Question about Whirlpool Dishwashers
My Whirlpool Quiet Partner II dishwasher will not start. Thye Heated Dry Light is flashing and presssing the Cancel button does not resolve the matter. Also pressing the Heated Dry button for 4 seconds does not resolve the matter either. Please help. Thanks Jim Sparks
    President:
  • 2,468 Answers
Have you tried powering it down,shutting off power to the unit for 15 minutes,sometimes the electronics will glitch as a computer does,if this is to no avail,then try removing all connections from the interface(control panel) to the main control panel and clean each cable and re-plug in,then see if this solves your problem,otherwise it may be time to replace either the interface or main control board
Posted on Apr 08, 2011
How to reset wirlpool quiet dishwasher
To reset it, you will have to have the door open. It can not be latched. Press "Heated Dry," "Normal," "Heated Dry," "Normal" within three seconds of the first pressed button. Now close the door, this should reset your dishwasher.17 Dec 2012
SOLVED: Dishwasher whirlpool quiet partner I push start button - iFixit
https://www.ifixit.com/.../Dishwasher+whirlpool+quiet+partner+I+push+start+button+not...
or try this link.
How to reset wirlpool quiet dishwasher Google Search
Oct 28, 2017 | Dishwashers
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Clean light flashing Quiet Partner V
do the heated dry and hi temp and then hitr cancel. you know what this means?! you have a bad heating element usually. call for service this should be a covered repair if it is only 6 months old
Mar 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner 980
Bad control board ,replace it.
May 26, 2008 | Dishwashers
clean light blinkin???? ry pushing the sanirinse-heated dry--sanirinse--heated dry. tha tshould put in diagnostic mode, there also should be a trouble shooter underthe lower acess panel
Apr 09, 2008 | Dishwashers
Whirlpool dishwasher # quiet partner II
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
Jan 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
37 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
