Question about Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD Television
I have a Sony KLV-S40A10 LCD TV. The picture is black but the audio works fine. The back light comes on as well as the green light. I have tried from the cable box as well as the dvd player. I have checked the power save options and the tv is on. I have unplugged it and tried again and no change. Is it possible the lcd screen has failed?
  • 1,591 Answers
It's much more likely a fuse has blown to the video processor board, or a cable is loose going from the video board to the LCD panel, or a cold solder joint on either end of that cables' connectors, or the most likely answer is a leaky or blown capacitor in the power supply section.
Any caps in these (or any) sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably come on and display video, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, don't worry, read the rest of this and watch the videos.
If you are handy with a soldering iron, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Apr 08, 2011
  • 325 Answers
If you can see the screen iluminate I wouldn't assume the panel has failed. It seems that your video sources are not being decoded and then shown. I would suspect the mainboard (aka tuner board) to be having problems. It may not be getting the proper voltage needed from the power supply. When repairing, start simple and that is ALWAYS the power supply FIRST...then other components second.
Hope this helps, please rate.
I have SONY BRAVIA MODEL KLV-32BX300 LCD TV the scren /panel was broken or Dameged .How Can I get the part of this product
Thank U
Tigstu
Posted on Apr 19, 2011
2 Suggested Answers
  • 713 Answers
SOURCE: We have a Sony Bravia lcd tv model KLV-S40A10 - no power
Hi,the problem is from the fuse in the tv,it's blown and it's a means of in-built security against power fluctuations from damaging the unit,so the solution is to replace the fuse of the TV to restore your unit back to a normal working condition.
Be cool.
Posted on Jun 13, 2010
On my Sony Bravia KLV-S40A TV I have a message "VIDEO 1". How do I get it off the screen?
On the original SONY remote press display to remove that---if left on long enough it will actually burn that image into the screen--button on almost any Sony Tv remote will remove or clear it.
Oct 25, 2012 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Be cool.
Jun 13, 2010 | Televison & Video
My Sony Bravia KLV-40U100M has audio but the screen is black. No picture. Could it be the lamp? The unit is only a little over 2 years old
No,this tv a LCD not a DLP.The LCD inverter board is dead.Must replaced to get picture back.The board is usally a long board.Tries Shopjimmy.com,Ebay.com to buy the board.
Jan 15, 2010 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
It was working fine then no picture dark sceen sound work fine
More information is required. Your backlight is lit (screen not dark) but I need to know what you have connected to the TV (your sources) and how they are connected. Does the menu/OSD (on screen display) work?
Oct 19, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
KLV 40S200A
If you watch how many times the light flashes and then relay that to your local authorized sony repair centre they will tell you what is likely wrong with the TV. Have you unplugged, left for a couple of minutes and re-plugged?
Sep 07, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
OK SOUND NO PICTURE
More information is required. What do you have hooked up to the TV and how is it connected? Do you have a menu/OSD (on screen display)?
Jun 25, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Tv shuts off spontaneously. red power light blinks.
re: sony flat panel lcd tv mod. # klv s 40a10.
No power. When power button is pressed, nothing happens.
The stand-by at the power supply ( cn6201) measures to be 3.47 v. instead of 5 v. However, when I unplug cn6201 (5 pin connector) I can read 5v. at the power supply.
Any suggestions?
Jan 23, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Bravia KLV-S40A10 HDMI input
I agree with your solution and you are correct in that you lose very little quality by using component instead of HDMI. there are A/V receivers that transcode HDMI inputs to component; as far as I know that's the only other option
Dec 25, 2007 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD Television Logo
544 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
