.A[0][2]=3;
mat.A[1][0]=4;
mat.A[1][1]=4;
mat.A[1][2]=6;
mat.A[2][0]=7;
mat.A[2][1]=8;
mat.A[2][2]=9;
d=det(mat);
printf("%d",d);
getch();
return 0;
double d=0;
if(mat.size>2)
for(int i=0;i<mat.size;i++)
d+=pow(-1,i)*mat.A[0][i]*det(cut(mat,i));
else
d=mat.A[0][0]*mat.A[1][1]-mat.A[0][1]*mat.A[1][0];
return d;
Matrix cutmat;
cutmat.size=mat.size-1;
for(int i=0;i<cutmat.size;i++)
for(int j=0;j<cutmat.size;j++)
if(j<x)
cutmat.A[i][j]=mat.A[i+1][j];
else
cutmat.A[i][j]=mat.A[i+1][j+1];
return cutmat;
Rate me if it helped!
And if you find the mistake please tell me where thanks.
Mar 06, 2009 | Intel Computers & Internet
Casio FX-9860G Graphic Calculator Logo
521 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
