Question about Samsung Televison & Video
I Have a 72"
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, don't worry, just read the rest of this and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
i  Have a 72 You-Tube video "Mm51C_RDIZE" placeholder
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Apr 08, 2011
How to reset my security or antithef ligth on escalade 2004 wont start or cranck
Try this it works on an 2002 with the master key take and turn the key on wait about ten minutes the antitheft light will go off then switch the key to the off position wait 5 seconds and turn back to the on position do this 3 times total. On the 3rd time switch the key off then start the vehichle. It may take a few trys of reprograming to get it to work it takes about thirty minutes to do.
Oct 08, 2013 | Cars & Trucks
All lights flash on Epson stylus TX110
switch off the main power of printer in running situation and then on the printer.. hope it will be work..
Aug 20, 2012 | Epson Stylus Multifunction Inkjet Printer/...
2001 Cadillac Deville problems starting
I have had the same problem and I have come to the conclusion it is the security system. After 3 minutes the car will start so there is nothing wrong with the battery or starter. I have had it to the dealer a few times and they cannot solve it. It may be the locks on the doors and they may not be resetting properly. I have learned to live with it.
Oct 08, 2009 | 2001 Cadillac DeVille
Samsung Dlp completely shuts off and then all three lights flash
Sounds more like the TV is overheating. The lamp cooling fan may be seized or not spinning fast enough. If the TV gets hot enough to trip the thermal, it could rupture the lamp.
Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HLN617W TV does not turn on, all 3 lights flash
In this case it seems you may have an issue with your ballast. Either it's going out or barely starting. I recommend you replace it
Aug 06, 2009 | Samsung Televison & Video
My Sansung HL-S4266W just shut off one evening while watching. It had all 3 lights blinking and it had been over 3 years since buying the tv. I replaced the bulb, nothing changed the tv would still turn on...
this could be the color engine or a power supply problem. My suggestion is to not put anymore money into this tv, its an old technology and you will be replacing parts for it every 3 or so years. eventially the parts will not be able to be found. Go get a new tv, save yourself money and headaches.
Jul 17, 2009 | Televison & Video
Samsung DLP 72inch, recurring loud pop then fuzz for 3 seconds
I pulled out the Lamp, cleared the dust inside with one of those air blowers and returned the Lamp. That seems to have fixed the picture problems I was having.
Jul 07, 2009 | Samsung DLP HL-P5663W 56" TV
Door locked, start pause light flashing
I also have the same problem. I have got it to work by unplugging for a day and night. When I plug it in the next day it works like new for a couple days and then back to the same old "door locked" problem when the door isn't locked........BIG HEADACHE!!!!
Jun 11, 2008 | GE WSXH208A Front Load Washer
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
