Question about Whirlpool Microwave Ovens
I have whirlpool model MH1160xsq-0. We recently replaced the light under the microwave....after a few days it "sparked" out. Now the new light and fan do not work and the microwave itself runs much slower.
5 Suggested Answers
reg501
  • 413 Answers
SOURCE: Whirlpool Microwave
The magnetron has failed and has damaged the waveguide. This type of failure is generally unrepairable. First look in your owners manual for specific warranties, then contact Whirlpool and explain to them what has happened.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 08, 2008
erpaalai
  • 999 Answers
SOURCE: Whirlpool Microwave Oven Serial Number MH660XW-0
Hi Adam,
Built in over the range? The models change so rapidly unless it is less than a year old there probably wont be an identical replacement, Fortunately the mounting brackets remain close if you stay in the same brand. Whirlpools can be purchased at almost any retailer like Lowe's, Sears, BestBuy etc. Measure the the original and look for one that fits that dimension.
Eric
Posted on Jun 10, 2009
  • 464 Answers
SOURCE: Whirlpool MH1160XSQ-1 microwave oven will not heat
all microwaves have a magenetron which produces the heat. if this is gone and it is not under warranty, it is not cost effective to repair. check you manual, most mag's have a 3 - 5 year warranty.
Posted on Nov 07, 2009
  • 10865 Answers
SOURCE: I'm replacing whirlpool microwave model
Hi ahenley.... Actually there are several choices for you. If you want your new one to be the same size as your old one be sure to measure your old one before you go to the store. Here is an excellent review of some of the better microwaves on the market now! http://www.consumersearch.com/microwaves?gclid=CPSf3ZTI2qUCFeJ95QodEliZyQ&ef_id=skZM-mDvAAAAga0:20101207162935:s
Joe
Posted on Dec 07, 2010
My Whirlpool microwave MT6120XEB-0 keeps blowing the fuse. Inststalled new fuse and display and timer works. Cooking blows new fuse. It turns on, makes grinding sound and blows a new fuse within a second...
You almost certainly have a shorted high voltage capacitor.
See the safety warnings and help information here.
Chances are you will have to remove the oven from the wall to replace it.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 26, 2013 | Microwave Ovens
My whirlpool microwave model gh4184xsb needed a new cooktop light bulb so I removed the cover to replace it. I didn't unplug it (BAD!) and there were sparks and the microwave lost power. We repla
there are short. go to www.repairclinic.com for to get the parts.
2) test the switch door for short and replace see the diagram
3) test the high voltage capacitor+ high voltage diode
see the diagram
7_15_2012_12_42_08_pm.gif7_15_2012_12_42_27_pm.gif7_15_2012_12_42_40_pm.gif7_15_2012_12_43_03_pm.gif7_15_2012_12_43_25_pm.jpg
Jul 15, 2012 | Microwave Ovens
GH7155XHS Microwave control panel
If you do not want to get the newer model due to configuration changes it does not appear that you have another alternative other than to replace the logic board on unit. And unless you can spot a very obvious issue with the board, there is no way for you to fix it especially if it is a bad ic with beaucoup connections to the board.
Mar 24, 2017 | Whirlpool GH7155XHS Microwave Oven
Microwave whirlpool model AVM 240 - plate problem
What problem, I wonder....
If you need a new one, You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If yours is not turning, it may be grease under the plate or in the motor, a bad motor or coupler, or a problem with the control circuit board that supplies its power.
I would especially suspect the board if you're recently had trouble with the cooktop lights.
Oct 01, 2011 | Whirlpool MH7140XF Microwave Oven
Model mh1160xsq-1 with the door closed and nothing programed the cavit light stays on and the turntable rotates
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean , solder and reset the board.
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Jul 14, 2011 | Whirlpool Microwave Ovens
I'm replacing whirlpool microwave model GH7145XFQ-0. What whirlpool microwave and model today replaces it?
Joe
Dec 07, 2010 | Whirlpool Microwave Ovens
The hood light blew and I replaced it. It worked
The cause could be anything from defective bulbs(least likely, to a bad bulb socket or vibration during operation. A voltage measurment at the bulb will tell you if it is getting too much.
Eric
Dec 24, 2009 | Microwave Ovens
Nov 07, 2009 | Microwave Ovens
27 day old MH1160XSQ micro-wave- turn table will not turn.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free. Whirlpool customer service is here.
For owners whose oven is out of warranty, read on:
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel (and your model does not have this feature) but it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 13, 2008 | Whirlpool Microwave Ovens
Whirlpool Microwave
Regards,
reg501
Jul 07, 2008 | Whirlpool GT4175S Microwave Oven
Microwave Ovens Logo
161 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
