Question about Zizzle Toys
Zizzle "Hooked on Phonics" sound
  • cknight187 Apr 10, 2011
    Your above instructions don't appear to apply to the Zizzle Hooked on Phonics Electronic Learning device for children which I was trying to describe in my initial inquiry. Your solutions sound like those for a product or device controlled by or through a Microsoft software operating system??? Can you refer my inquiry to the proper expert if other than yourself? Thanks for helping me and have a blessed day! Charley Knight
    Genius:
  • 1,157 Answers
Hi Charley,
Based on your concern, you already reset the device by pressing the reset button on the back but to no avail. Resetting a device will bring back the factory state like when you first got the unit. I suspected that this is a hardware failure. If the device is still in warranty, I recommend to contact the manufacturer and let them set a free repair or replacement. You can email Zizzle via info@zizzle.com and let them know about your issue.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 11, 2011
  • 794 Answers
Hi cknight187,
You may try the troubleshooting below that can be done to get the sound to work again with the Zizzle "Hooke on Phonics".
1. Use the steps below to change the sound card to something other than the Game Compatible setting.
  • Click on Start, Settings, and Control Panel
  • Double click on Multimedia (or Sounds and Multimedia in Windows Me, or Sounds and Audio Devices in XP)
  • Click the Audio tab.
  • Under the Playback section, look for the Preferred Device.
  • Under Preferred Device, click on the arrow pointing down and select a device other than Game Compatible..
  • Click on the Apply button, then the Ok button.
  • Close the Control Panel.
2. If that does not correct the issue, you can bypass Microsoft DirectSound, and play audio directly through your sound card.
  • Click Start, and then Run.
  • Type DxDiag and click OK
  • Click the Sound tab
  • Under DirectX features, you will see the Hardware Sound Acceleration Level.
  • Move the slider bar to the left or right until it says Basic acceleration and click Exit.
3. If you are still experiencing problems, check the following:
- Check that your speakers are turned on and connected to your computer.
- You can verify that your sound system is working by playing any audio file.
- Make sure you've closed any other programs that use audio, such as RealAudio, WinAmp, or Napster.
- If the audio still doesn't work properly, update the drivers for your audio card from the manufacturer's Web site.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 10, 2011
Projection TV no picture flashing horiz arcs across top of screen sound okay
You will need convergence work to this unit. Not cheap.(Not recommended for DIY unless already experienced in this type work). Might contact a local servicer experienced with Toshiba & see if they can give you a quote over the phone. Be sure you are sitting.
This is probably a good time to consider entering the 21st century & look at LCD or LED flat screens.
Jul 24, 2014 | Toshiba Televison & Video
Panasonic VIERA TC-L42U5 42-Inch 1080p 60Hz Full HD LCD TV (Screen doesn't work)
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 01, 2017 | Panasonic Televison & Video
I have a sharp aquos LC-C3234U. It had the blinking green light problem. I followed the first couple of steps ((vol up, chl down) and it now comes on with a solid green light. I have sound, but no
Search on eBay for RUNTKA448WJQZ and buy one.
I mean for $35 delivered it isn't much of an investment.
Don't forget to rate me if it works (and forget me if it doesn't; but it will).
Oct 12, 2012 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
How to fix
tried to hooked up with other monitor just to ensure if the cause is your pc. if the monitor doesn't receive signal it will goes to stand by mode.
Sep 07, 2012 | HP W2207H 22-inch Widescreen LCD Monitor
Laptop broken screen... plugged in Dell monitor,still doesnt work
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 03, 2012 | Computers & Internet
I have a insignia ns-lcd37-09 tv.The screen suddenly turned green.I can here sound but no picture.can you help?
Change input device to some other which you know works for sure. If problem persists, try changing the channel. If you notice same problem, this may need attention by a qualified service technician.
Jul 21, 2012 | Insignia NS-LCD37 37 in. LCD TV
My screen in in dark negative and cant see whats on
Hello Mandy,
A dim screen or one that is black or suddenly blacks out, it might just be a power or battery issue. Do some troubleshooting. Check the power connection and see if its loose, then unplug it and take out the battery pack, then press the ON button for 20 seconds or so. Then put the battery back in. If that doesn`t work, you could have a burned out visual back light or a loose inverter. If the problem doesn`t go away, don`t open the LCD monitor and try to fix it yourself as that will void the warranty. Sorry for the late reply.
Thanks,Reymond
Nov 11, 2011 | Toshiba Computers & Internet
My TV turns on, but the screen doesn't light up at all. So the green "on" light is on, but there is absolutely no visual. Any ideas?
solution
step 1: At first test your fly back Transformer
step 2 : Test the tube back side bulb and video I.C.
Jul 25, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
"Clean" light keeps flashing. Machine doesn't
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Kenmore Dishwashers
Toys Logo
75 people viewed this question
Top Zizzle Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Zizzle Toy Expert? Answer questions, earn points and help others
