I use one universal charger (GP) for 4 different Photo Camera's and one video camera. All batteries are charged correct. On my charger I need to set the contact points correct for the different batteries, but after I put one on the chatter it becomes charged in a few hours. (I don't need to look for voltage nor for where the plus and minus go.
My advice? Google for universal battery charger for camera's and buy one. I think the charger will serve your next camera too.
You could try to buy a charger from Polaroid, but not only will that be expensive, it could be almost impossible to find the same one you had.
I do use two universal chargers, for my camera's. mine are from GP, but I'm convinced there are other brands to. One charger, I need to adjust the spacing between the contacts, but not tree are chargers, that don't need any adjustment. The voltage needed, is found by the charger, the moment you connect the battery.
Because I do have a Kodak (3,7V) a Canon (3,7 volt) and a Nikon (7,2 volt) I have to adjust, but all batteries are charged every time.
When traveling I only need to take one charger for 2 or 3 different cameras. Next camera? I can leave the charger in the box.
same could go for you too.
You can charge the battery with the charger that came with the camera. Or you can charge the battery with the camera dock. For that to work, you should switch off the camera. While the charging is stopped as soon as you switch on the camera. If you don't have a dock nor a charger, you could buy a new universal battery charger. Several brands do have universal camera battery chargers. Those new chargers sense what voltage your battery needs and will give no more.
You don't say what make or model the camera is, so I can only answer generally. Most cameras, as opposed to most cellphones, do not charge the battery in the camera at all. They are supplied with a separate mains charger- you take the battery out of the camera and put it in the charger. I have a number of cameras with USB connectors, and none of them charge while connected to the computer.
If you bought the camera new, and it came with a charger, then the camera almost certainly needs the charger to charge the battery. If you purchased it used or it was a hand-me-down, and you didn't get a charger, then the seller or giver has probably been remiss. It won't hurt to leave the camera connected to the computer's USB port to see if it will charge, but when that doesn't work, you can find a replacement charger for your camera by searching Amazon with the camera model number and the word "charger". Better, you can get a "universal" charger on Amazon for as little as $4 that will charge any of the small lithium batteries used in cameras and phones (assuming this isn't a huge battery of the kind fitted to older video cameras). I have a universal charger and it is easy to use and has saved me a lot of money as I no longer need to buy a replacement for every type of battery I come across.
Try to find same battery charger or camera and do Cross-Check, hook new charger with camera and confirm charging process and hook your charger in other same camera and confirm is it working? You will rectify the problem unit, either camera or charger.
