Kenmore Front-loading Washer, Model # 417.44142400, approximately 7 years old, vibrates tremendously in spin cycle, sometimes deposits black spots or stripes on laundry, emits foul odor from drum (musty smell).
  • 3 more comments
  • fdscott Apr 08, 2011
    e
    How do I get to the filter and remove it?What about the vibration and the smell?
    Could not find a filter. Do not think I have a bad bearing. Machine is just loud on fast spin. Qwner's manual says it is normal.
    thanks. My wife said it vibrates. i was taking her word for it. Sorry for the confusion. thanks.
    John cross told me how to find filtwer. I liked your vinegar thing. Ran it through. could not find a filter, but with the Englishman's directions found what looked like aflapper valve that was filthy. Hoses at bottom of drum had filty water and black crud in them. Might be the dirt proble. ran the vinegar through. Running a loaad of clothes for a final test. I used a combo of your and Cross's suggestions. if I am satisfied, who decides who gets paid?
    Thank you. on second thought, I do need to check the bearings, but I am going to call a repairman for that.
  • 2,382 Answers
Hi, the tremendous vibration means you have a faulty bearing which needs to be replace or else it would affect and damage the transmission...
Your washer might be very dirt. If you don't clean it regularly, lime deposits can form in the washer and dirt can collect in the washer filter. The dark spots on your clothes could be caused by a dirt washer not properly filtered by the washer filter. Check your washer's filter and remove collected dirt. You can also try running an empty hot water cycle and add a cup of white vinegar. This will effectively remove detergent residues in your washing machine.
Posted on Apr 08, 2011
  • 2 more comments
  • Tunde Autos
    Tunde Autos Apr 08, 2011
  • Tunde Autos
    Hi, if the user manual says it is normal to have such noise on fast spin, then you don't need to bother yourself but if it vibrates tremendously as you have said earlier it is the bearing...
  • Tunde Autos
    Alright........
  • Tunde Autos
    Just accept and rate the solution to confirm i proffered you a solution you were satisfied with....
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
Kenmore front-loading washer, model #417.44142400, vibrates tremendously on Spin cycle, occasionally deposits black spots or stripes on laundry, and the tub emits a foul odor (musty smell). Washer is...
3 things- balance, marks and smells, the latter 2 could be caused by the same thing.
Balance
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
Marks and smells
I'm going to suggest one thing for both of these- check and, if necessary, clean the filter.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem, good luck and please score these accordingly ;-0)
John C
Apr 08, 2011 | Washing Machines
My 7 year old he3 has a terible thumping noise when in the very fast spin cycle it is like the tub is coming out. The spin cycle before last is not as bad. the shock absorber are ok I can take the front of...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 11, 2011 | Kenmore HE2 Plus Front Load Washer
I am having tremendous vibration and noise when in the spin cycle. Serial #XC33113241. Purchased in 2003
Washer Problems
heatman101
Jan 04, 2011 | Frigidaire ATF6000ES Front Load Washer
Vibration
With the age of the machine, although Speed Queen's are built like a tank, the suspension systems are one of the most worked systems on a clothes washer,so, that being said, I would check all related parts of the suspension system, springs,pivot,etc,.these parts do get tired, think of the amount of loads of clothes that you have run through the washer over those 15 years.
Good Luck !
Feb 14, 2010 | Washing Machines
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Hotpoint Aquarius WMA46 1300 , front loader
half loads will vibrate more than full load
check transit bolts are removed
if vibration persists, then fault is probably shock absorbers worn
Sep 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Kenmore Elite Model 44836
Check that the feet are level to the floor as this may cause the vibration. Also set the machine to wool mode this then knows what material you are putting in the machine then should cycle to that material.
Thanks J
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
298 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
