Error code f35
Hi any one can help me fixing this error code f35 i m using konica photocopier
thanks for prompt response.
  • pakmail442 Aug 07, 2008
    its konica 2223
Konica f 35 eror code
Posted on Oct 25, 2008
What model is the Konica?
Posted on Aug 07, 2008
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
hi piz Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
Apr 29, 2010 | Konica Minolta bizhub C250 All-In-One...
I have a Konica 7145. It has error code
This is a fixing unit over temperature fault. The device has detcted the fixing unit has gone over 470 degrees F.
You will need to check the Thermisters in the fixing unit, and repair or replace as needed.
Service mode DIP Switch needs to be reset after repairing.
WARNING
• When F34-∗∗, F35-∗∗ or F36-∗∗ (fixing temperature related abnormality) occurs, be sure to repair a defective part before setting the 25 DIPSW 3-1 to 0.
If the 25 DIPSW 3-1 is set to 0 without repairing a defective part, it may cause a fire.
Apr 26, 2010 | Canon imageRUNNER C3200 Copier
ON SWITCHING ON THE COPIER KONICA 2020 ERROR CODE F35 DISPLAYS PROMPTLY
How to clear fuser abnormality codes (F34, F35, F36), 2020.
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
If the code comes back then your fusing unit will need parts/service.
Dec 14, 2009 | Office Equipment & Supplies
Error code f-35-8
On most Konica copiers, an F35 error indicates:
1. low temperature of the fuser; and/or
2. open lamp; or
3. open thermo wire fuse; or
4. open thermistor; or
5. or anything heat related at start or warm up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 19, 2008 | Office Equipment & Supplies
Error code F35 on my konica 1212 photocopier
That's a fuser error condition...I'll have to get back to you because i have to check in my book to remember how to reset it...Thank you for your patient !
Mar 19, 2008 | Office Equipment & Supplies
Error code 27
The error code p27 the toner density sensor unplugged/dirty/faulty
Any problems please get back to me
thank you
Feb 19, 2008 | Office Equipment & Supplies
515 people viewed this question
k24674
jasbo
jasbo
