Question about Janome Memory Craft 9000 Computerized Sewing Machine
Why does my Gutterman thread keep breaking on my 6600? I was told this was a good thread to use a Janome dealer?
  • Janome Master
  • 1,133 Answers
Have you got the thread aerial up and using the thread cap on top of the spool of thread to ensure it feeds off smoothly. Also need to look at the thread spool, some of them have a little cut in the top where the thread end is placed to keep neat. If the thread is catching on this, just turn the spool up the other way and use the cap to hold thread away from the edge of the spool.
Gutterman is a good quality thread so you need to check that there isn't something in the thread path catching the thread and affecting the tension which is why it usually breaks. It could be a burr on the bobbin holder, the black plastic tensioning device which sits on a magnet. I have managed to damage 3 of these with my 6600P by trying to stitch too heavy weight seams, the bobbin holder moves and then the needle strikes it, once to the point of piercing right through it!
So have a look in the bobbin area, refer to your manual if you haven't removed the bobbin holder before. There is two little red marks that need to line up when it is in the right location. If you can see damage on the bobbin holder, you could take it out and try to file down the burring with a nail file or very fine grade sandpaper and then put back in again. The needle thread could be catching on a burr as it comes around during the stitch process.
Also, look at the top tension dial, turn it to zero and clean between the discs with the selvage edge of a clean piece of cotton waste. Then turn tension back to 5 and thread up everything and try again.
If you have tried all the above without success then perhaps take it back to the dealer and ask them to test sew it for you and see if they can spot the problem.
Posted on Apr 10, 2011
I use a speed controller, medium speed. Top thread keeps fraying and breaking. Have tried changing needles, used 100/16 hlx5, 90/14, janome numbers 16, 14, 12.
When the thread is fraying at the needle eye, it sometimes means the thread is being held back somewhere in the thread path. Remove the top thread. ALWAYS RAISE the presser foot and rethread. Verify the thread path is correct. Check the tension. If it is too tight, the tensioner is not allowing the thread to advance. (When you raise the presser foot, are you able to pull the top thread?) Try changing thread brands. Some threads and machines just do not get along. AVOID old or bargain bin threads. If you are stitching coarse, abrasive fabric, it can cause thread to fray and break.
Jun 14, 2018 | Janome Sewing Machines
I have a janome 6600. The stitches started jamming up and breaking.What might be causing the challenge with the stitches?
Difficult to say without really seeing what's happening and which thread is breaking. If the top thread is breaking, check to make sure the thread is not wrapped around the spool pin or a thread guide.
Just some things to try:
Install a brand new needle.
Be sure to clean and remove all the thread pieces, lint, etc from under the needle plate, around the shuttle, etc. Oil as instructed in the owner's manual.
Remove all the thread from the machine. ALWAYS RAISE the presser foot when threading the top and rethread the machine from the beginning. Check that the thread path is correct and the bobbin is loaded and threaded correctly.
Be sure to use good quality thread--no Old or bargain bin threads!
Solve Most Sewing Machine Problems With These Simple Tips
Why Does My Sewing Machine Keep Jamming Sewing Made Simple
Feb 11, 2018 | Janome Sewing Machines
I have a Janome 1600P and the top thread keeos breaking
There are several common reasons for upper thread breakage.
Check that the needle/thread/fabric are compatible.
All About Needles
Remove the upper thread from the machine, install a brand new needle, ALWAYS RAISE the presser foot, and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point.
NMSU Checklist of Common Machine Troubles
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
Oct 29, 2016 | Janome Sewing Machines
How do you clean out the lint and dust from a Topaz 20 machine. Alos my thread keep breaking and I'm using Gutterman so it should be good. I never had this problem with my Janome.
you might try a can of computer air to clean out the lint and dust, it's a good idea to clean under the needle plate also.
what problem did you have with your Janome?
Jan 26, 2014 | Husqvarna Sewing Machines
Thread keeps breaking
Have you checked any edge the thread might contact for knicks which should be files or sanded down? Also, I had to replace my bobbin case after a number of years as it had kind of stretched out and allowed my bobbin to pop around and consequently broke many threads.
Feb 07, 2010 | Janome Memory Craft 9000 Computerized...
New Janome 6600 Erroring out
This is the official Janome reference to your E% error message:
Feed sensor error "E 5" appears when the machine is turned backwords slightly while the machine runs over tight spot. The above will happen when - the machine is locked by thread jammed in the machine. - sewing extreamly thick fabric. In case of the MC4900, it will happen when running without threading the thread take up lever. The thread take up lever should be threaded when the threading light lights up.
Hioe this helps
Bargain Box
Sep 27, 2009 | Janome Memory Craft 5700
Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Sep 23, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Top thread breaking during sewing.
your needle needs to be replaced and make sure it is in correctly..if this does not work you will need to make sure your thread is not old. then adjust you bobbin tension...there are 2 tensions on machine top and bobbin
May 22, 2009 | Janome Memory Craft 9000 Computerized...
No zig and cotton keeps breaking
Make sure you have a new sharp needle installed for both problems and sometimes you need a particular kind of needle for the fabric. Also some machines don't deal well with 100% cotton thread. For some reason it gets caught up in the machine somewhere and breaks. Gutterman and Metrosene make excellent although slightly more expensive threads. Coats and Clark thread is good too. They make an all cotton thread but it doesn't come in as many colors. If you have the old spools of cotton thread from Walmart, just use them for topstitching if you need the color. Other wise, use them for hand stitching or throw them away. One more thing that I can think of off hand, one of my machines does not like lining fabric. For some reason the thread breaks if I stitch really fast. If you have to use that thread, you may try sewing slowly. One more thing, when was the last time your machine was serviced? This can make a huge difference if it's been awhile and you use the machine a lot. Good luck. Hope any of this helps.
Apr 01, 2009 | Janome Sewing Machines
Janome Memory Craft 9000 Computerized Sewing Machine Logo
166 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
