Hello I have a Bosch Problem with the Washing Machines Hello I have a Bosch WFT8030 washer/drier. as soon as it start workig at any kind of progrem the green led [spining symbol] lights up, and the red led in the draying progress [2 drops] start flashing. can you help me please??
    Brigadier General:
  • 6,277 Answers
If you haven't already tried this I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 08, 2011
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Why won't it start?
Bosch WAS32461GB Washing Machine that will not start
www.how-to-repair.com/.../bosch-was32461gb-washing-machine-that-w...
Mar 31, 2015 - Bosch washing machine Will not start, won't start, Will not open - this is usually due to the machine still having water in it or a door interlock ...
My Bosch Washer Won't Start ' eHow
www.ehow.com > Home
If your Bosch washer does not start, there are a few troubleshooting steps to take before calling for ... Problems with Bosch washing machines that won't spin.
Bosch washer WFMC6400UC won't start - Appliantology.org
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 07, 2016 | Bosch Washing Machines
Bosch advantixx washer drier drier only runs 5 mins then switches off
The likely answer is the motor is overheating and the auto cut-off switch activates. If you wait a while it will then start up and repeat.
The answer will probably have to be a replacement motor, but a qulified engineer may find he can clean up the motor contacts and get it running - but that may cost same or more than a new motor!
Nov 18, 2015 | Bosch Washing Machines
Hello I have a Bosch WFT8030 washer/drier. as soon as it start workig at any kind of progrem the green led [spining symbol] lights up, and the red led in the draying progress [2 drops] start flashing. can...
Hi
The issue seems with the water not draining completely and so it is unable to work correctly. The issue can be with the either the motor that is bad or something is clogged and you will have to take the bottom front panel out to clean it. Hope this helps...please post back for further assistance.
Daniel
Apr 06, 2011 | Washing Machines
Have new w.m. installed, but no manual, can you forward in pdf format instn's for operation. ta.
Hello gallagher, welcome to Fixya. I can send you a "pdf" manual, but you'll need to post an email. I'm in the process of setting up a windows live account where I can make this kind of thing available, but I'm not there yet. I'll watch your post and as soon as I have your email I'll reply to confirm I sent it. Once you receive it please rate the assistance favorable. Macmarkus :)
Jun 20, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Drier
Dont know if it will help try this website: www.bshappliancecare.com. I think Bosch and Siemens might have some common ground but please please dont hold me to this.
Sep 03, 2008 | Bosch Classixx WVF 2402 Front Load...
Bosch WVF 2402 Washer Drier Steam Problem
Hello All
Problem solved by clearing out the condensate container which on inspection was full of dried up fluff and dead tissues! This is not a ****that is mentioned in the manual and access to the bin is pretty tricky so I suspect there are lots of machines out there with the same problem waiting to happen.
Access was gained by taking the top of the machine off, removing the dryer motor and then scraping out the muck using a wire coathanger and a vacuum cleaner.
Many thanks
Andy Wray
Mar 08, 2008 | Bosch Classixx WVF 2402 Front Load...
Washing Machines Logo
Top Washing Machines Experts
