Question about JVC RX-6042 Receiver
The unit keeps switchng from linear PCM to auto digital and back again. The sound keeps cutting out when it switches to linear PCM. Do I need to get a new unit?
4 Suggested Answers
renosean
  • 492 Answers
SOURCE: used digital optical connection on amp from
pcm linear refers to how the tv is communicating with the amplifier. Follow the steps in your tv manual to ensure the tv is capable and setup for output of dolby and or dts, then try a dvd or a hd channel to test it
Posted on Jan 11, 2010
Testimonial: "Thank You"
  • 11800 Answers
SOURCE: Lost sound from all of
4 power surges and the receiver is still functional? Wow, that's a good quality one. Unfortunately the sound processor didn't survived and, since it's soldered on the mainboard directly, it can't be replaced. There's only one thing you can do - replace the mainboard. But i don't think it's worth it, for the same money you can buy a new one.
So either use it as is or replace it.
Posted on Oct 18, 2010
bmccoy1234
  • 4 Answers
SOURCE: 5.1 surround sound will not
You should try pressing the surround on/off button or the speakers on/off button
Posted on Feb 27, 2011
How do I fix my PCM-M10 Sony audio recorder? I haven't changed the batteries for a while and it looks like they are corroded. The recorder won't switch on. Is it fixable?
Carefully remove the batteries and remove the corrosion. Outdoor is better to reduce being exposed by breathing it in. After removing corrosion, add new batteries and try again.
Oct 03, 2015 | Sony Pcm-d50 Portable Linear Pcm Recorder
Optical Audio Output Formats for PS3
look in your receivers manual or download it using a google search
Dec 23, 2013 | Kenwood VR-606 Receiver
My component is in LINEAR PCM MODE when it start playing dvd/cd no sound comes out. while in CASSETTE TAPE, it has a sound. i want to know what is this LINEAR PCM, coz i notice, when i turn FM it has a...
LPCM is for digital sources ONLY. Your cassette wouldn't be digital would it? FM, being an internal source on your unidentified receiver CAN'T be wired or configured incorrectly. Crack the manual open and find out how to set the parameters for all the digital inputs, then connect and select an analog input for the tape.
Jun 24, 2011 | Audio Players & Recorders
5.1 surround sound will not work. Only showing digital auto and linear pcm.
Jan 02, 2011 | JVC RX-6018V Receiver
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
PS3 connection to Yamaha HTR-6130 Av Receiver
URNOTME is right. HDMI is great and all, but wish i would have spent a few more dollars on a unit that supports switching. htr-6130 does pass-through, so you have to use seperate audio connections. really there is no use running HDMI into the receiver and then into the receiver and THEN to the tv. just go straight to the tv, then run your audio either optical (best) or coaxial.
Nov 28, 2008 | Audio Players & Recorders
JVC RX-702B only detects linear PCM, not multi-channel digital
Like most receivers it will probably have settings for the sound output. Once you find this it will be just a matter of switching the system over to Dolby signals. If you find that it already set like that, try switching the DVD or blue ray player you are using or whatever source, using their sound settings on them. So that both devices are sending and detecting Dolby signals.
If both devices are set correctly then there probably will be a fault in the decoder of the JVC.
Dec 07, 2017 | JVC Audio Players & Recorders
Ps3 sound setting for Acoustic Solutions tv
i had the same problem with my acoustic solutions astv 3619ws, you have to change the settings to:
linear PCM 2 ch. 44.1 khz
linear PCM 2 ch. 48 khz
linear PCM 2 ch. 96 khz
linear PCM 2 ch. 192 khz
you have to unselect all the other settings.
Feb 06, 2008 | Televison & Video
Bad sound through HDMI
Is it only in Games or Movies?
Try checking the cables. (obvious I know but it must be said).
On the XMB (Cross Media Bar), go to settings on the left. Scroll down to "Sound Settings"
Choose "Audio Output Settings", then "HDMI", then "Auto"
If that doesn't fix it then choose manual and the most basic outputs first;
-Linear PCM 2ch. 44.1KHz
and
-Linear PCM 2ch. 48KHz
Depending on your surround sound setup your could get away with other options as well. Fist determine if your setup is 5.1 or 7.1, DTS or Dolby Digital. Then start with the lower KHz settings and work your way up.
Dec 12, 2007 | Sony Playstation 3 (PS3) Console
JVC RX-6042 Receiver Logo
88 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
