Question about HP Office Equipment & Supplies
I have an HP LaserJetM1522nf and I've replaced the cartridge and am now getting an error message; 10. 1000 Supply memory error.
How do enlarge on this printer?
Posted on Sep 03, 2008
Supply memory error(cartridge), Cartridge might be refilled or memory chip faulty.. Replace cartridge or if available replace supply memory.
Jan 17, 2013 | HP LaserJet M1522nf Multifunction Printer...
10.10.00 supply memory error
10.00.00 SUPPLIES MEMORY ERROR alternates with For help press ? Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 00 = memory is defective
  • 00 = black print cartridge
  1. Turn the printer power off, and then turn the printer power on again to clear the message.
  2. If the message persists, go to this site for HP support ( .
  3. If the printer has a 500-sheet Tray 3 installed, turn the printer off again and replace the print cartridge with a new HP print cartridge.
  4. Turn the printer on again.
  5. If the error does not clear, turn the printer off and remove Tray 3.
  6. Turn the printer on and verify if the error clears.
If the error does not clear, contact HP support. reference site:
Another option would be: 1. Open the top cover, remove
the print cartridge, and
reinstall it.
2. Install a new HP print
3. Check the connection
between the
DC controller PCA
(location J97) and the
memory chip on the print
cartridge (location J600).
4. Replace the memory chip
cable and contact assembly.
5. Replace the
DC controller PCA.
kindly read this forum 1st:
Aug 26, 2011 | HP LaserJet P3005 Printer
What is 10,1000 supply memory error with hp
10.1000 Supply Memory Error
A specific print cartridge has a missing elabel.
Reinstall the print cartridge.
Turn off and then turn on the product.
If the problem is not solved, replace the cartridge.
Jul 21, 2011 | HP LaserJet M1522nf Multifunction Printer...
10.1000 memory error
Thank you for contacting FixYa with your printer inquiry.
This error is normally associated with a supplies error. I have extracted information on this error from the HP 6L manual.
Error Codes
Error 10 - Supplies Memory Error 10.XX.YY Exact format is dependent on printer model
    The printer is unable to read the electronic information (elabel) on the print cartridge. This helps track page count and life of consumable.
    XX Description 00 memory error on the cartridge or 01 memory device not found
    10.00.00 Black print cartridge
    10.00.01 Cyan print cartridge
    10.00.02 Magenta print cartridge
    10.00.03 Yellow print cartridge
  1. Supplies used in newer printer models contain a memory chip. The information contained on this chip is dependent on the printer model and the supply. The error 10 indicates a problem with the printer obtaining the information from this chip. The chip may be missing or defective or contain incorrect information. There may be a problem with connection between the memory chip and DC controller. Turn the printer off/on to attempt to clear or reset the message. Remove and reinstall the supply, replace the supply.
  2. Replace the memory chip cable/connector or the DC controller.
    How did we do?
Hope this helps helps. Please keep us updated and remember to rate this answer.
Jun 08, 2011 | HP : HP6L Laserjet Printer
I am getting error: 10,1000 supply memory error reinstall
You are using re manufactured toner and it has a bad chip. Replace the toner.
Jul 06, 2010 | HP Laserjet CM2320nf All-In-One Color...
10.1000 Supply Memory error. How can I fix that?
sounds like might be your toner, specifically your black toner.
is this a non-standard toner or HP? IF it your toner you can try this:
Place a stip of opaqe tape or paper or the chip. When the printer detects a non-standard cartridge press the green (go) button. It will then reset the LCD to Ready.
Found this info on a recycled manufacturer site.
otherwise it's probably the memory on the printer, try removing or replacing a DIMM
Jun 09, 2010 | HP LaserJet M1522nf Multifunction Printer...
Supply Memory Error
It sounds like you are having two diffrent problems. I don't think they are associated with each other.
First, the memory supply error. The cartridges on this machine have a chip. The chip could very well be faulty causing this supply error message. Change the black cartridge and see if the message clears. if it dosen't then the antena that reads that chip needs to be replaced. I suspect the cartridge is the problem.
Second, the paper jams. This can be caused by a worn p/u roller as you mentioned. Sounds like the jam happens first then the error, based on your description.
The black thing you refer to on the door is called the "transfer belt assembly".
Aug 21, 2008 | HP Color LaserJet 2600n Printer
Memory error
Just do 2 steps:
1. Press Stop.
2. If the display highlight "Resume". Press the OK (Check Button).
The display will tell you that a Non-HP Cartridge is installed and Economode is Disabled.
At least, you can now print. The display will show back again to "Ready".
Jul 23, 2008 | HP LaserJet 2420 Printer
"cartridge memory error"
To identify the misbehaving cartridge just replace them one by one with another new, preferably HP cartridge. As far as why, HP makes lots of money by ?encouraging? users to buy genuine HP consumables. While HP?s cartridges are uniformly the best available they are are outrageously priced, thus the refill market. In an attempt to kill the remanufacturing market HP now embeds ?chips? in each of their LaserJet cartridges, unfortunately for HP refillers can replace them too. I?ve found several references to this error message and they are always linked it the printer discovering a remanufactured cartridge. In most of the other cases this automatically disables ?economy mode? printing but you can typically bypass the error message by hitting the enter (check) button on the printer.
Nov 28, 2006 | HP Color LaserJet 3500 Printer
165 people viewed this question
Ben Johnson
