Question about Metra Kia Din Mount Sportage/Sephia
NOBODY in any articles on the internet has tried to explain why the freon is coming out of inside vents .Apparently according to the mechanic I go to the problem could occur by a leak coming from a small radiator under the dashboard that has to come out. (my car a KIA SPORTAGE 2009 Diesel) An expensive bit of work. We have replace the freon 3 times and nothing is leaking from under the engine bonnet. ANY IDEAS. Thank you
Air not blowing out dash vents
The evaporator coil is icing shut. Check the freon level and make sure there are no air leaks in the system.
May 02, 2013 | Vehicle Parts & Accessories
Air blows cold in rear but warm in front vents.
If it is cold in the rear, that eliminates the "freon" part of the system. (It apparently has enough freon and the compressor is apparently working.)
So that leaves you with a blend-air door problem on the front A/C unit. That may be a blend-air door actuator, a broken blend-air door, or a faulty control head. (Proper diagnosis required)
May 18, 2012 | 2002 Mercury Villager
I have a 1993 honda accord 10th anniversary edition, ok when i turn on the a/c the green light comes on and the compressor kicks on you can feel a change in the drive and the clutch engages i seen it...
Then your vent control is not working, since this is a 1993 you would be able to see the filter drier ice up on the enternal area.Also make sure the heater control cable is not engage
Jun 04, 2011 | 1993 Honda Accord
I have a 2002 honda accord ex and i have freon on the car's a/c, it works cold from time to time, I noticed that I sometimes have to turn off the a/c button and then back on and it later on starts...
Low freon is the problem. And if you have enough freon then the high pressure switch can be going bad. If the switch is bad replace the expansion vavle at this time.
May 24, 2011 | 2002 Honda Accord
Honda Accord LX has bad temperature control switch? I just got my A/C recharge with new freons and it is working. Before it was just blowing hot air when A/C is switch on and the A/C control knob turned to...
  1. what year model is accord?
  2. there are several doors in the air box
  3. blend door (hot cold)
  4. mode door (defrost, floor, vent)
  5. recirculation door (outside air)
  6. if the control mechanism is defective. the tech may have reached under the dash and manually opened the blend door.
  7. which control knob does not work mode or temp?
Jul 26, 2010 | 1994 Honda Accord
2 month long issue...RUUD Achiever 1.5 Ton 10 Seer Heat Pump
Rather than have him replace the control board first, ask him to remove all the freon and weigh it. He then can reuse the Freon that came out of your system put back in at the exact charge that the rating plate calls for. He will add a bit more to compensate for any length of refrigerant lines from the outside unit to the inside unit. Now this will bring us to factory specs. If the unit continues to act up, then try another board. I am not a big fan of replacing parts unless other alternative ways have been tried. If he is not willing to try what you ask, why is he there? As far as if something is taking out the control board, have him clean and reconnect all ground connections and inspect the thermostat connections both on the inside unit and the outside unit. Is lightning a factor in your area?
Mar 11, 2010 | Ruud Matching Split Air Conditioner
2003 accord air conditioner
This is a common problem when the AC system has a low charge.
If this is the case, you have a leak somewhere. Do not try to fix it yourself without the proper equipment.
May 21, 2009 | 2006 Honda Accord
I ad this problem fixed and it cost $35. Apparently, this happens when the Freon level is low for some reason. They refilled the Freon and now I have AC on both sides. Don't forget to replace the internal filter in the glove box.
Feb 17, 2009 | 2003 Honda Accord
Heating Element no longer working
Hi Paige
Expect to pay $30 for the kit. it's a 279816 and will take some level of mechanical and technical ability to locate it and affect the repair. This kit addresses 2 issues and should be installed by a certified technician. Your owners manual has a big WARNING!!! block saying what not to do, like Don't use plastic or foil venting. But nobody reads manuals anyway. Most likely you have an aluminum foil colored accordian style vent pipe. That's what caused your thermostats to burn out. Get your drier checked out by a certified tech for safety. Afterwards, keep that vent, clean clean clean and install a sure vent from Whirlpool 4396028. 16,000 homes each year have fires from improperly vented driers according to the U.S. Dept of Consumer Safety.
Dec 10, 2008 | KitchenAid KEYS750LQ Electric Dryer
Metra Kia Din Mount Sportage/Sephia Logo
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
