Question about Samsung LN32A330 32 in. LCD TV
The tv will not come on with either remote or msnuslly pressing the power switch
  • 760 Answers
Check for swollen capacitors on the power supply and replace. If you are not comfortable in soldering then I would take it to a authorized service center. You would mostly only pay for labor. The parts are only a couple bucks.
Posted on Apr 08, 2011
Testimonial: "I'm impressed with the promptness of th response."
  • Torrey Stensvad Apr 12, 2011
    If you call 1-800-Samsung and explain your situation, chances are they will repair the Tv for you at no charge. Samsung purchased bad capacitors from their distributor, which ended up in many TV's that are now 2 to 3 years old. Contrary to internet gossip, these are properly rated capacitors for the board. For example, Samsung only allows me to replace a 10 volt, 1000 microferrits with the same. I am an authorized Samsung TV tech and repair several of these every week. Depending on where you live and how accessible your residence is to the nearest repair person, Samsung might even send someone directly to your house. It's what I do in my area. If you call Samsung and you don't get the response you need, be persistent. They want you as a future customer!
I have an emish tv box the remote switches it off and on if I press it after about 5 seconds. But if I switch it off with the remote i have to use switch on back of box to switch back on
DIRECTV - Support: Your Remote Control
www.directv.com/DTVAPP/equipment/demoInfo.jsp?assetId...
DIRECTVTrying to get your DIRECTV remote control to work with other devices? ... TV Power On & Off - If your receiver turns off while the TV turns on, press TV Power On ...
Program the remote for your TV - Fiber Help
support.google.com > ... > About the remote control
GoogleThe Google Fiber remote control is not designed to fully control external audio equipment. ... Press and hold the button on the original TV remote that you want to program on the Google Fiber remote. If the learning works, the TV power button on the Google Fiber remote blinks twice ...
Dec 26, 2015 | Televison & Video
How to program Direct TV remote
How to program your DIRECTV remote control:
Press MENU on remote.
Select "Parental, Favs and Setup".
Select "System Setup".
Select "Remote".
Select "Program Remote".
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
Look up the control codes for your DIRECTV remote control.
Make sure your TV is turned on.
Slide the mode switch at top of remote to "TV".
Press and hold the MUTE button. This is located above the number 1 button.
While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
Enter the first TV code you have. The green light on remote should flash twice.
Aim remote at TV and press PWR button once. The TV should power off.
Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
Then enter 9911, the green light on remote should flash twice.
Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
When the TV powers off, press and release the SELECT button.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
Apr 11, 2012 | Audio Players & Recorders
Samsung AK59-00123A remote to a M261VP vizio tv
Hello
[1] Switch your television on
[2] Point the remote control towards the
television
[3] Press and hold the TV POWER button, and
then enter the two-figure code in the table
to the right that corresponds to the brand of
your television by pressing the appropriate
number buttons.
If your television is compatible with the remote
control, it will switch off.
The remote is now programmed to operate
the TV.
The code for Zenith TV is [TV POWER + 63]
Sep 20, 2011 | Zenith ZEN700 Remote Control
How do i search for codes on urc20-d1f
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
Jan 02, 2011 | Televison & Video
Can you help i have the asda rch7h10 smart price remote controls and have lost the insrutions i changed the battries and now they need re programing
Switch the TV on.
Press the Set and TV buttons together and the red LED should light continuously. Then press the power button and then press it every time the LED flashes (about once a second).
When the TV switches off, press the TV button on the remote. Switch the TV on with the remote and check that the other buttons work as expected. If not, repeat the process...
I had the same problem: worked it out by trial and error ;-) Hope it helps...
Oct 28, 2010 | Televison & Video
How to get some code for aorion tv
switch the toggle to tv, press mute and select at the same time until the light over tv blinks. then press 991 lights will blink again, then press 1. now press the power button and point at the tv and press the channel up arrow. you are now doing a code search and as soon as the remote finds the right code, your tv will turn off. once tv turns off, press select. if tv powers back on by pressing the power buttin, then you have found the code.
Sep 10, 2010 | RCA DIRECTV Satellite Remote Control
Need rca crk17sa users guide for codes for Magnavox TV
Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
http://www.directv.com/DTVAPP/content/remote_codes
Here's how to program your DIRECTV remote control:
  1. Press MENU on remote.
  2. Select "Parental, Favs and Setup"
  3. Select "System Setup"
  4. Select "Remote"
  5. Select "Program Remote"
  1. Look up the control codes for your DIRECTV remote control.
  2. Make sure your TV is turned on.
  3. Slide the mode switch at top of remote to "TV".
  4. Press and hold the MUTE button. This is located above the number 1 button.
  5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
  6. Enter the first TV code you have. The green light on remote should flash twice.
  7. Aim remote at TV and press PWR button once. The TV should power off.
  8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
  1. Make sure your TV is turned on.
  2. Slide the mode switch at top of remote to "TV".
  3. Press and hold the MUTE button. This is located above the number 1 button.
  4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  5. Then enter 991, the green light on remote should flash twice.
  6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  7. When the TV powers off, press and release the SELECT button.
Mar 08, 2010 | Televison & Video
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Programming my remote to control the sound on my TV
Here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
Jul 24, 2008 | DISH Network IR Remote Control
Ge 94948 universal remote instrutios for progaming t.v.
Hiya this is how i got mine to work.Manually turn on the tv.
Press and hold setup on your remote till the light comes on and stays on.
Then press the tv button then release. The light will flash then continue to stay on.
Now press and release the power button waiting 2 seconds before you press it again until your tv switches off.. you may have to press it for awhile.
Once your tv cuts off press the mute button and now your remote is set for your tv.
Feb 19, 2008 | GE RM24948 Remote Control
Samsung LN32A330 32 in. LCD TV Logo
554 people viewed this question
Jerry Greenberg
Jerry Greenberg
