Question about Homelite Garden
What is the spark gap for a homelite 240 chainsaw
    Sergeant:
  • 250 Answers
.0025
Posted on Apr 08, 2011
Homelite chainsaw ut 10516 won't start have replaced all electrical parts still no spark why?
Incorrect gap on ignition coil? On/off switch stuck in closed position and grounding out spark?
Mar 30, 2017 | Homelite Garden
How do you check the spark on a Husqvarna 240 chainsaw?
Buy yourself a spark tester from the local chainsaw dealer, these will clip to the cylinder to create an earth, the plug cap fits to the end, it will have a large gap to load the ignition unit, if there is a spark when the engine is cranked the unit is ok.
Aug 08, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Homelite 150 chain saw spark plug gap?
Hi chozen3
Set your gap to .28-.32 for your chainsaw using a round feeler gauge
Please take time to rate me
Sep 03, 2011 | Garden
I have an old homelite super xl saw and what i need to know is the high and low adjustments as well as spark plug gap
For the high and low speed jets turn all the way in and turn counter clockwise 1 1/4 turns to start with and continue a bit more until the saw runs a max speed(go by ear) and idling speed(idle down enough so chain does not spin while finger off triger). For the spark plug gap, go about 20 thousands of an inch. I hope this helps you out.
Jul 15, 2011 | Homelite Garden
Have a 16" Homelite super
Air gap 0.3mm and plug gap 0.5mm
Apr 21, 2011 | Garden
Homelite ut 10695 spark plug gap, gas oil ratio?
Gap the plug at 0.020", and the fuel to oil ratio is 50:1. Be sure to use a modern synthetic saw oil, fresh fuel, and mix in it's own container (don't make up more than a gallon at a time unless your business is sawing). Be sure to shake the container thoroughly each time just before adding fuel mix to the tank to prevent oil starvation. Hope this helps!
Nov 04, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Chainsaw will not run, there is no spark detected
Homelite 330 – no points
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/baf9791bfc773f1a88256c2600142688?OpenDocument
Please try this
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
Oct 27, 2009 | Remington Electric Chain Saw
Spark plug gap on homelite 16 inch ranger chainshaw
I don't have access to an Operator's Manual and they don't appear to be available on line, I checked several different Homelite models at Chain Saw Collectors Corner. All said 0.025". HTH
Lou
Oct 11, 2009 | Homelite Garden
I have a homelite 240-hg I cant get it started i
Try some starter fluid (eather) that wil give you an indication if it's ignition or a fuel problem.
Feb 28, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
Feb 07, 2009 | Homelite ZR10926 16 Chain Saw
Garden Logo
131 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
