Question about PNY Computers & Internet
Lap top will not start up after installing the ddr2
  • 73 Answers
The memory may not be compatible, make sure the DDR2 number matches the original memory. If it matches, remove and re-seat the memory firmly. if not replace with correct memory
Posted on Apr 08, 2011
  • PNY Master
  • 27,725 Answers
Make sure the RAM is securely seated and the RAM socket is dust free your laptop might not be compatible with ddr2 RAM also always keep the largest RAM closest the CPU central processing unit and keep the same brands/types of RAM some motherboards will not accept 2 different brands/types of RAM
hope this helps
2 Suggested Answers
  • 10406 Answers
SOURCE: How to install PNY OPTIMA 2GB DDR2 667 MHz memory card in lap top
Turn the computer off.
Remove the battery.
Unplug the AC adapter.
Turn the computer bottom-up.
Look for a few screws that secure a small panel.
Unscrew those screws, and remove the panel.
If you've selected the right panel, you should see your current RAM.
On the LEFT and RIGHT edges, there are small "fingers" that are holding the RAM.
Gently pull those fingers away from the RAM, and it should pop-up slightly, and you should be able to remove the RAM.
Notice that the "notch" in the middle of the RAM is slightly off-centre.
Insert the new RAM into the socket, and gently press down, until those two fingers "click" to grab the new RAM.
Depending on your "old" RAM, you may have:
* one "occupied" RAM slot (1GB), and one "empty" RAM slot;
* two "occupied" RAM slots (512MB/stick).
So, you may have to remove one RAM stick, to expose an "empty" RAM-slot "hidden" under the RAM.
Or, the "empty" RAM-slot may be visible without removing the RAM.
Or, you may have to remove one of the 512MB RAM-sticks, in order to free-up a slot for the "new" RAM.
Replace the cover-panel, and screw it in.
Reconnect the battery.
Reconnect the power-supply.
Start the computer.
Click Start
Point at My Computer
Right-mouse click on My Computer
Choose Properties
It should display your CPU-speed and the "new" amount of installed RAM.
Posted on Dec 10, 2009
Ok so i bought 2g ram upgraid ddr2 for my cf 51...was told this is what it takes....does not fit...do i shave it down....whats the issue
No you cannot shave memory to make it fit and work. It is designed for either SDRAM or DDR the slots are what identify the fit and type of Ram used on your computer. So you may not be using DDR2 ram it may be something else you need to get the specific specs for your lap top and exchange or purchase the proper ram replacement never deface or sand down ram and try to install into any computer. I hope this assisted you with all of your questions. John
Feb 08, 2011 | Panasonic Toughbook CF-51 Notebook
The power light come on in my vaio lap top but wont start
boot files / Win files corrupt....
re-install OS
visit my site
www.sureshayyar.110mb.com
get all details on installing Win XP
pls leave a feedback...
May 10, 2010 | Sony VAIO FZ Series VGN-FZ140N/B Notebook
Mouse pad wont work on lap top compac
boot to safe mode and test the touchpad. if it works on safemode, run system restore. if it does not, try reinstalling the touchpad driver.
Dec 01, 2009 | HP Hewlett Packard Compaq 6720s Laptop...
RAM is installed, but lap top does not read it
The 6735s requires DDR2 SODIMM chips clocked at 800 MHz and they must be installed two at a time (so a 2 Gb chip won't work - you need 2 1 Gb chips. Installing 2 + 1 Gbs will give you 2 Gbs only, (1+1), that is if the PC even boots at all; and so on).
Also, not all operative systems will read the full amount of RAM installed.
Oct 24, 2009 | HP Compaq 6735s Notebook
What is the maximum memory i can puty in my lap top. Model no.ML6226B Setial no. T3C7371006412
Installed memory: 512 MB (2 × 256)
Total slots: 2 DDR2 slots | Available slots: 0 DDR2 slots
Maximum memory: 2 GB
Sep 24, 2009 | Gateway Computers & Internet
Put in dvd of the all in one driving test disk into my lap top .all it does is go round very fast in the disk drive. So i am unable to install the programe . I have downloaded many disk but i am cluelas to...
If you can run other DVD's in this drive as well as CD's, then the problem lies with that DVD--try cleaning it first. To do this, gently wipe it across the CD/DVD (not in a circle around it) with a very soft cloth. Breathing on it to fog it a bit before you wipe it sometimes helps.
If this doesn't work, then the DVD is bad.
Aug 26, 2009 | Acer Computers & Internet
Lap starts with this masage and does not go past it
possible solution
you will need the installation cd for I believe it is windows vista and do a repair install as per the instructions , also if you have any external hard drives / usb memory sticks etc dis connect them before doing this.
Apr 11, 2009 | Computers & Internet
My Acer Lap-top Aspire 5570Z with 80GB HDD & 512 MB DDR2 is very very slow. Can its DDR2 be upgraded to 2 GB.
what the max ram is for this laptop? I bought 2x2GB dual channel ram for it and windows vista home premium (32bit) only recognizes upto 2GB, but CPU-Z recognizes more than that.
Mar 17, 2009 | Acer Computers & Internet
Having trouble with memory upgrade for Toshiba laptop
I don't see anything about DDR2 I do see DDR SODIMM.
Kingston ( a company owned by Toshiba) has the specs you need for your pc. Here is the link:
http://shop.kingston.com/modelsinfo.asp?SysID=23890&mfr=Toshiba&model=Satellite+M55&SUBMIT1=Find
Jun 21, 2008 | Toshiba Satellite M55-S135 Notebook
Computers & Internet Logo
51 people viewed this question
Top PNY Computers & Internet Experts
David
David
Alun Cox
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
